Inevitable, going the FI way -= NOW DONE -= update 13/05/2013
Same spec but the one before it. Mine doesn`t have touch screen, it has a remote. Be warned though, I`ve had trouble with mine & PLX are VERY UNHELPFUL & DO NOT PLAY BALL WITH CUSTOMER COMPLAINTS. I have an issue with my control unit emitting some kind of signal that disrupts GPS aerials & the radio signal. When the unit is plugged in it reduces the signals massively. I`ve tried repositioning the device all around the car, different power sources & basically if its powered up within 2metres of the car the radio & GPS signals are affected :thumbdown:
I should hope that this is just a one off issue with my particular device, but with the lack of customer service & PLX being situated in the US I can`t easily knock on their door & hit them in the face with it. :angry: Personally from my experience with PLX I would NEVER buy anything from them again & would not recommend them to anyone. On the other hand it does do what it says on the box, apart from you can only organise daisy chained modules on the main screen. You can`t pull obd modules & mix them with an additional module. For example I wanted to monitor 4 sensors, Oil temp, water temp, afr & inlet temp(obd-2) You can`t add the obd sensor to the list.
Thank you, I'll have a think about it then, it's a shame...
Was the Cosworth Twin Plenum worth doing it in terms of power upgrade vs money spent - approx £900 from ZMANALEX? How much more power / whp after fitting it and remap?
Good post Adrian. Its already quite informative.
Let me know if I can help at all. If I can, I will.
Regarding the oil feed to your vortech - does it have the brass nozzle/Jet or is it stainless steel? If it is the brass one I would highly recommend getting the up-rated Stainless steel one as the Brass ones can crack. If it does you will run your charger dry and loose all your engine oil!
Luckily I noticed mine had a crack in it and was weeping while I was giving the car a service and caught it before it failed.
Stainless ones available from Superchargersonline.com
Thanks Sam!
I just need to decide what parts I need to get as per my original post, such as injectors, intercooler, oil cooler, etc
I got some ideas from what I've seen on the American forums, but we could always use the expertise available from UK people :)
If you have time going through my first post here, what parts are you using in your setup?
Thanks a lot!
Posted (edited)
Cjm stage 0, injecter dynamics 725s and walboro pump.
Just need the blower to match now.
Edited by OllyB
Hi, we use CJ stage 0 fuel system, 725cc ID injectors , walbro fuel pump, Uprev GT mad and 8 heat range spark plugs
To tune will take around 5 hours work.
I can supply all these parts and will upload a good start map to your ECU.
I would fit a greddy sump, 19 row oil cooler (Abbey will have a full oil cooler kit soon brackets/ducts and pipe work.
Any more questions ask away.
Posted (edited)
My set up is:
Vortech V2 Supercharger, Polished
3"33 pulley
Vortech Front mount Intercooler
Maxflow racing bypass valve
Kinetix SSV Inlet Manifold
Walbro 255 Fuel Pump
AEM 'Basic' Return Fuel System
Deatschwerks Injectors 600cc
Denso Iridium IKH22 spark plugs
Uprev GT MAF
Invidia G200 true dual exhaust
Japspeed Decats
JWT Oil pan spacer
Driftworks 19 row Oil cooler
Mocal 90 Degree Thermostatic Sandwich plate
Stillen Pneumatic engine damper
Catch Can
Custom CAI with K&N Air Filter and Breather Filter
Uprev Remap
AEM UEGO Wideband AFR gauge
Prosport Performance Boost Gauge
Prosport Performance Oil Temp Gauge
RSW Gauge pod
Edited by Sam Mcgoo
Posted (edited)
Hey Addy,
sorry I missed your call but this thread is very informative and would help anyone who is planning sc-ing or even those who have this installed.
Good you got the kit. I can't believe it didn't go sooner.
Eg the fitting advisory provided by Sam is invaluable and I will be addressing this when installing my kit.
From my research and talking with Mark @ abbey
This are my supporting parts list.
My kit.
Vortech V2 T trim tuner kit polished
2.87 pulley
I hope I have enough money left to pc the whole it black for stealthness :)
EXTRA PARTS:
1. FUEL RETURN SYSTEM
AAM Competition 350Z Stage 1 Fuel Return Kit
OR
AAM Competition 350Z Basic FRS
OR
CJM Stage 1 Return Fuel System Kit
OR
CJM Stage 0 Return Fuel System
I prefer CJM and going for the stage 0 will upgrade to stage 1 with dampers only if I go forged someday.
2. INJECTORS:
Injector Dynamics 725Cc
OR
DeatschWerks 600cc Top Feed Injectors
Mark uses both frequently but prefers the IDs so I'd go with that. I just hate that they are not plug and play like the DWs.
3. FUEL PUMP
Aeromotive Stealth 340LPH In Tank Fuel Pump with Setup Kit is my choice but the DW 300 pump is an option and the Walbro 255 should be fine.
4. INTERCOOLER:
Turbonetics Spearco 24x7.9x 3.5. For me.
Same height and core as the standard vortech cooler only 4 inches wider core. So will fit with retained crash bar.
5. OIL PAN SPACER
AAM COMPETITION 350Z ENGINE OIL PAN SPACER
OR
JWT JIM WOLF TECHNOLOGY OIL PAN SPACER W/ PORT 350Z
Either would be fine provide about an extra litre of oil and cheaper than the other fancy stuff. I have AAM.
6. 1 STEP COLDER SPARK PLUGS
HKS 50003-M40HL Iridium M-Series Super Fire Racing Spark Plugs
Ill go with these as Mark prefers them.
7. GAUGES - A/F, BOOST, OIL TEMP
Not a fan of any gauges other than OEM. Pointless. I'll rather spend more on a perfect tuning solution with active fail safes rather than watch passive gauges.
8. OIL COOLER WITH THERMOSTAT
Setrab 19 row cooler with Aeroquip -10 AN fittings and HEL -10 lines. Mocal thermostatic sandwich plate
9. OIL CATCH CAN
: http://www.350z-uk.c...sted-and-prov
Yup that's the one
10. LOW TEMPERATURE THERMOSTAT
Mishimoto stat.
11. UPGRADED RADIATOR:
Gone with Mishimoto with fans shroud and larger 12' fans.
12. FLUIDS
ENGINE:
Any fully synthetic oil will be fine. 5w30 or 5w 40
I stopped using Motul 300v too pricey. Been happy with Gulf competition (oilman recommended) with my oil cooler and lines and spacer I require 6.7l now and would expect to need about 7l factoring the SC and lines.
GEARBOX:
Redline MT 90 . Best for the GB. I have tried all! I'm about to try the Redline lightweight shock proof oil for anIy of track use protection. 2.9l needed
REAR DIFF:
Motul, gulf or silkolene. Used all no issues. 1.2L
13. OIL FILTER.
I hate the OEM vortech mushroom filter and would do the CAI mod like Sam mcgoo did but will use the Apexi cone filter.
Don't forget CLUTCH/BRAKES/COOLANT
Always used Motul RBF 660 and Motul coolant. All available from Opie.
14. ENGINE DAMPER
Stillen Dampener. My choice too. In galls to expensive. I also added the torque solutions transmission mount and make the gear action riffle precise and take away the OEM sloppiness. I'm sure the short shifter also helps.
15. STAINLESS STEEL CLUTCH LINE
I got HEL for about 2yrs now so no complaints. Cheaper to. CS stock these.
15.Cosworth Twin Plenum Inlet.
Personally I think it too much money for little benefit. I got a used Kinetic SSV for £300! MD plenum spacer would be ok IMO. Plus MRE2 for those with revup engines.
TUNING
MAF sensor :
MAF GT if tuning with Uprev.
I'm still to decide which tuning solution to go with. But I have to say I fancy the Syvecs S6. Just waiting on Mark to address the revup/ HR specific issue which should be surmountable :)
MISCELLANEOUS
I have gone for these for peace of mind. I'll add the links to these later.
- Replace all IC worm clamps with T bolt clamps
- Complete uprated Z1 motorsports silicon hoses kit.
- Pathfinder coolant mode.
- 928 BLV to limit my boost at my chosen target.
- Custom made "strafe auto" intake tube
- Fluidampr crank pulley
Edited by GT4 Zed
Just of the phone from a 3 hour conversation with Bennet / GT4Zed! Many thanks for the in-depth information, it really helped a lot! So excited, can't wait to start the project!
Thanks ever so much, Bennet, you're a big and important asset to this forum!
I will update the first post with the parts I will go for and we'll take it from there, as soon as you gather the rest of the information required!
Thanks again!
Have you booked in for the GTM yet Olly.
I can't remember were we left the converstion.
I see you made a start with the Dynamics Injectors 725cc
First post updated with the parts I'll be going for.
Some goodies from my current setup will soon be on the For Sale section, things like:
Berk Polished Intake Tube
ARC SuperInduction
Berk HFC
Any vultures around? :lol:
ARC SuperInduction
Berk HFC
I am sure they are circling, just waiting for the opportune moment :lol:
ARC SuperInduction
Berk HFC
Me, me, me :)
Posted (edited)
Here is my Spec including all supporting mods :thumbs:
Engine
3.5l VQ35DE V6 block bored to 96mm
Tomei pro cams
Brian crower valve springs and valve caps
3 angle valve seats
Ported cylinder heads
Skimmed heads (0.5mm)
OEM full gasket set
Polished and balanced crank
Eagle h-beam rods
Arp rod bolts
Arp Head studs
Cosworth 96mm 11.0:1 forged pistons
ACL race main bearings
ACL race big end bearings
ACL race thrust washers
New oil pump
APS Plenum
APS Sump
Bosch 725cc Injectors
Vortech V2 Supercharger 3.12 pulley
Additional Engine / Engine Bay
Haltech Platinum Pro ECU
FMIC
Stillen Ceramic Coated Headers
AEM water/meth injector with filter
Wizards of NOS 75 shot system
AMS Light Weight Pulleys (Except main pulley due to damping after lightened and balanced)
Stage 1 Fuel Return System
AAM Fuel rails
Walbro 255 fuel pump
Mishimoto fans and aluminium shroud
Koyo radiator
Nismo thermostat
Nismo oil Cap
Oil Cooler
Power steering fluid cooler
Spill's grounding kit
Stainless Steel Coolant and Power steering pots
Stainless Steel Bolt set
APS Strut brace (modified to clear supercharger)
Rare JDM harness cover (modified to clear brace)
Samco Hoses
Decat Invidia G200 True Dual Exhaust
up rated engine mounts
Z-Speed under tray
Transmission
OEM 6 speed gearbox
Carbonetic twin plate clutch
Kaaz limited slip differential (2 way converted to 1.5 way)
Quick Shifter gearstick
Torque Solution rear gearbox mount
Braided Clutch line
Suspension, Brakes
Braided Brake lines all round
Front - D2 8pot callipers with 356mm disks
Rear - Ksport 6 pot callipers and 330mm disks
Tein Flex suspension with EDFC
NISMO Front and Rear ARB's
SuperPro / Whiteline adjustable bushes throughout
Adjustable rear camber arms
GTSPEC 4 Point Mid Chassis Reinforcement Brace
GTSPEC Rear Lateral Arm Brace
GTSPEC Rear Lower Tie Brace
GTSPEC Front Lower Tie Brace (to be modified to fit)
GTSPEC Fender Braces
Wheels
Rota Drift 18x9 and 18x10 running Toyo 888's 245 and 275 respectively (for track)
Volk RE30 19 x11 and 18x8.5 Running Yokohama 295 and 245 respectively (for road )
Interior
Custom built centre console
After market Head Unit with BT and SAT NAV
AEM Wide Band gauges (two)
AEM Fuel pressure gauge
Saga Oil Temp gauge
Saga Oil Pressure gauge
Saga Boost gauge
Bride Brix II Seats and Rails
EDF Control unit
Nismo throttle pedal (still to be fitted)
Track Cam
NOS Control unit
Water/Meth control unit
2 x 5lbs NOS bottles with heaters (stealth install behind passenger seat)
Nismo Titanium gear knob
Custom warning light array
Green LED Lighting
Exterior
Shine Amuse Front Bumper with CF intake
CF A Pillars
CF Mirror Covers
CF B pillars
Nismo Version 2 rear wing
Upgraded facelift rear lights (LED type) tinted
Rolled arches
Rear arch extensions
Nismo Side skirts (replica)
LX Front wings
Espirit rear bumper
Limo tinted rear glass
Angry wife £0.00 in the bank account :lol:
Edited by Keyser
