Primey Posted November 22, 2019 Posted November 22, 2019 Hi all, I was just wondering what grade of engine oil people are using in DEs? Mines due a change after a drift day at Santa Pod on Wednesday. Cheers! Quote
davey_83 Posted November 22, 2019 Posted November 22, 2019 I've pretty much swapped brand of oil every oil change since ownership, had Motul, Castrol, Shell, Fuchs 5w30 or 5w40 to which the car felt best on Castrol 5w30 C3 stop start. Quote
HEADPHONES Posted November 22, 2019 Posted November 22, 2019 +1 on above 5w30 according to the manual Quote
Lolli pop Posted November 26, 2019 Posted November 26, 2019 On 23/11/2019 at 11:12, Jack94 said: Fuchs Titan Race Pro S 5w-30 just received this oil from Opie - will be getting it changed this weekend. Quote
Beefy Posted December 18, 2019 Posted December 18, 2019 I find 5w30 burns off too quickly and ends up running a bit, well... "Low pressurey". I used 10w-40. But I send it a fair amount. Quote
pintopete58 Posted September 5, 2020 Posted September 5, 2020 Hi everyone hope all is well just won't to no how many LTRS of oil does a DE 350 hold Quote
davey_83 Posted September 5, 2020 Posted September 5, 2020 58 minutes ago, pintopete58 said: Hi everyone hope all is well just won't to no how many LTRS of oil does a DE 350 hold https://applications.castrol.com/oilselector/en_gb/c/search Quote
ZMANALEX Posted September 5, 2020 Posted September 5, 2020 1 hour ago, pintopete58 said: Hi everyone hope all is well just won't to no how many LTRS of oil does a DE 350 hold 4.9 lts. including filter if OEM sump fitted with no spacer. Quote
Anth4130 Posted November 23, 2020 Posted November 23, 2020 I used MLR 10w50 when I was using the V6. No oil cooler, never had any problems. Standard grade oil I was getting low oil pressures when it was hot (I hot lapped if the opportunity was there), on the off chance I tried the thicker oil before putting a cooler on and it was fine so kept running it. Quote
lgz350 Posted Wednesday at 22:42 Posted Wednesday at 22:42 On 22/11/2019 at 12:35, Primey said: Hi all, I was just wondering what grade of engine oil people are using in DEs? Mines due a change after a drift day at Santa Pod on Wednesday. Cheers! my de twin turbo aso im using 5/40 motul 8100 power synthetic ester. hdev recommend it turbo z's Quote
