Posted (edited)
Hi Guys
You may have seen this already, its took a long time to make this happen but the end results are pretty stunning.
FRP - Strosek style rear spoiler, comes un painted
Black aluminum brackets which fit to the OEM spoiler, you must have an OEM spoiler to fit this too, I have a spare used one if required.
Currently have just 1 available so contact me if you want to order and I will check availability at the time
Here are some pics on one of the nicest 350z's on the Forum:
Quote on fitting from customer:
OEM spoiler was left in situ and drilled through and bolted on from inside the boot, when you remove the rear plastic there are four holes, the two centres ones giving you access to the front bolt position, holes needed to widened slightly to get the rear bolts in. 50 mm bolts to attach are required.
https://www.tarmacsportz.co.uk/interior-and-exterior/350z-frp-strosek-style-rear-spoiler.html
Edited by Tarmac@TarmacSportz
  • Like 5
Looks great, Im just not a fan of mounting it to the standard spoiler.... can this be mounted to the bootlid instead?
Nope, it won't sit at the right angle
That's a shame as I this is the only rear spoiler I would consider ...... Sure it wouldn't be hard to have some Ali blocks made up at the right angle .....
Thats a shame
Agree
So how does this fit chris ? I guess you have to take the original spoiler off then fit it to it , and then refit the original ?
  • 4 weeks later...
  • 3 weeks later...
Very tempted by one of these after I get a rear diffuser in the new year :D
Recon it will work well on stock body with GT lip, Tarmac skirts, Tarmac rear diffuser, Rays, or would it need a more aggressive kit to pull it off?
Sent from my iPad using Tapatalk
I'm sold after doing some research on them. Hope you don't mind me posting these Chris, may help with some sales for those undecided on mainly stock body cars.
I'll be in contact in the new year for diffuser and one of these :thumbs:
  • Like 2
I should have mine fitted and painted next week, I'll post pics when it's done :teeth:
Look forward to the pics :D
  • Like 2
