Personally I wouldn't worry, mine was quite happy on Shell helix 10w40 nothing wrong with a semi synthetic, the jump from w30 to w40 is not great, and TBH with Nissan's engine tolerances it made virtually no difference to oil pressure, maybe 1-2 psi.
Is it the right oil? No. Is it going to make your engine collapse? No. Long term it won't do it any favours and you'll be losing power, but it's better than no oil at all.
I'd replace it sooner rather than later and I wouldn't go tracking it, but to use it normally won't hurt too much.
That grade and viscosity will make no difference. It just won't be as effective for as long as a fully synthetic. Changing it would be a good idea but I wouldn't be panicked. Cheaper oil degrades under heat cycles quicker but its still lubricating the engine. So as long as the engine has time to warm up before spirited driving it will be fine. Do a mini service and put fresh oil and filter in. There are some good semi's out there, so it doesn't have to be fully synthetic. And the thinner viscosity will make it easier for the engine to crank over in the winter.
I thought some people ran 10w40 to help engine ware on older cars or ones which were burning a bit? I was going to switch to 10w40 at my next service... I might rethink! :shrug:
I don't understand why people switch from what the manufacturer recommends???? They recommend for a reason to suit where the car is going to be used(in terms of temps etc) and to protect the life of the engine!
They do Paddy.
My GT4 is burning about 3/4 of a litre every 1000 miles and Japex have advised me to try the 10w40 from now on.
I'm happy to follow their advice.
Some of the responses on this thread are laughable.
which ones? And why?
None of them are laughable because they are just trying to help the OP in good faith and from their own knowledge and experience.
They do Paddy.
+1
Reading back 'laughable' is a bit strong, but the tone of urgency in some of the replies is a bit much and some of the statements of 'fact' do differ to advice given by professionals who specialise in these cars.
It's fine, it'll be fine and it's very similar to what I'm about to put in a car I like to take good care of.
It's worth reading this:
http://www.350z-uk.com/topic/71469-the-advantages-of-synthetic-oils-over-mineral-oils/
To a lesser degree, the points covered in the above would apply to semi- synthetics also.
The other point is that when it is not clear what use the car is going to be to, it pays for members to be cautious with oil recommendations.
Nissan actually say that you can use 5w/30, 10w30 and 10w40. 5w30 is prefered but the others are fine so long as ambient temps are above -18deg C. Semi synth is fine too, for road driving. Synthetic oils are better at coping with higher temps and they maintain their lubrication properties for longer. So the oil justthejedi has shouldn't cause any probs at all.
Edited by Jez
http://www.350z-uk.c...r-mineral-oils/
Extract from a European Court judgement: "Synthetic is a marketing term and its up to the marketer of the oil to define what synthetic is." Therefor, any oil that is subjected to any unconventional practice can be labelled synthetic.Most "fully synthetic"oils have as much as 20% petroleum product added as a carrier oil for the additives, so it is labelled as "fully synthetic" when it is not. Why,if "fully synthetic" is so good,are the change intervals exactly the same as mineral oils? It seemed to me that some of the answers given to Justin may have scared him into thinking it would wreck his engine, when,as Jezz said, it won't do any harm at all. Regards, Keith Edited by firemansim
When all is said and done I guess each owner makes their own decisions for their own reasons.
One thing I have always done with my performance cars is to put in the best oil I can.... I can't see much downside to that other than an element of additional cost.
The expensive ones :lol:
Don't know why I'm laughing, that's true really. Motul, Mobil 1, Fuchs, and there's another one that's been mentioned on here before too that a lot of people in the know are using these days too but the name escapes me now. Which is irritating, and it's probably the one to go for as well.
Getting old Dan :)
