stichy Posted November 22, 2009 Posted November 22, 2009 my windscreen washers have stoped working, the rear still works fine? any ideas?? and yes there is water in the washer bottle Quote
givememorepower Posted November 22, 2009 Posted November 22, 2009 Simple. Pull the hoses off the injectors and see if water comes through when you hear the motor turn. Quote
marzman Posted November 22, 2009 Posted November 22, 2009 Will be a £2 non return valve from halfords. Open the bonnet, remove the brake fluid cover, reach under and unclip the pipes. There will be 2 valves under there - a Y shaped valve and a non return valve. It is usually this piece which gets blocked. Quote
stichy Posted November 22, 2009 Author Posted November 22, 2009 thanks mate will have a look tomoro Quote
Pimm Posted November 22, 2009 Posted November 22, 2009 Will be a £2 non return valve from halfords. Open the bonnet, remove the brake fluid cover, reach under and unclip the pipes. There will be 2 valves under there - a Y shaped valve and a non return valve. It is usually this piece which gets blocked. +1 Been there done that Quote
stichy Posted January 23, 2010 Author Posted January 23, 2010 still not working? but i cant hear the pump going. is there a fuse for the front washers? i cant see one on the fuse box layout. Quote
Stew Posted January 23, 2010 Posted January 23, 2010 The pump not going for the front but is working for the back????? Quote
chocohercules Posted October 27, 2010 Posted October 27, 2010 I too have the same problem, did you find out what it was? where is the fuse location for the front washer jets for the windowscreen? Quote
Darren-B Posted October 27, 2010 Posted October 27, 2010 I too have the same problem, did you find out what it was? where is the fuse location for the front washer jets for the windowscreen? Drivers footwell Quote
bigmike20vt Posted May 11, 2012 Posted May 11, 2012 Hi my front and rears are not working (again!) it happend about 6 months ago then fixed itsself. the headlight washers are fine however. is this still likely to be one of the valves? cheers edit.. damn i blindly replied to a search (at least i did a search) i just realised this is the import section, mine is a uk car though i imagine they are the same thanks Quote
Tackleberry Posted January 6, 2014 Posted January 6, 2014 Thread Resurrection! I have this issue, i do not have a non return valve as i replaced with a straight through piece of copper pipe. HAs been working fine but suddenly stopped working. The pump is not firing up when you pull on the windscreen washer stalk in the car. Is this a fuse? was the fix ever found? Quote
cs2000 Posted January 6, 2014 Posted January 6, 2014 Will be a fuse (drivers footwell) or a dead pump. They do die if people operate them (or try) when the screenwash is frozen, OR if you use tap water the calcium build up can kill it. Quote
Jay M1988 Posted January 26, 2014 Posted January 26, 2014 I've looked in the drivers football but I'm struggling to work out which is the fuse to check? Any ideas or diagram of fuse layout within the drivers footwell My washer pump doesn't make any noise at all, so I swapped the pumps over an the rear window pump mustn't be as powerful as water is trickling from the wipers. Quote
Lyger Posted March 17, 2014 Posted March 17, 2014 I've got the same issue did anyone find the fuse ? Quote
kevinmwatters Posted August 17, 2014 Posted August 17, 2014 Guys any update on this one?Having the same issue, but drivers footwell fuse box doesn't clearly designate which fuse is for the front (or any) screen washers? Quote
GMballistic Posted August 17, 2014 Posted August 17, 2014 Guys any update on this one?Having the same issue, but drivers footwell fuse box doesn't clearly designate which fuse is for the front (or any) screen washers? Does it not list the fuses on the lid? Something like this?... I have never looked at mine so not sure whether it has a diagram layout of the fuses or not but most vehicles usually do. Quote
kevinmwatters Posted August 18, 2014 Posted August 18, 2014 It does have a diagram like this, but most of the entries are blank. Certainly don't have a washer designated fuse as shown above? Quote
GMballistic Posted August 18, 2014 Posted August 18, 2014 It does have a diagram like this, but most of the entries are blank. Certainly don't have a washer designated fuse as shown above? Very strange. Quote
kevinmwatters Posted August 20, 2014 Posted August 20, 2014 Ok, photos seem to generally make these discussions a little easier. Heres what I have currently; Fuse box (Pic 1) and lid (Pic 2) in the battery compartment, along with headlight washer relay in battery compartment (Pic 3), no "washer" designated fuse, only one for the headlight washers, which I believe are seperately fused? Pic 1; http://i1373.photobucket.com/albums/ag366/Kevinmwatters1/fuses2_zps36b35afa.jpg Pic 2; http://i1373.photobucket.com/albums/ag366/Kevinmwatters1/fuses1_zps084b896a.jpg Pic 3; http://i1373.photobucket.com/albums/ag366/Kevinmwatters1/fuses4_zpsd9d11340.jpg Otherwise, there is just the 2nd fuse box in the drivers footwell, the cover of which looks like this (again, no specific reference to washers); http://i1373.photobucket.com/albums/ag366/Kevinmwatters1/fuses3_zps73ed6e4c.jpg Any ideas? Quote
philw99 Posted August 21, 2014 Posted August 21, 2014 I never found the fuse just swapped the pump fixed the issue for me. Really cheap just time consuming to replace. Quote
retro_al Posted April 9, 2016 Posted April 9, 2016 I have the same problem,must be a fuse as ive checked the wires onto the pumps and there no live when operating the stalks,but I cant find the fuses in the drivers footwell Quote
retro_al Posted April 9, 2016 Posted April 9, 2016 It was the pumps after all, I had a new one in garage for a escort, tried it and it worked, they still seem a bit weak but at least they are working Quote
