WhackyWill Posted February 6, 2013 Posted February 6, 2013 What a stupid dipstick there is in a Zed.. need to be a Brain Surgeon to get it back in the hole..!!! Quote
ATTAK Z Posted February 6, 2013 Posted February 6, 2013 The guy who designed the dipstick on a 350 Z was a dipstick Husky 2010 Quote
Adrian@TORQEN Posted February 6, 2013 Posted February 6, 2013 REEEEEPOOOOOST! :lol: I hate it, too!!! Hard to read as well Quote
Paddy78 Posted February 6, 2013 Posted February 6, 2013 Are there any alternatives on the market? Quote
rtbiscuit Posted February 6, 2013 Posted February 6, 2013 Are there any alternatives on the market? there is the dry sump method. basically you leave it till the engine spits a piston through the bonnet, then you know its time to top it up again, 1 Quote
Paddy78 Posted February 6, 2013 Posted February 6, 2013 Are there any alternatives on the market? there is the dry sump method. basically you leave it till the engine spits a piston through the bonnet, then you know its time to top it up again, On second thoughts, the current method seems ok! Quote
rtbiscuit Posted February 6, 2013 Posted February 6, 2013 its not that hard to read, but its best done on a cold engine on a flat surface, and you have about 2 dips in the pipe before it starts to smear up the tube. as for putting it in, it just takes practice thats all. i didn;t find it that difficult. Quote
WhackyWill Posted February 6, 2013 Author Posted February 6, 2013 Dry sump sounds expensive as does not checking your oil... Quote
SimonPG Posted February 6, 2013 Posted February 6, 2013 I find the entire thing gets covered in oil.. bloody hard to read what the level is!? Quote
S1 HNK Posted February 6, 2013 Posted February 6, 2013 I find the entire thing gets covered in oil.. bloody hard to read what the level is!? As said its not hard to read at all if you let the oil go totally cold. If its even slightly warm then yes the oil is all over the dipstick but when totally cold on a flat surface its very clear where the oil level is. Quote
SimonPG Posted February 6, 2013 Posted February 6, 2013 I find the entire thing gets covered in oil.. bloody hard to read what the level is!? As said its not hard to read at all if you let the oil go totally cold. If its even slightly warm then yes the oil is all over the dipstick but when totally cold on a flat surface its very clear where the oil level is. Ah great, i'll check it tonight then! Although.. finding where to put it back in the dark.. hmmm Quote
rtbiscuit Posted February 6, 2013 Posted February 6, 2013 i find first thing on a morning is good, the oil has had 12 hours to cool, and usually on a crisp winter morning, the oil is even thicker due to the low temps. Quote
JetSet Posted February 6, 2013 Posted February 6, 2013 Don't even attempt to remove it when its dark or even in twilight unless you have a decent torch you'll never get it back in. Later models, 2007 onwards have a normal dipstick. Pete Quote
WhackyWill Posted February 6, 2013 Author Posted February 6, 2013 I agree with JetSet...dont attempt to remove it in the dark.. bad enough in the day even then you still need a torch to find the hole. :thumbdown: Quote
RickyZ Posted February 6, 2013 Posted February 6, 2013 I find the entire thing gets covered in oil.. bloody hard to read what the level is!? As said its not hard to read at all if you let the oil go totally cold. If its even slightly warm then yes the oil is all over the dipstick but when totally cold on a flat surface its very clear where the oil level is. Good tip, I live on a hill so have to drive somewhere flat to check the oil properly but it warms up a bit and is tough to read. Just checked at work (level carpark) and the level was clear as day Quote
Gonzo88 Posted February 6, 2013 Posted February 6, 2013 I'm guessing this isnt an issue on the HR engine as its located in a different place? Quote
DaddyCee Posted February 7, 2013 Posted February 7, 2013 Don't even attempt to remove it when its dark or even in twilight unless you have a decent torch you'll never get it back in. Later models, 2007 onwards have a normal dipstick. Pete really? I have an 07 plate 350z and the dipstick still has that kink and readability factor is zero on the damn thing. Quote
smudgedon Posted February 7, 2013 Posted February 7, 2013 I've never had a problem with finding the hole for my dipstick The one on the car is a bit tricky however Quote
NeilMH Posted February 7, 2013 Posted February 7, 2013 I've never had a problem with finding the hole for my dipstick The one on the car is a bit tricky however I've never had a problem with finding the hole for my dipstick The one on the car is a bit tricky however In which case you may want to help Dip with finding a hole for his Quote
smudgedon Posted February 7, 2013 Posted February 7, 2013 I've never had a problem with finding the hole for my dipstick The one on the car is a bit tricky however I've never had a problem with finding the hole for my dipstick The one on the car is a bit tricky however In which case you may want to help Dip with finding a hole for his I don't like to touch other peoples cars, let alone their dipsticks Quote
The Bounty Bar Kid Posted February 7, 2013 Posted February 7, 2013 I've never had a problem with finding the hole for my dipstick The one on the car is a bit tricky however I've never had a problem with finding the hole for my dipstick The one on the car is a bit tricky however In which case you may want to help Dip with finding a hole for his I don't like to touch other peoples cars, let alone their dipsticks I was wondering when I would get pulled into this thread! Quote
Builder49 Posted February 7, 2013 Posted February 7, 2013 Go to specsavers guys, its not that hard in good light, but i agree the oil needs to be cold. Quote
glrnet Posted February 7, 2013 Posted February 7, 2013 I've never had a problem with finding the hole for my dipstick The one on the car is a bit tricky however I've never had a problem with finding the hole for my dipstick The one on the car is a bit tricky however In which case you may want to help Dip with finding a hole for his I don't like to touch other peoples cars, let alone their dipsticks You've been reading too much SMD smudge Quote
