The Chubby Ninja Posted April 3, 2013 Posted April 3, 2013 What sbout the tegiwa nuts in the pics? They any good? Quote
HaydnH Posted April 3, 2013 Posted April 3, 2013 What sbout the tegiwa nuts in the pics? They any good? Probably not, they're still Aluminium. I just used that pick to show the adaptors. Quote
rob63 Posted April 3, 2013 Posted April 3, 2013 If I was you having tried everything else I would drill the centre of the stud, start small and increase the drill bit size until it falls off, also only drill deep enough to remove the nut itself! Not sure how easy it will be to source a new stud might be worth looking into before destroying it completely +1 On the above. But, if you feel the need to ask how to do this then don't attempt it...then again if you knew how to do this you'd have done it by now and wouldn't have posted Quote
StevoD Posted April 3, 2013 Posted April 3, 2013 (edited) NEVER USE ALUMINIUM NUTS EVER! Ive delt with getting about 6-7 sets off of friends cars who said it would be fine, Steel or titanium only Edited December 12, 2013 by StevoD Quote
Tarmac@TarmacSportz Posted April 3, 2013 Posted April 3, 2013 Tarmac, do you stock the Muteki SR48's or do you only have the SR35's? I sell Muteki super tuner nuts, although I can order the other ones I always find the super tuner nuts the popular ones. They are made of steel 1 Quote
Grundy Posted December 12, 2013 Posted December 12, 2013 Just bought some of these of a forum member...Not sure if I should fit these.http://www.350z-uk.com/topic/78345-d1-spec-gold-wheel-nuts-20x-for-350z/ Anyway to tell if there genuine? Quote
Lexx Posted December 12, 2013 Posted December 12, 2013 D1 nuts are horrendous. Every forum has stories of them stripping and needing to be drilled off. Aluminium.pieces of crap. Quote
AliveBoy Posted December 12, 2013 Posted December 12, 2013 Just bought some of these of a forum member...Not sure if I should fit these.http://www.350z-uk.c...<br /><br />Anyway to tell if there genuine? Honestly, I wouldn't recommend it. They MIGHT be ok for a bit, but I wouldn't take the risk personally. You'd have to be the unluckiest person in the world for them all to fail, but the agro might not be worth it. Quote
Grundy Posted December 12, 2013 Posted December 12, 2013 Brilliant lol, now I have some nuts in the post, waiting to sit at home. And I'd feel to harsh to sell them on given the history. Quote
Leosille Posted December 12, 2013 Posted December 12, 2013 I've just got a set in red :| they look the dogs bssss which is the annoying thing. Quote
Grundy Posted December 12, 2013 Posted December 12, 2013 I've just got a set in red :| they look the dogs bssss which is the annoying thing. Want some Gold ones? Heard there stronger 1 Quote
The Chubby Ninja Posted December 12, 2013 Posted December 12, 2013 I had a nightmare with the gold ones. Car ended up on the back of a lorry on its way to abbey and had to get the studs drilled out I'd never use them again Quote
peteman35 Posted December 12, 2013 Posted December 12, 2013 Horrible pieces of poo. Not worth the hassle they can cause Quote
HaydnH Posted December 12, 2013 Posted December 12, 2013 The Muteki SR48s look similar, are made of steel and are good quality... available from Tarmac. Quote
Leosille Posted December 12, 2013 Posted December 12, 2013 I've just got a set in red :| they look the dogs bssss which is the annoying thing. Want some Gold ones? Heard there stronger send them straight over I'm going to forge them together I will have super nuts Quote
BulletMagnet Posted December 12, 2013 Posted December 12, 2013 I have 5Zigen Duraluminium nuts when my Volks are on, OEM nuts when the Rays are on, been four years and no issues. Lil bit of copper grease helps too Quote
