magrillz Posted May 19, 2009 Posted May 19, 2009 As some of you will know I got myself a 350z Coupe 3 weeks ago. Over the moon with the car in fact it’s even better than I imagined. One quick question, I have noticed that when the engine/gearbox is cold 2nd gear seems a bit clunky. It’s quite stiff going from 1st to 2nd and also makes a bit of a clunk when it goes in. I almost feel like I’m forcing it which I’m guessing isn’t good. The cars only done just over 4k and is a 58 plate. Also as the car is cold I’m only taking it easy at this stage. When the car is warmed up nicely it doesn’t do it. Is this just a characteristic or do you think I should get it checked out? As usual, thanks in advance Quote
martinmac Posted May 19, 2009 Posted May 19, 2009 Its pretty normal bud, they are a bit clunky when cold. Nothing to worry about Quote
magrillz Posted May 19, 2009 Author Posted May 19, 2009 Thanks for the fast response guys. Thought it best to ask here first as don’t always trust the dealers. You never know when your being fobbed off! It’s absolutely fine when warm so sounds like the same. Nice one! Quote
Trev-the-Rev Posted May 19, 2009 Posted May 19, 2009 Totally agree with what has already been said. A slight pause when you pass through the neutral position will prevent this from happening. Quote
magrillz Posted May 19, 2009 Author Posted May 19, 2009 Totally agree with what has already been said. A slight pause when you pass through the neutral position will prevent this from happening. I'll give it a go, cheers for that Quote
200sx Posted May 19, 2009 Posted May 19, 2009 Every 'performance' car I have driven is the same. I guess its something to do with the type of syncro-mesh used. Nothing to worry about as long as its ok when it gets warmed up. Quote
fatalus Posted May 19, 2009 Posted May 19, 2009 Mine does exactly the same too! As said, little pause in neutral helps. Everything gets smooth after a couple of minutes! Quote
JDM Lover Posted May 19, 2009 Posted May 19, 2009 I've had the same problem with my 06 JDM ever since I got it - thought it was just mine, phew Quote
IanS16 Posted May 19, 2009 Posted May 19, 2009 Mine does it occasionally even when warm. Just have to put up with it. Quote
M350ZB Posted May 19, 2009 Posted May 19, 2009 Every 'performance' car I have driven is the same. I guess its something to do with the type of syncro-mesh used. Nothing to worry about as long as its ok when it gets warmed up. +1 , but allways let it warm up before you give it some beans Quote
Greekman Posted May 19, 2009 Posted May 19, 2009 Mine was quite bad at first...its 58 like yours....after 17000miles it has loosened up and its ok (most of the time) even when its cold now... Quote
GT4 Zed Posted May 21, 2009 Posted May 21, 2009 Had exactly the same problem and always prewarmed the car (5-10mins) before starting off in the morning which did the trick. However since changing the gear oil with motul gear 300 at P3, no more notchiness except on really really cold mornings when I resort to a prewarm and the overall change is very slick now Quote
M350ZB Posted May 21, 2009 Posted May 21, 2009 Intresting to see the change in oil has made a difference, due a oil change soon Quote
busa1300 Posted September 19, 2010 Posted September 19, 2010 Ive just put some Red Line 75w90 gear oil and now smooth gear change when cold from 1st to 2nd, on a side note when i went to nissan to get a new drain plug gasket i said you will have them in stock because of the p3 service, he said then don't change the gearbox oil on a p3 only every six years and that is only an option too. Kev Quote
Vik54 Posted September 19, 2010 Posted September 19, 2010 Ive just put some Red Line 75w90 gear oil and now smooth gear change when cold from 1st to 2nd, on a side note when i went to nissan to get a new drain plug gasket i said you will have them in stock because of the p3 service, he said then don't change the gearbox oil on a p3 only every six years and that is only an option too. Kev That's kind of correct....basically gear box oil change is optional full stop...most (unless they're tracking their cars or driving very hard) just leave well alone Quote
andlid Posted September 19, 2010 Posted September 19, 2010 Ive just put some Red Line 75w90 gear oil and now smooth gear change when cold from 1st to 2nd, on a side note when i went to nissan to get a new drain plug gasket i said you will have them in stock because of the p3 service, he said then don't change the gearbox oil on a p3 only every six years and that is only an option too. Kev Got some redline for my box too, must say that I think it's a bit clunky when cold but once warmed up 100% spot on, thinking on getting nissan oem oil for my next swapout and think Zman recommended to use some other stuff in the box might give that a go. Quote
un1eash Posted September 19, 2010 Posted September 19, 2010 I was concerned about this too when i first got my car, when warm its alot better but when cold you have to exaggerate the first to second gear change. Quote
doctor austin Posted September 19, 2010 Posted September 19, 2010 Mines the same too, but when cold I 'double de clutch' only really notice it on cold mornings for the first or second change. Quote
Androo Posted September 21, 2010 Posted September 21, 2010 on previous cars i've had, that was always the tell tale story that the gearbox oil needed topping up / replacing I think i read somewhere that you "just" put x volume in - there isnt a way of checking (ie when it starts to fall out the level drain plug) - maybe theres quite a few out there that are low on oil? (or need a top up) When i had it previously, it was horrible in the cold - changed the oil and bingo - all was well and good Mines funny in 1st - 2nd, so was thinking about getting it changed at next service to see if my babble is true Quote
350 Russ Posted September 21, 2010 Posted September 21, 2010 Is it only ever 1st and 2nd that's it's clunky in? Mine sometimes gives a little crunch when going into 3rd when cold if not put in slowly Quote
busa1300 Posted September 21, 2010 Posted September 21, 2010 Just remember if you are going to do it yourself you will need a small hand pump to get the oil in because the level/fill plug is quite high and awkward to get to. Kev Quote
