Little Headlight Project
stu1986
Hi all
While my car is in the bodyshop having a few bits done and the headlights were already removed I thought Id do a little project on them, I was looking for another set to practise on but after I found out the price for them I decided to bite thew bullett and go for it on my own ones so here goes......
Before
The Headlight lens was then split for the main unit by placing in the oven to soften up the mastic
The Headlight lens was then split from the rest of the shell
Holes were drilled in the appropiate places
The rest of the shell was dismantled and sprayed satin black
Once complete the shell was rebuilt
White LEDs were prepared using resistors and heatshrink
LEDs were then placed in the holes drilled and glued into place
A simple test to make sure they were all still working using a battery
The lens was screwed back together
LEDs on with Lens
I also purchased some Super bright LED Sidelights and some LED Indicators with resistors that will be fitted Front and rear
The Headlights are now ready to be put back together, I will be having to brightness's on the lights 100% when the lights aren't on, and once they are on they will dim down to around 25%
More updates coming soon!!
That looks very sexy indeed........wish dreamzcustoms were still running as I would be asking them to do my headlights.
Do it yourself much more fun :smile:
Dont trust myself dude
+ Dont forget your Scottish :lol:
Look very nice B)
UPDATE - 17/12/2012
Now everything has been done it was the final stages of getting the lights back together.
One the car was back from the body shop it was time to fit them and do the wiring
The wires for the two sides went into a grommet to go into the cabin on the left hand side (looking from the front)
Wires them came out in the drivers footwell
The LEDS would come on once the ignition was active I them spiced in to on of the blue wires going to the fuse box
I then placed an inline blade fuse just in case and was then all sorted :D
I know its not to everyones taste but I like it
For more pictures of my car what she looks like now go to my car thread
http://www.350z-uk.c...0z-lots-of-pics
