just bought this zed so frustrated problem after preblem
Posted (edited)
TGM has really good reviews, lots of people on here vouch for them.
I think the guys name is Tom you need to speak to - knows Zeds very well.
Edited by coldel
thanks guys :)
I will be at AC Mechanical tomorrow around 12 if your down there for a quote.
They are fitting my compression arm bushes!
To test the fan motors, wait until the water/coolant is hot and give the centre of the fans a tap. If they kick into life then the fan motors are shot and need replacing (get them from Zmanalex as he's far cheaper than Nissan).
Posted (edited)
guys does anyone know a local garage who knows these cars inside out ? im in reading berkshire
Horsham developments are near you i Think
Yup - just off J13 of the M4 :)
Did I speak with you today? Some one called about radiator fans - in stock if you need them.
Edited by Jez
yes it was and thanks for all the help guys it was the cable that plugs into the fans went faulty somehow so my electrician has sorted it :)
Good news :thumbs:
  • 1 month later...
If your water is not circulating in the rad does that not mean the water pump is knackered?
See post 32 on the previous page. This was sorted 21/12/12 .
It's always worth reading a thread before replying. :wink:
could well be air trapped in the cooling system, they can be an arse and get coolant filled up right. in some cases people have found that jacking the rear right up when re filling the coolant helps get all the air out.
Wouldnt you jack the front up?
JAck the back up if using the bleed screw or jack the front up if using a spill free funnel with the rad cap removed.
