Keyser Posted August 6, 2014 Posted August 6, 2014 (edited) Due to my current personal situation I have decided that rather than sit in my garage gathering dust I will simply let her go to a good home. Please do keep in mind this is not a slightly modified Zed it is extreme in most respects, basically it is a road legal race car – it’s harsh, loud bumpy hard work in heavy traffic and demands more attention by way of servicing etc than your average Zed. Let’s get the bad bits out of the way – The body work needs attention both the front and rear bumpers need fibre glass work and the paint is suffering in several places so a re-spray or wrap may be in order. She will also need some new rear tyres soon 500HP tends to rip em up quite quickly That’s it as far as I know just cosmetic work needed really other than that she is fine, I last drove her home from Japfest after being on track and she gave me no problems at all. The only differences between the last time anyone saw her and what I am selling is the Bride seats will have been changed back to standard cloth seats and the Kaaz limited slip differential will be removed and swapped back to a stock vicious diff (these parts can go with the car subject to an agreed price) Onto the spec – UK 350z GT with 48,700 approx miles on the clock. Engine rebuild and full bodywork/suspension rebuild was done at about 42,000 miles, the V3 SC was fitted about 200 miles ago. Engine built by AEM in Silverstone – Engine 3.5l VQ35DE V6 block bored to 96mm Tomei pro cams Brian crower valve springs and valve caps 3 angle valve seats Ported cylinder heads Skimmed heads (0.5mm) OEM full gasket set Polished and balanced crank Eagle h-beam rods Arp rod bolts Arp Head studs Cosworth 96mm 11.0:1 forged pistons ACL race main bearings ACL race big end bearings ACL race thrust washers New oil pump APS Plenum APS Sump Bosch 725cc Injectors Vortech V3 Supercharger More modifications – Additional Engine / Engine Bay Haltech Platinum Pro ECU FMIC Stillen Ceramic Coated Headers AEM water/meth injector with filter Wizards of NOS 75 shot system AMS Light Weight Pulleys (Except main pulley due to damping) Stage 1 FRS AAM Fuel rails Walbro 255 fuel pump Mishimoto fans and aluminium shroud Koyo radiator Nismo thermostat Nismo oil Cap Oil Cooler Power steering fluid cooler Spill's grounding kit Stainless Steel Coolant and Power steering pot Stainless Steel Bolts APS Strut brace (modified) Rare JDM harness cover (modified) Samco Hoses Decat Invidia G200 Exhaust Z-Speed under tray Transmission OEM 6 speed gearbox Carbonetic twin plate clutch Quick Shifter Torque Solution rear gearbox mount Braided Clutch line Suspension, Brakes and Wheels Braided Brake lines Ksport 6 pot callipers and 330mm disks rear D2 8pot callipers with 356mm disks front Tein Flex suspension all round with EDFC NISMO Front and Rear ARB's SuperPro / Whiteline adjustable bushes throughout Adjustable rear camber arms Rota Drift 18" wheels running Toyo 888's 275 rear 245 front for track. 19" x 11 RE30 Running 295 Rear & 18" x 8.5 RE30 Front Running 245 for road . GTSPEC 4 Point Mid Chassis Reinforcement Brace GTSPEC Rear Lateral Arm Brace GTSPEC Rear Lower Tie Brace GTSPEC Front Lower Tie Brace (Not Fitted) GTSPEC Fender Braces Interior Custom built centre console After market Head Unit with BT and SAT NAV 2x AEM Wide Band gauges AEM Fuel pressure gauge Saga Oil Temp gauge Saga Oil Pressure gauge Saga Boost gauge EDF Control unit Nismo throttle pedal NOS Control unit Water/Meth control unit 2 x 5lbs NOS bottles with heaters (stealth install) Custom warning light array Rising Sun Head Lining Green LED Lighting Exterior Shine Amuse Front Bumper with CF intake CF A Pillars CF Mirror Covers CF B pillars Nismo Version 2 rear wing Upgraded facelift rear lights (LED type) tinted Rolled arches Rear arch extensions Nismo Side skirts (replica) LX +1 Front wings Espirit rear bumper Limo tint rear glass Subtle green and black paint work. Again I will point out she is sold as seen, she is a race car and as such highly strung and demands a lot of attention, but treated right she does make you smile All the above including both sets of wheels for the bargain price of £ - SOLD Pictures – Dyno run with NOS Dyno without NOS Some pics of what she looks like on a good day Tha bad paint the bumpers - Rear Front bonnet Build thread - http://www.350z-uk.c...date-25th-july/ Any questions feel free to PM EDIT : Number Plate NOT INCLUDED! Edited August 15, 2014 by Keyser 1 Quote
SJ350z Posted August 6, 2014 Posted August 6, 2014 Wow didn't realise it was supercharged ! Looks like a lot of car for the money. GLWTS Quote
choptop Posted August 6, 2014 Posted August 6, 2014 Understand totally why you are looking for a new home for her. All the best with the sale Quote
Stutopia Posted August 6, 2014 Posted August 6, 2014 Wow, an iconic Zed for sale. Wish I had the brains to look after such a beauty, good luck with the sale. Quote
Humpy Posted August 6, 2014 Posted August 6, 2014 All the best with this mate and fingers crossed you get a quick sale Quote
GMballistic Posted August 6, 2014 Posted August 6, 2014 Great value when you consider everything done to this Zed. GLWTS Keyser. Quote
ChrisB Posted August 6, 2014 Posted August 6, 2014 This car and the build is the stuff of legend.. I'm sure someone will be made very happy very soon Quote
Wasso Posted August 6, 2014 Posted August 6, 2014 Feck me that's SUPER CHEAP!!!! A shame to see blood sweat and tears.......... From Bob........dissapear Good luck with the sale. I've had the pleasure of being a passenger and holy mother of god, if you WANT a quick car then look no further. Built from the ground up and the dedication to get the car where she is, 14k is under priced. I know, I know it may not be desirable to the normal customer, but you won't be dealing with a normal customer. Higher price I say. All the best with the sale Chris 1 Quote
BulletMagnet Posted August 6, 2014 Posted August 6, 2014 Offer incoming I think you will be probably the only one on here that would be able to appreciate and maintain The Bitch Quote
glrnet Posted August 6, 2014 Posted August 6, 2014 The do Feck me that's SUPER CHEAP!!!! A shame to see blood sweat and tears.......... From Bob........dissapear Good luck with the sale. I've had the pleasure of being a passenger and holy mother of god, if you WANT a quick car then look no further. Built from the ground up and the dedication to get the car where she is, 14k is under priced. I know, I know it may not be desirable to the normal customer, but you won't be dealing with a normal customer. Higher price I say. All the best with the sale Chris The doughnuts were at least a grand!! Quote
Tarmac@TarmacSportz Posted August 6, 2014 Posted August 6, 2014 I was nearly sick when I had a passenger ride in it !! That's cheap mate !! Parts alone are probably double that value 2 Quote
Keyser Posted August 6, 2014 Author Posted August 6, 2014 Thanks for the comments everyone Priced sensibly IMO given it needs a respray and tyres. Trust me it cost a lot more than that to build At Mr G - £1000 would not cover Bob's share of the doughnuts consumed 1 Quote
BulletMagnet Posted August 6, 2014 Posted August 6, 2014 I was nearly sick when I had a passenger ride in it !! That's cheap mate !! Parts alone are probably double that value Buy it and turn it into a Tarmacsportz marketing vehicle.It has Vortech, you sell Vortech... Then add the slogan on the side saying "The stuff we sell will make you S#!T your pants" 4 Quote
Grundy Posted August 6, 2014 Posted August 6, 2014 Buy it for me chris, I'll get the word out about your business even more #teamtarmac Quote
GT4 Zed Posted August 6, 2014 Posted August 6, 2014 🙀🙀 Shame the bitch is going and hope it goes to a good home but I suspect it maybe hard to sell despite the price due to being so individual. GLWTS But I think the vultures vultures are circling already for the big part out👀 Shameless dibs on the GT spec braces😈. Been on the cards for a long time but shipping has been the hiccup😖 Quote
WhackyWill Posted August 6, 2014 Posted August 6, 2014 (edited) That's a serious bit of kit for the money. Good Luck with the sale Buster. (Keyser) How can I get that SOOOO wrong..!! :scare: Edited August 6, 2014 by WhackyWill Quote
Keyser Posted August 6, 2014 Author Posted August 6, 2014 That's a serious bit of kit for the money. Good Luck with the sale Buster. Is Buster selling my car now as well??? I hate him he already stole my garage 1 Quote
WhackyWill Posted August 6, 2014 Posted August 6, 2014 That's a serious bit of kit for the money. Good Luck with the sale Buster. Is Buster selling my car now as well??? I hate him he already stole my garage I'm just getting my coat... :surrender: Quote
leonk Posted August 6, 2014 Posted August 6, 2014 Good luck with the sale Chris, I'm sure it won't hang about. Quote
Sam Mcgoo Posted August 6, 2014 Posted August 6, 2014 The amount of Man hours that went into this car was epic. It does seem to be cheap on the face of it, and will be a great buy for the right person. The need for a respray isn't a bad thing, they might even paint it a nice colour. Good luck with the sale Chris. 7 Quote
evilscorp Posted August 6, 2014 Posted August 6, 2014 Bargain! The build detail was outstanding on this car, someone is going to be very lucky/happy owner . . . . . (Once they change the colour =p ) 1 Quote
mouthwash Posted August 6, 2014 Posted August 6, 2014 You'll know if it's too cheap, it will be sold within a day to a certain vulture. Good luck, I've seen the car in the flesh and it's awesome Quote
