So I want to be able to take better pictures but I'm on a budget as I'm saving for a house atm.
My current camera canon eos 450d has an iso limit of 1600. Would I be better off getting the speedlite 430ex ii flash to enable myself to take better low light photos or getting a better camera with a higher iso limit. In that case I'd be selling my 450d body and buying a used one off eBay. My limit for that would be about £500. That includes the sale of my 450d body.
Any help would be greatly appreciated. Thanks in advance.
Higher iso usually means more noise so maybe not ideal? What are you taking photos of? If it's close up, then a flash would be beneficial. If it's over 10m then obviously a flash is pretty useless.
Have you thought about a tripod and longer exposure? That comes with other problems and no good really if you want to take shots of anything moving.
Better body isn't always the answer. :)
ISO performance is better, even on a modest upgrade such as the 550D - but stretching the limit of the cameras ISO performance isn't ideal or desirable.
You don't mention what lenses you are using, which is a far more significant factor when dealing with low light photography than your body, as is technique.
Additionally, if considering a flash unit, the Canon ones are very expensive and not really necessary unless you take photographs for a living (reliability). You can buy Speedlite copies very cheaply, and the performance is fantastic. I own several along with some wireless triggers - lighting possibilities are endless.
http://www.amazon.co...N/dp/B009APY9TO
And as Paddy says, what are you taking pictures of? Might help us help you...
Edited by ts743
Tripod sounds like what you need, always try for the lowest ISO/ASA you can.
If it's sport your photographing you'll need to practising 'panning'.
As others have said BBK you need to tell us what type of low light photography you intend to do and what lenses you intend to use.
If you are thinking of buying a flash then do this as ts743 said,
" You can buy Speedlite copies very cheaply, and the performance is fantastic. I own several along with some wireless triggers - lighting possibilities are endless."
Yes, these units are superb, very cheap and can be used off camera creatively.
By the way, do you shoot raw or jpeg??
Cheers for the help peeps. I shoot raw, and have the following lenses...
Ef 50mm f1.8
Ef 70-300 f4-5.6
Ef-s 15-85 f3.5-5.6
I already have a tripod. But sometimes it's not useful to get it out all the time.
I like going to the zoo alot and to museums. It's there that I have issues. When it's dark and its close up stuff.
Sometimes I do night time photography. I'll put some of my shots up. Sometimes I like night time sports photography like the le mans 24hrs race.
I understand that the higher iso brings more noise, I just wasn't sure if the newer cameras handled it better and would be of more use.
I have those lenses, but I sold a 350d body and bought a 550d body, I also sold my 17-70f2.6 but kind of regret it now as the difference between that and the f3.5 is quite a lot, and although I now have plenty of ISO I seldom use it, but then I don't really do a lot of low light.
I don't see any problems with your pictures...
Some have an exposed sky and an under-exposed land area, for example. Nothing will fix this other than external lighting or using HDR technique from multiple exposures...
For museum photography, you might benefit from an external flash, should yield good results.
Your 50mm 1.8 is a reasonably fast lens, either use a longer exposure with a tripod or employ the use of a flash :)
Edited by ts743
If you want quality pics similar to the type you've posted then you are going to have to get the tripod out every time.
Nothing wrong with them and you dont need a fast lens to take them.
The middle pic; the camera has exposed for the sky and left the trees dark. Correct this by using a graduated filter, but I don't usually bother with them, and use the grad filter in Lightroom 5.
For museum and zoo work, I'd definitely use the flash if possible. Once you start getting into the realm of fast lenses with apertures of f1.4 or f1.8 then you are talking big, big money.
I would buy a Speedlite replica for now, as this is your cheapest option, and see how you get on with it.
The new cameras do handle noise better but to what level, I can't comment on that, as I use a Nikon D80.
I have a 450D and agree the ISO performance is pretty poor.
When I compared it to a similarly priced Nikon a few years ago (think it might have been the D90) the Nikon was streets ahead.
That said, I agree with the others about finding a way to reduce your need for high ISO settings.
Lessons. Take some lessons, that'll be a far better use of budget than anything you can throw at body or lenses.
I’ve recent thought about swapping my £300 550D for a £1500 7D Mark II body…but after looking through some of the shots i’ve managed to get with the 450/550D, and some advice from people on the forum I really cannot justify the price difference. So actually I don't think you need to spend £££ to get some decent shots with the gear you have already.
I will probably go for a 70D soon, mainly because my 550D is actually starting to finally show signs of wear.
For Zoo/Motorsport stuff I love the 450/550D with 70-300 4.5-5.6 IS Lens, just wish the AF system had a more flexibility.
Though I don’t do much static night photography so you might see more difference from better ISO body, but these nights shots are all hand held, using 450/550D, not good enough for pro level stuff, but more than good enough for the walls of our little house :)
Edited by gangzoom
Taken some but I still feel held back. thinking flash is the way forward.
And then you you might need to start going down the route of two or three flashes with slaves.
There is an old book called 'Techniques of Photography by Available Light' by Colin Glanfield If you see a copy in a junk shop,it's a good read.
I'll try and get up an example pic of what I mean by having issues. Sometimes a tripod is a no no. Yesterday at the natural history museum with so many kids on school trips around its just not do-able.
I'm no expert and Im not using my camera as much as I'd like due to the ball ache of carrying tripod around etc but I do have friends who do carry their kit with them.
They will enjoy places like the natural history museum with the crowds just taking in the exhibits without getting distracted by taking a picture. They will then try and visit at a quiter time when they can set their tripod up and concentrate on the picture and not the exhibit.
I know it's not ideal but that way the enjoy the museum for what it's meant without the fuss of all their kit. I also know places like that are never quiet but if you can work along those lines it may just help.
Keep the pics coming :):thumbs:
