New 370z owner
Welcome to the forum :thumbs:
As the car is still under warranty I would get yourself along to a decent Nissan dealer to sort the problem. Best to go to a HPC centre really ;)
If you post up whereabouts you are (or add it to your avatar) someone local can advise
Just had a new roof fitted today on my convertible along with its first service.
Had a small wear mark on the side, the roof had been hitting a mounting when the roof folded away.
Got it done under warranty and the garage seem to have done a good job, had the car for three days.
Have some pics somewhere will post up if it helps?
the problem with the roof, and I think this is a design fault, is that the edge of the window catches on the roof fabric, there should be the rubber seal around the window and then at a uniform distance the roof fabric, so as you open the door, the window drops and the edge of it catches the fabric as you pull the door open,. On mine this has pulled the fabric away from the narrow stitching (and has frayed). This is in the hands of nissan warrenty. But i went to a dealer and had a look at a brand new car and the passenger door on that one does the same . I thinkthis is a design fault and I think Nissan may have a serious problem with it. Unfortunately I have looked at BMW and Mercedes roofs and you dont get this problem as the roofs are perfectly 'carved', but maybe this is a problem buying a Nissan. One person said the window does not 'drop' quick enough before you pull the door out. Please checvk your doors on yours 370Z roadsters and see if they catch..
When I went to the dealer and told them I wanted a new roof putting on I mentioned that I had read on forums in the states that people had, had bad / shoddy work done and had to go back with the roof for it to be corrected. Dealer was very good said the GTR specialist would do the work.
Must admit I was apprehensive going to pick the car up but on the face of it, it looks like the roof when new. Fitment looks good and tried the roof a couple of times and appears to work ok and all fits back into place.
I am going to have a good look round it this weekend just to make sure.
I am sure that I read on the US forums that Nissan had issued a TSB re the door catching the roof on the edges and that there was a fix for this.
Nissan should sort the problem out under warranty, had no issue with my claim.
diversifying for a moment, in the boot well, where once a spare tyre was present, there is a rectangle storage section, I am assuming that it is storage, if not then something else should be there, so can I ask if all your boor wells have this empty space, and really what is it for?
If you look on the US forums you'll see the vast range of stuff you can find in the boot in different countries. They've basically made the cutouts so they can store everything that each country where the 370z is sold can fit. In the US they get the spare tyre, but in this country its not mandatory so we get a can of tyre weld and a bit of a hole left where the wheel is. If you have Connect Premium you'll find the BOSE sub where the wheel would be as Lee says.
You lot have been done - I've got a spacesaver in my 370 :teeth:
Its a 350 spacesaver - fits the well once the foam fill is removed and the Bose sub fits inside the wheel.
Jack and handle added and I also carry the torque wrench (you can see in the pic) for peace of mind. Fronts need 20mm spacers for the 350 spacesaver to fit over the 370 calipers but straight fit on the rear but as I run with the spacers on - no issue for me there.
Theoretically, if you got a front puncture you could put a rear wheel on the front (I have tried it and it works without fouling anything) and the then the spacesaver on the rear as an emergency get you home job but would not recommend it - carrying a spacer would be much better.
Yeah, I know about the extra weight but like Lee I would rather have a wheel to get me home, than rely on the puncture being a tiny hole that the gel supplied might fix but then I gather is likely to render the tyre u/s even if the puncture could be repaired.
Only reason the gel is still there is for when I come to sell the car, without the spacesaver most likely. The pump I find really good for the odd topping up, as invariably garage air machines are out of action :thumbdown:
