RobPhoboS Posted February 17, 2015 Posted February 17, 2015 Time/miles approximately with typical driving, not crazy track days or daft suspension settings. I wondered roughly how long they go on for until the ball joint end gives up. Quote
JetSet Posted February 17, 2015 Posted February 17, 2015 Mine lasted just 21k but then again I would imagine that the age of the car is a factor too, mines a 2006 car. Pete Quote
KyleR Posted February 17, 2015 Posted February 17, 2015 I'd say 30 to 40 K miles I would agree with this, or about 5-6 years if not doing much driving. They really are shite I have a bush here if yours is going? Quote
hensh65 Posted February 17, 2015 Posted February 17, 2015 Plus if your house is in the middle of an estate with a lot of speed bumps it will go even quicker Quote
RobPhoboS Posted February 17, 2015 Author Posted February 17, 2015 (edited) I've got 2 types of poly bushings here ready to go into them, just will see what Sly things regarding either brand and quality. It really was just a curiosity thing regarding these parts, I replaced my ones a little while back but it's frustrating that a company like Kinetix/SPL etc etc haven't actually come up with an improved design (yet). I also wonder if the poly bush helps improve/reduce the longevity of them ? Edited February 17, 2015 by RobPhoboS Quote
Mark@Abbey m/s Posted February 17, 2015 Posted February 17, 2015 (edited) Are you running SPL Front comp arm rear bushes? If so they will never be quiet. I use them on our heavy duty track cars/race cars and they are normally noisy straight away. I would always use Super Pro bushes nice and quiet and will last forever I would say. Edited February 17, 2015 by Mark@Abbey m/s Quote
RobPhoboS Posted February 17, 2015 Author Posted February 17, 2015 Are you running SPL Front comp arm rear bushes? If so they will never be quiet. I use them on our heavy duty track cars/race cars and they are normally noisy straight away. I would always use Super Pro bushes nice and quiet and will last forever I would say. Hi Mark (MANY thanks again for the top mount on Sat !), I've got Superpro and Prothane, most likely the Superpro for this specific part will go on, seems better engineered for this bushing. At the moment it's just the standard rubber in there, looks fine though (not touching any metal parts at that end). Quote
Mark@Abbey m/s Posted February 17, 2015 Posted February 17, 2015 so what item is causing the noise at the moment? the ball joint (at the hub) or the rear bush onto the subframe? Quote
GT4 Zed Posted February 17, 2015 Posted February 17, 2015 I replaced my ones a little while back but it's frustrating that a company like Kinetix/SPL etc etc haven't actually come up with an improved design (yet). I also wonder if the poly bush helps improve/reduce the longevity of them ? I think your suggestion is misleading Robbo. Have you used Kinetix or SPL parts? I have the engineering is fantastic. My whole car is fully bushes with the SPL solid monoball bushings from Superpro/ energy suspension combo and there is no squeaking, rattling or banging. There is an increase in NVH as the solid bushes transfer all the road noise into the cabin via the chassis. I can even go one step further to say that there is minimal difference between my polybush setup with the solid bushes wrt NVH. I agree that urethane will outlast the OEM bushes but not a poorly designed one. Superpro, whiteline are well designed and probably up there. Overall energy suspension are good but their compression bushing is not as well engineered and would cause bind imho. From what I see looks like prothane are ok but we await your feedback being the first to try them on. We shouldn't forget that these cars are mostly a decade now and when upgrading some areas it can expose problems that were concealed by the good dampening effect of the OEM rubber bushes. So strange noises, knocks etc need to be investigated thouroughly. I've seen front top mounts that were completely seperated due to rust, worn/shrunken bump stops etc as all accuse for strange noises after bushing change. Quote
RobPhoboS Posted February 17, 2015 Author Posted February 17, 2015 (edited) so what item is causing the noise at the moment? the ball joint (at the hub) or the rear bush onto the subframe? Oh, that's either just the piston rod in the new shocks (didn't torque them due to not having the right tool - just on f'ing tight), or possibly the ball joint end on the compression arm (front left, stops noise after left foot braking). I replaced my ones a little while back but it's frustrating that a company like Kinetix/SPL etc etc haven't actually come up with an improved design (yet). I also wonder if the poly bush helps improve/reduce the longevity of them ? I think your suggestion is misleading Robbo. Have you used Kinetix or SPL parts? How is it misleading mate (?), I said it would be great if Kinetic/SPL etc would make a replacement for the compression arm. (I think you've mis-read what I typed) I have the engineering is fantastic. My whole car is fully bushes with the SPL solid monoball bushings from Superpro/ energy suspension combo and there is no squeaking, rattling or banging. There is an increase in NVH as the solid bushes transfer all the road noise into the cabin via the chassis. I can even go one step further to say that there is minimal difference between my polybush setup with the solid bushes wrt NVH. I agree that urethane will outlast the OEM bushes but not a poorly designed one. Superpro, whiteline are well designed and probably up there. Overall energy suspension are good but their compression bushing is not as well engineered and would cause bind imho. From what I see looks like prothane are ok but we await your feedback being the first to try them on. We shouldn't forget that these cars are mostly a decade now and when upgrading some areas it can expose problems that were concealed by the good dampening effect of the OEM rubber bushes. So strange noises, knocks etc need to be investigated thouroughly. I've seen front top mounts that were completely seperated due to rust, worn/shrunken bump stops etc as all accuse for strange noises after bushing change. Once again, no disagreements whatsoever from me here. I literally, innocently wondered how long compression arms should last in daily driving conditions, and then wondered how poly bushings affect this as well (good or bad) - IF at all. I imagine it would be more beneficial with a poly bushing/solid due to less stress on the ball join end. Obviously I'm no engineer but just logically pondering Edited February 17, 2015 by RobPhoboS Quote
GT4 Zed Posted February 17, 2015 Posted February 17, 2015 (edited) Hey Robbo, got you but I wasn't having a go at you my friend just that your statement read ambiguously TBF I know you are trying to share your experience which is great. Edited February 17, 2015 by GT4 Zed 1 Quote
Daryl Posted February 17, 2015 Posted February 17, 2015 I had Superpro Bannan arm bushes fitted a few years back, and they have been as good as gold. Quote
