what's the difference between these and the one in the video?
I don't think there is any difference.
I have just gone through the thread and according to Marzman who bought one
the display has a slight blue tint to it. everything else is as in the video. :thumbs:
Edited by WhackyWill
There is a difference - the one in the video is white, and these are green. Secondly the one in the video has a second, smaller numeric readout (in green on the video) - which is not present on this model. Look at the photos of the unit, you can see there is no smaller display above the main one.
This is not to put anyone off buying one - im happy with mine, it's just not the one in the video.
Thanks for clearing that up Marzman, as I said I never got around to trying it out when i got them. :thumbs:
Desperately need one of these for the Z32, but they ain't OBDii.
I think I'll need to look around and see if anything can be mocked up using the Nissan Consult plug on the ECU.
Thats far to technical for me Lexx.. :scare: :scare:
It wont work with an import - i tried it on my JDM zed and no joy because they are not ODBII, they are J-OBD.
Lexx - maybe get one of the hard wired models which just need power and tapping into the single VSS wire?
how is it plug and play? what do you plug it into?
It's OBD 11 Interface.
That means nothing to me! Where would I actual plug it into? :surrender:
Hi Randy.
You plug it into the same port under the dash as you would a code reader.
I'm sure somebody on here has a pic of its location, if not I'll try and photograph its location
this evening when home. :thumbs:
Hi Randy.
This is a pic of the OBD port where it plugs into.
How are people hiding the wire? I'd probably just run it up the side of rg door and round the bottom of the window. Would be interested to see it installed.
Buy one Randy and install it, and post your results... :thumbs:
Hi Randy.
Marzman has installed his. :thumbs:
Hi Randy.
...in a Range Rover
Hi Randy.
...in a Range Rover
Yes still has a cable though... !! :surrender:
Hi Randy.
...in a Range Rover
I think he was after "where" to route the cable in a 350Z, rather than a Range Rover
