Luke350
My new nismo! Couple of queries/problems if someone could answer?
Here’s some pics of my new ‘18 nismo in storm white! But got a few small problems.
I can hear a rattle quite loud when the windows open. Sounds like a heat shield type rattle. Anything common that can rattle on these?
As I pull off, there’s about half a second where the exhaust sounds a lot louder and deeper then goes back to normal.
Then I need to call Nissan up and tell them my tacking is out, the steering wheels point left a little when straight.
And is the biting point quite high on the nismos? Mines right at the top and don’t want the slave cylinder problem happening. Can this be altered?
Share this post
Link to post
Hi mate. Have a 2016 Nismo and don't have or have never had any of your issues. I would say that the stock exhaust needs replacing as its the one thing that lets the car down. I had the ARK Dual Grip on my 350z and have it on my Nismo. Perfect look and sound for the car. I am assuming the delivery blocks have been removed from the springs ?. Would get the alignment checked as it sounds off. Not sure about your rattles. Biting point is a little higher but I am not sure what you are used to driving. In comparison to a 350z its not that different. Maybe see if you can cross check it with another 370z at the dealers if they have one.
Share this post
Link to post
Hi Luke,  I have an 18 plate Nismo and no issues at all. Alignment  - seek out a garage that has the Hawkeye system and get it checked as Payco advises above.
That aside - you'll love the car.
Share this post
Link to post
Great. Thank guys. Springs are clear of transit clips. I think the release bearing is going on it too :( loud whining that goes as soon as I press the clutch. Done less than 9k. Starting to take the excitement of the new car away now. Its less than 12 months old so I’m hoping they’ll just sort it all, or they’ll have me constantly moaning to them for the next 2 years of warranty!!
Share this post
Link to post
Japanese cars are known for noisy clutch release bearings but yeah mine is the same. Quick Google says its a characteristic of the 370Z. Wouldn't worry too much.
Share this post
Link to post
8 minutes ago, Silverthorn said:
@Luke350 Mine has had a slight whine ever since I've had the car. I just think it's the nature of the car to be honest.
Check the wife isn't in the passenger seat.:stir:
  • Like 2
  • Haha 2
Share this post
Link to post
Certainly get these things checked out on your warranty but sounds like your ears are a little sensitive to little noises etc
All 370s make the noise you talk of when going on and off the clutch ...well both of mine have anyway.
Get the issues checked out and if its all good get out and take no notice enjoy the car
The 370 definitely isn't a silky smooth quiet car they have all sorts of squeaks and rattles and agricultural noises
Share this post
Link to post
Great. Thanks all for your help. It goes in next week for alignment and rattle issue. I’ll see what they say.
Share this post
Link to post
Well, you’re all too positive here :lol:
it needs a new clutch and flywheel!!
Rattle was a loose brake calliper
wheel alignment getting sorted.
turns out there was a gearbox leak that fit into the clutch and caused damage. A bit worrying with less that 9k on the clock. So 12 months old and getting new clutch and flywheel!
Quick question. It’s an ‘18 plate, so should the new clutch be the exedy one? (it’s what they would have taken out) Or could they chuck an older one in and I’d never know? Thinking is it worth me requesting it to be an exedy.
Share this post
Link to post
2018 Nismo 370z should have the exedy clutch fitted when new as it was an upgrade on earlier 370z Nismo. Replace with the same is my advice.
Edited by Payco
Share this post
Link to post
Hope its all free. These defects possibly symptoms of abuse. This an ex demo? I dont know about Nissan but the oil leak in gearbox happened to me with an Audi A3 pushing to the redline uphill! Needed new clutch and flywheel as well as a hole sheered in the gearbox casing causing oil to leak onto the clutch/flywheel causing it to slip. £1000 all in! New box and clutch/flywheel
Might just be one of those things! But this car should be able to handle it
Edited by GranTurismoEra
Share this post
Link to post
Ye I definitely want exedy to be fitted. But will they automatically fit the exedy with it being an 18 plate? Or do you think I should specify so they don’t just put any in?
Share this post
Link to post
Salesman said it was the directors car for 6 months. But I suspect it was a demo car with that kind of wear to the clutch. Either way, if it all gets put in new, that’s great. Thanks incompetent test drivers :lol:
Share this post
Link to post
If it’s a main dealer you will no doubt have to tell them. It should be like for like so they should replace the exedy  with an exedy. Don’t accept anything less.
Edited by Payco
Share this post
Link to post
Its Nissan, Insist on it being the Exedy. They cant really say no as the model year is 18.. I had the 17. That clutch isn't great. Mine was slipping at times.
Share this post
Link to post
Ill PM you
Share this post
Link to post
Westway aren’t replying to emails I’ve been sending since 18th. Can’t call them to request the exedy clutch as I’m in sunny jamaica. If they end up fitting the wrong clutch, and just try to say it’s the right one, is there a way to visually check the clutch to see which it is?
Share this post
Link to post
I would also request photos of the new clutch as proof of what they have installed, I wouldn't trust the main stealer, I got ripped off by them years ago, I wouldn't go to Nissan not even for a dust cap :rant:
Edited by ShortPaul
Spelling
  • Like 2
Share this post
Link to post
If you are really concerned then suck up the cost of a call from Jamaica and phone them! Alternatively if you have internet then download something like Skype and call using that. Or check if Westway have internet chat.
Share this post
Link to post
Loading...
350z-uk.com
370z-uk.com
350z-uk.com
370z-uk.com
