Renegade Posted December 27, 2014 Posted December 27, 2014 I bought a rear alloy from ebay so I could get my rear wheel painted as it is getting the usual bubbles. The advert stated. Alloy is without any buckles. I have already requested a return What do you guys think is it bent ? I have never seen a 350 rear damaged before. Quote
WhackyWill Posted December 27, 2014 Posted December 27, 2014 Its as bent as Elton John... :lol: 1 Quote
StevoD Posted December 27, 2014 Posted December 27, 2014 (edited) advert might be right thats not buckled it dented hard to tell from pictures If its buckled its got a dent as below ie flat spot bent inwards or i would bet 80% of 350z wheels would be similar to yours hence why all wheels end up with weights as the wheels do naturally deform on the road , only way around it is buy a new one, also the two measure tape pictures might be the angle taken from but looks like the tapes held at different angles which will make it more different than it is take it to a garage and see how many weights it would take to run true can you get a picture from infront and behind the face like the image above Edited December 27, 2014 by StevoD 1 Quote
Ekona Posted December 27, 2014 Posted December 27, 2014 Must admit, I can't see anything obvious either, but that just be me. Quote
spursmaddave Posted December 27, 2014 Posted December 27, 2014 (edited) Can't see too much wrong either, don't understand the mention about Elton John, unless I have missed something he is a massive bender and the wheel looks ok.... I would say it is more like David Walliams, you may just think it's bent.... Edited December 27, 2014 by spursmaddave 1 Quote
LRF4N Posted December 27, 2014 Posted December 27, 2014 Can't see it's bent from the pics above? Agree with Steve that the tape measure doesn't look like it's been held straight. Not sure that would add half an inch tho Quote
StevoD Posted December 27, 2014 Posted December 27, 2014 Can't see it's bent from the pics above? Agree with Steve that the tape measure doesn't look like it's been held straight. Not sure that would add half an inch tho that what i thought but when you look at the white stuff on the alloy the tapes been moved maybe 10-20mm up between photos if there an extra inch there over 10-20mm would stand out like a sore thumb that doesnt well not to me Quote
ZEUS Posted December 27, 2014 Posted December 27, 2014 Bolt it to a hub, spin it and measure the run out. You can't tell properly by looking at it . Quote
Renegade Posted December 27, 2014 Author Posted December 27, 2014 I used the tape as a guide,over an area of around 200mm there is a 5mm narrowing. If you look at the outer and inner lip beneath the tape you can see it closing in. Plus the outer lip that usually gets scraped has been hammered and filed flat, and is very uneven. Seller has accepted it back. Quote
ATTAK Z Posted December 27, 2014 Posted December 27, 2014 That wheel is/was bent ... I can't understand how people cannot see that ... it is blatantly obvious ... there's a 10+ mm difference in width at the two points (assuming that the end of the tape is located correctly on the other rim) Quote
StevoD Posted December 27, 2014 Posted December 27, 2014 (edited) That wheel is/was bent ... I can't understand how people cannot see that ... it is blatantly obvious ... there's a 10+ mm difference in width at the two points (assuming that the end of the tape is located correctly on the other rim) Bent and buckled are two different things Also look where the tape is its 10mm above the other if it's grown an inch over 10mm of the circumference the rim would look a lot worse than that it would have a spike on it Edited December 27, 2014 by StevoD 1 Quote
gsexr Posted December 27, 2014 Posted December 27, 2014 The first picture shows the wheel on a flat surface and its clearly not true. Whatever words were used to describe it the intention was to give the impression that there is nothing wrong with the wheel which is not correct. Get it returned mate. Usual thing of ebay is that half the people selling stuff don't know what they are selling, They could`nt tell a good one from a bad one. Secondhand stuff has always been like this with sellers just taking a chance. Quote
LRF4N Posted December 27, 2014 Posted December 27, 2014 (edited) Is it just me or in the first photo the edge of the wheel is off the edge of whatever it's sitting on. So you can't get a good idea of what it's like Viewing on my phone so hard to tell Edited December 27, 2014 by LRF4N 1 Quote
Renegade Posted December 27, 2014 Author Posted December 27, 2014 Its sat on a sheet of perspex on top of the tumble dryer. Rest of the wheel sits flat you can see the gap under the wavy lip. Quote
ATTAK Z Posted December 27, 2014 Posted December 27, 2014 Its sat on a sheet of perspex on top of the tumble dryer. Rest of the wheel sits flat you can see the gap under the wavy lip. I see it ... that wheel has had a bash ... it looks like somebody has had a go at straightening it ... you were right to reject it Quote
Keyser Posted December 27, 2014 Posted December 27, 2014 (edited) I think the issue is the difference between bent and buckled - as in the pic above (StevoD post) that is buckled yours appears to have a "bent" rim - heavy curbing will do that and you can argue therefore that the rim is buckled so you could certainly ask to return it and see what happens. The other side to it is that a buckled wheel is hard if not impossible to repair a "bent/buckled" rim can usually be repaired quite easily by most wheel specialists, although as said above a lot of wheels are like this will still take a tyre and hold air and can be balanced so if it is not noticeable with a tyre on could be used as is. Not telling you what you should or shouldn't do just trying to help I hope you get a suitable solution as quickly cheaply and painlessly as possible Edited December 27, 2014 by Keyser Quote
Renegade Posted January 1, 2015 Author Posted January 1, 2015 (edited) The outcome of this was. I sent it back on Monday at the buyers expense, I got a refund a little while back Edited January 1, 2015 by Renegade Quote
chrisday1990 Posted January 3, 2015 Posted January 3, 2015 It looks quite bent for something your about to put on a performance car, a ford transit without motorway miles maybe. The outer flange looks bent so if you hit a corner hard and loose tyre compression.... hedge. Quote
