hi new to this just ran out of fuel
just ran out of fuel due to car light saying 40miles left just put in 10quids worth of fuel wont tick over at alll any advice is there a fuel kill switch or a certain amount of fuel your surposed to put in there to try get it to start ? cheers
Hi and welcome ,no kill switch you have simply run out of fuel and will need to turn it over a fair bit to pull it through ,i would avoid running the car so low if you can as never like to think i am running on the bits and pieces of dirt slopping around in the tank,the tenner is not realistically going to carry you far in a 350Z
cheers yeh i was literally about to fill it up :( i might go put more fuel into it give it a chance hopefully it ticks over
Yup fill her up mate and give her a good chance of recovering :thumbs:
Had this happen to me once in my VX220. It cut out at the top of a hill on this same bit of road there is two petrol stations, there is me thinking ooh you lucky bastard ill stop at one of these, well first one was closed as it was late, the second (24hr) had the cones out because the guy running the place was having a break :bangin::bang: needless to say I normally try to fill any of my cars up now when I have about 1/4 of a tank left.
With regard to it not starting like others have said it will be either pulling a load of crap through the tank, worst case is that you have clogged a fuel filter up or something and it cant flow properly. But you would have to turn it over a decent amount after letting it run dry.
I hope shoving more fuel in sorts her out without any other problems :thumbs:
flick the ignition on and off 3 or 4 times , that will prime the fuel system , then she will fire up all okay.
If the car wont idle and was showing 40 miles I doubt the car has run out of fuel but something else will be causing the non running /bad running problem.
i just had someone come check it apprently he thinks that it is something to do with the ecu as when i turn ignition on the fan comes on and he said this aint normal. anyone had any type of problems like this he thinks i will have to take to nissan get it diagnosed then see wat happens hopefully they just reset it which i read on a previous forum but not to sure any info would helppp cheers
You could try an ecu reset, it's in the guides section how to do it, although it doesn't sound like the sort of problem that will just reset. I f I were you I would disconnect the battery for tonight and give it another try in the morning.
Where abouts are you? We can suggest a specialist nearby to take a look if need be. ( not Nissan)
im in wickford essex mate and ok i will have to do that 2moro cause car at another place but hopefully it works just weird how i was driving thought it was cause of low fuel next thing i know the power just cut out
