Suzanne the LS3 6.2 V8! Caution very long build thread....
Wasso
Just spend the last hour planning the intricate elements of the build over the next 2 months. Silly things like oil, rad, fabrication mounts, diff, wheels and some fu@k off great big turbo's all make up the remaining bits.
I have fixed that for you Ian :stir:
:lol:
from faceplant ....... and I quote "Yummy breakfast before heading home to see my Daisy & wait for my sweet to come home from his project weekend💕"
awww - there's lovely :blush::huglove:
from faceplant ....... and I quote "Yummy breakfast before heading home to see my Daisy & wait for my sweet to come home from his project weekend������"
She's a good girl..... :teeth:
Another fun day in the Zed Shed today, well it was for me I got to angle grind and weld on Wasso's car - he took it really well to be fair, even when the sparks were flying :lol:
No video today as it was all in the car or on the workbench.
First job was to get the gearstick in position and working - Ian came out very lucky here considering we are not using the T56 box and Sikky don't do a convertor for ours we knew we had to do some fabrication - as it happens the rear gearbox mount was a reasonably straight forwards mod and the box and arm are almost exactly in the right place :thumbs:
Now the box is mounted we needed to get the gearstick to hold correctly in the right place - fabrication time :teeth:
seems like I forgot to take any more pic's of the last bits of fabrication :doh::sorry:
So moving swiftly on -
The 350z gearstick next to the LS gearstick :scare:
angle grinder to the rescue :lol:
weld the bits together
we have a LiSMO gearstick
All in place -
The only problem is when you put her in gear
As you can see the stick is to far forwards - O well :shrug:
We will simply take it out and bend a dogleg into it to get it more upright, but that's for another day as Wasso had to get home and I need to get in from the cold and have some grub.
More soon .............................
While waiting for our Zorst specialist to reappear on the scene I got bored :lol:
So.........
You may remember that the gearstick which is now half 350z and half Corvette has an issue -
when you put it in gear you smash the ipad :lol:
So I took some very technical measurements and made an intricate template
cut the gearstick up and welded a collar round it
cut it - beat it with a hammer and welded at the new angle
Fits like a glove
well it's better anyway and it seems all gears are available without beating the air con controls (I Hope)
That's all for now :thumbs:
  • Like 4
Pretty cool & I bet the extra weight may even help with better gear shifts. :DB)
:lol:
Extra weight you should try the corvette standard one it's basically a 2 foot scaffold tube with a bit of leather on one end - we did try it but it was interfering with the sun glass holder :lol:
  • Like 8
Cool work! Sending my car over for ls3 swap asap... Missing the FI part when is that happening? ;)
That gear shift work is awesome , what way does wasso shift though , depending on his hands on the shifter he might hit the knuckles on the knobs? ;) might have to adapt :p
Love the updates, perfect for snowy Sweden.
