jollyranchers Posted October 16, 2013 Posted October 16, 2013 (edited) Well I replaced my tyres with these a few weeks ago , however if i'm honest i'm not that happy with them. The main complaint being the side walls seem quite soft and where as the Zed used to be flat as anything into the corners with next to no body roll I now feel the car rolling in the corners. Ive checked the pressures every week and the results are noticeably different to my last budget set. Yes they are quiet and the grip is noticeably better in the wet ,love the tread pattern however the extra body roll is noticeable Its seems i'm not alone in my opinion after a quick look on the net Anyone else find this ? http://automotivethi...essanta-review/ Edited October 16, 2013 by jollyranchers Quote
ATTAK Z Posted October 16, 2013 Posted October 16, 2013 I've never been keen since I found out they they were not handed for driver and passenger sides Quote
FooFighter Posted October 16, 2013 Posted October 16, 2013 I liked them when I had them but I agree they feel soft especially compared with the Bridgestone RE050s which I run now. I thought the Sessantas gave a lot of feedback which was nice. I would have got another set but they seemed to wear fairly fast. Can't say I've tried many tyres on the Zed but, If you've not tried them, you might like the Bridgestones if you want a stiffer tyre. More expensive but I find them harder wearing. Quote
ioneabee Posted October 16, 2013 Posted October 16, 2013 I found the bridgestones pants - but the vreds excellent - so totally opposite Quote
dragon Posted October 16, 2013 Posted October 16, 2013 I have them on mine but find them ok only prob I have with them is they wear quick. Quote
jollyranchers Posted October 16, 2013 Author Posted October 16, 2013 I can deal with wear but was not expecting the roll , I'm sure I will get used to it but does leave the car less confidence inspiring I've no doubt it wont let go as they are grippy , but just un nerves you slightly as it didnt do it before Quote
Lexx Posted October 16, 2013 Posted October 16, 2013 I had 2 sets on my RX8 and 2 on my 350z. Never had any reason to dislike them. The feedback was excellent, and I knew exactly what was going on at all times no matter how spirited my driving was. I had Tein SuperStreet fitted (to both cars) so suspension was pretty stiff and probs masked any sidewall lean. But to be honest, the grip and feedback, far out weighed any of the negatives a little tyre roll would give. Quote
rtbiscuit Posted October 16, 2013 Posted October 16, 2013 i found you need to up the tyre pressure to remove some of that tyre roll feel. about 5 PSI above the factory reccomendation Quote
The G Man Posted October 16, 2013 Posted October 16, 2013 Had two sets on my last Z, but like Lexx, I had a modified suspension set up, they were allright, wear was probably average, better than the RE050's. You say you've only had them on a short while, are they properly scrubbed in? Finding that the Bridgestone's on my present Z, very, very good, rears are 285's though and the suspension is, again highly modified (factory). Never really had a problem with the Bridgestones, either on my RX8, my last Z or this one. I will probably stick with them when the time comes. Quote
Dblock Posted October 16, 2013 Posted October 16, 2013 I didn't think they where all that tbh. Not as grippy has eagle f1's which to be fair ARE more expensive but the wear was terrible. Like so bad I wouldn't even consider them. I don't drive hard etc etc and my eagle f1's did double the mileage plus the better grip for only a small bit more outlay. No brainer for me tbh. Quote
Ebized Posted October 17, 2013 Posted October 17, 2013 i found you need to up the tyre pressure to remove some of that tyre roll feel. about 5 PSI above the factory reccomendation This is the answer, except I found 3psi was enough - otherwise I would agree with the other comments ^^^^ and that they need to be well scrubbed in before pushing the limits. Quote
chubbster Posted October 17, 2013 Posted October 17, 2013 I'd intended to buy them as my new rear tyres a few months ago, with a view to putting them on the fronts too, at a later date, but when I compared a range of tyres by looking at as many reviews as I could, I was disappointed to find out that they didn't rate very well. So I bought a different brand - Falken 453's, which are nice and stiff on the sidewalls. Quote
hensh65 Posted October 17, 2013 Posted October 17, 2013 Yesterday was my first day to actually test the MPSS by giving it some beans. Wow is all I have to say, the power you can get from first gear now is unreal and also the grip in the wet is night and day. highly, highly recommend Quote
docwra Posted October 17, 2013 Posted October 17, 2013 I didnt like them either, found the ultimate grip lacking a little and thought the feedback right on the limit was a bit vague - as per others, RE050A's are streets ahead (as are MPSS) Quote
zxrob Posted October 17, 2013 Posted October 17, 2013 Dont you just love a good tyre debate I will need to replace the rear bridgestones shortly, may just replace like for like or go falkens as they seam to be popular Rob Quote
Ekona Posted October 17, 2013 Posted October 17, 2013 As always, match the fronts or change all round. MPSS are expensive, but you more than make your money back in the length of time they'll last you. The question shouldn't be "What's popular?", the question should be "What do I want from a tyre?". Answer that, and then you can be recommended. Personally I enjoyed the VUS as a hooning tyre since you get masses of communication, although that's offset by lack of grip compared to the 050A or MPSS. Quote
maddog1982 Posted October 17, 2013 Posted October 17, 2013 Had them on my 350 when I bought her, was impressed but once I fitted MPSS I realised that they were no where near as good as these Quote
jjt Posted October 17, 2013 Posted October 17, 2013 Ive had Goodyear Eagle F1 Asymmetric 2s for about a month now, and already I am very impressed with them. So much adjustability mid corner compared to my previous setup of track-biased Federal 595 RS-R, and grip in the wet (as well as clearing standing water) is on another level. I'm yet to feel the car feel anything other than 100% planted, and I really cant imagine how the MPSS could actually have any more grip. Quote
ianphampton Posted October 17, 2013 Posted October 17, 2013 I found the bridgestones pants - I also did not like the Bridgestones - I've been on Goodyear Eagle F1s for a couple of years now and I find them very good, quiet, good grip (both in wet and dry) and they've lasted well, even after a couple of track days and 4 laps on the 'Ring in that time Quote
jollyranchers Posted October 17, 2013 Author Posted October 17, 2013 will try upping the pressures over the weekend , scrubbed in or not I'm surprised in the difference in roll compared to my budget set Ill get used to them no doubt , just initial opinions on them ! the grip i find is very good Quote
HaydnH Posted October 18, 2013 Posted October 18, 2013 Which 'stones are you guys not liking? I thought the RE050As were excellent, not quite as good as MPSS or AD08s, but still very good. Aren't they the standard tyre on the Enzo after all? If it's the RE040As that's a different story. Quote
glrnet Posted October 18, 2013 Posted October 18, 2013 +1 ^ The 40's were shocking in the wet. The VUS's have been great for me (19" rims and standard suspension apart from uprated ARB's). I love the feed back they give, never really noticed the roll problem but that's helped by the ARB's, I run mine at 35psi and they have done some hard work in Wales this year without any dramas at all. I had Falken 452's after the 40's and they were an improvement, the VUS's are an improvement again although I would seriously consider MPSS next time. Quote
Toon Chris Posted October 18, 2013 Posted October 18, 2013 (edited) I thought the VUS were a great improvement onthe Flakens for grip too. The falkens never gave me any confidence but the VUS keep me nice and flat in the corners. My suspension is definately a litlle stiffer but yes the VUS have a touch more roll,but as the Falkens were so much less confidence inspring I don't think its a bad thing - at least I can feel what the car is doing. Edited October 18, 2013 by Toon Chris Quote
chubbster Posted October 18, 2013 Posted October 18, 2013 Yes, the 350z's original RE040's weren't good in wet or cold. The RE050's on my 370z are better, but that's not saying much. I too shall be going for MPSS. Quote
HaydnH Posted October 18, 2013 Posted October 18, 2013 Am I the only person on here that runs AD08s? Quote
