All Encompassing Wheel Size & Offset Thread
Jetpilot
 Share
Seems questions surrounding wheel & tyre size, offsets are frequently asked, so hoping we could start a wheel sticky of what members are using. Please no posts on theory, only experience of what you have, maybe an odd photo or two giving ideas of what they look like, mainly for offsets :)
Info is the key here, so, how about a template:
Wheel Size
Offset (front & rear)
Tyre Size
Lowered
Spacer sized if used
Arch work if necessary
Rear Camber
Edited by Jetpilot
I will kick off :)
Volk SF Winnings
Wheel Size 19 x 8.5 & 19 x 9.5
Offset (front & rear) Front ET 25 & Rear ET 17
Tyre Size Front 245/40/19 & Rear 275/30/19
Lowered Apex Springs
Spacer sized if used 3mm on front
Arch work if necessary No arch work
Rear Camber -1
Edited by Jetpilot
Wheel Size 19 x 8.5 &10.5
Offset (front & rear) Front ET 20=7 & Rear ET 35=20
Tyre Size Front 255/35/19 & Rear 295/30/19
Lowered tein super street coilovers
Spacer sized if used 13mm on front and 15mm on rear
Arch work if necessary rolled arches
Rear Camber -1
WHEELS..... Dare Hiro Dift
Edited by buster
Wheel Size 19 x 9 &10.5
Offset (front & rear) Front ET 20 & Rear ET 25
Tyre Size Front 245/35/19 & Rear 275/35/19
Lowered meister coilovers
Spacer sized if used 15mm on rear
Arch work if necessary rolled rear arches
Rear Camber -1
WHEELS..... Vertini drift
I will kick off :)
Volk SF Winnings
Wheel Size 19 x 8.5 & 19.5
Rear Camber -1
Got to be a typo on wheel size ?
Rota grid drifts
Wheel Size 19 x 9.5&10.5
Offset (front & rear) Front ET 20 & Rear ET 0
Tyre Size Front 235/35/19 & Rear 255/30/19
Lowered HSD Mono Pros
Spacer sized if used 20mm eibach rear spacers
Arch work if necessary rear arches rolled (no rubbing)
Rear Camber Lots
Edited by Pete87
Wheel Size - 19 * 9.5/10.5
Offset (front & rear) +22 all round
Tyre Size 255/35 & 285/35
Lowered Cusco coilovers
Arch work if necessary - Arches rolled
Rear Camber - A fair bit
Wheel Size - 18* 9.5/10.5
Offset (front & rear) +15 all round
Tyre Size 245/45 & 275/45
Lowered no
Arch work if necessary - none
Rear Camber - Stock
Wheel Size - F:19x9.5 R:19x10.5
Offset (front & rear) - ET20
Tyre Size - 245/35 - 275/35
Lowered - Teins (14/17mm)
Spacer sized if used - N/A
Arch work if necessary - N/A
Rear Camber - 1.5 degrees
  • Like 4
  • 2 months later...
Wheel Size: 9.5 x 18 fronts 10 x 18 rears
Offset (front & rear): ET12
Tyre Size: 245/35/18 fronts 265/35/18 rears
Lowered: -30mm on Apex springs
Spacer sized if used: 3mm on fronts to clear Brembo caliper
Arch work if necessary: None.
Rear Camber: 1.5 degrees.
Edited by oVerboost
  • Like 4
Wheel Size 18 x 10.5 front & rear
Offset (front & rear) ET 12
Tyre Size Front 225/45/18 Rear 245/40/18
Spacers 25mm rear
Arch work rolled arches
Rear Camber not measured or adjusted
  • Like 2
  • 2 months later...
  • 2 months later...
Hi all,
Apologies for the noob question I am having a problem finding wheels for my z roadster (w/brembos) while searching for various wheels I keep getting conflicting answers on fitting because if the offset.. For example the jade r 19"s x 8.5 and 9.5 some say will fit others say they won't... I'm looking for a nice set of 5 spoke maybe 6 but ideally 19's.. Plz can anyone help??
  • 2 months later...
As requested by a fellow member
ROTA GTR-D
Wheel Size - 18x9.5 & 18x10
Offset (front & rear) - ET12 Front and Rear
Tyre Size - 255/40/18 & 265/40/18
Lowered Roughly - 40mm-45mm - Meister R Zeta R + Meister R Rear Camber & Rear Toe Arms (Both arms necessary to keep Geometry safe) - Meister R Front Camber Arms (Not necessary)
Arch work if necessary - Significant rolling rear, minor front
Rear Camber - -2.8
Will swap for better photos soon
ROTA GTR-D
Lowered Roughly -30mm-35mm - HSD Monopro Coilovers - Hardrace Rear camber arms & Eibach toe bolts (Both Necessary)
Arch work if necessary - Minor rolling on rear - none on front
Rear Camber - -1.5
Edited by Desey
  • 7 months later...
That looks gorgeous! Can we see more pics?
What wheels are these? This looks perfect on 30mm springs. How do you find it for scraping over speed bumps???
  • 8 months later...
I think they are these:
http://www.rotashop.co.uk/rota-d2ex-18-10-5x114mm-et12-gunmetal-polished-lip-single-rim_p23344282.htm
 Share
