Paddy78 Posted January 13, 2014 Posted January 13, 2014 (edited) I have managed to get hold of a spare Plenum and TB which I want to powder coat black (To match my black Takeda intake which is imminent). I know that people have powder coated plenums before, but has anyone ever done a TB? Is it even possible due to the electric current / heat and the fact that the TB has electric / plastic parts? Â What prep work should I be doing for the plenum before I take it to be PC'd or will they just sand blast / acid strip it? Same question for the TB if I have to paint it myself. I assume you can't just remove the rivets and separate the plastic control box from the body of the TB? Â Any help or advice appreciated! Edited March 10, 2014 by Paddy78 Quote
Keyser Posted January 13, 2014 Posted January 13, 2014 Buster sprayed his TB Â I can't say that I would be happy to have mine powder coated due to the electronics - happy for you to do it and tell me if it still works. Â If you have the plenum sandblasted make sure you have it well cleaned before putting it back on. Â You should really sand the plenum down a bit and polish it up before PC as the "dimples" do show through. Â I did think of drilling the rivets and seeing if the TB could be stripped for PC but haven't got that far yet. Â Keep us informed. Quote
Wasso Posted January 13, 2014 Posted January 13, 2014 As Chris says the TB I don't think would bode well for PC'ing. Â +1 on the plenum. You could always paint it and build up the layers maybe to iron out the rough casting? Quote
glrnet Posted January 13, 2014 Posted January 13, 2014 Here you go Paddy:- Â http://www.350z-uk.com/topic/36830-painting-throttle-body/ Quote
Paddy78 Posted January 13, 2014 Author Posted January 13, 2014 Thanks guys, not sure I'm going to be the pioneer with stripping the TB... but you never know! Taking it apart will invariably break it though! I'm looking to get the same texture as the Takeda intake which I believe is slightly textured, like a wrinkle finish Quote
glrnet Posted January 13, 2014 Posted January 13, 2014 Post 54 here for pic:- http://www.350z-uk.c...-7/page__st__40 Quote
glrnet Posted January 13, 2014 Posted January 13, 2014 Thanks guys, not sure I'm going to be the pioneer with stripping the TB... but you never know! Taking it apart will invariably break it though! I'm looking to get the same texture as the Takeda intake which I believe is slightly textured, like a wrinkle finish Ignore this then ^ Quote
Paddy78 Posted January 13, 2014 Author Posted January 13, 2014 Thanks Graham! Your's and Marky's were the 2 that I'd seen painted. I think I'll just spray that matt black to minimise the chances of destroying the TB. Quote
Keyser Posted January 13, 2014 Posted January 13, 2014 Thanks Graham! Your's and Marky's were the 2 that I'd seen painted. I think I'll just spray that matt black to minimise the chances of destroying the TB.  O darn - I wanted to see if it would take the heat and still work  Prolly the best choice really Quote
Paddy78 Posted January 13, 2014 Author Posted January 13, 2014 I don't even live remotely near the Zed Shed, so you wouldn't even have to help sort out the mess! Quote
Wasso Posted January 13, 2014 Posted January 13, 2014 I don't even live remotely near the Zed Shed, so you wouldn't even have to help sort out the mess! Â The Zed Shed does have a postal address Quote
Keyser Posted January 13, 2014 Posted January 13, 2014 I don't even live remotely near the Zed Shed, so you wouldn't even have to help sort out the mess!  The Zed Shed does have a postal address  O Thanks mate  I do have a spare TB so I may yet try this though ........ watch this space  don't hold ya breath mind! Quote
fellsteruk Posted January 13, 2014 Posted January 13, 2014 Would like to see the end result. I found a good local powder coater who is doing my wheels and was thinking of getting mine done if the wheels come out good. Quote
Paddy78 Posted March 10, 2014 Author Posted March 10, 2014 So, first sunny weekend of the year and I decided to give painting the Plenum and TB a go. My car is still in the bodyshop, so really starting to get Zed withdrawals!  Paint  Prepped Plenum and TB - Tibby was no help whatsoever!  Finished Article   It's not perfect, but not too bad for my first attempt at spray painting. Depending how anal I get about the finish I might redo it, but overall I'm really pleased with the result. Does anyone know if you can put wheel sealant on these to give a bit of extra protection? 3 Quote
Keyser Posted March 10, 2014 Posted March 10, 2014 I quite like that  You can put wheel sealant on - weather it would do any good and what it would smell like I'm not to sure  Hi heat lacquer may be a better option? Quote
Paddy78 Posted March 10, 2014 Author Posted March 10, 2014 I quite like that  You can put wheel sealant on - weather it would do any good and what it would smell like I'm not to sure  Hi heat lacquer may be a better option?  This is why I ask the stupid questions!  speaking of stupid questions... anyone know the difference between the AKCD03 and AKCD02 plenums? CD02 is what I have on my Rev Up, but is there anything different in terms of flow??? Quote
Wasso Posted March 20, 2014 Posted March 20, 2014 There is not difference between the two plenum codes. I think it's just their model number change, maybe a different consistency of materials used? Â I've never seen a difference between the two. Â Looks smart though Paddy 1 Quote
Tricky-Ricky Posted March 20, 2014 Posted March 20, 2014 You can just use 2K paint, that way you can choose any colour you want, 2K will take engine heat no problem, I have sprayed bike engines with it. Quote
