Coilovers > slammed.
Daze
Hey guys,
In the middle of a dilemma with either thinking of selling my 350 or beginning to modify it, so just putting some feelers out there, and getting some ideas together.
Thinking of potentially buying some nice rims & coilovers and lowering it a fair bit.
However, just wondering how much the 350's can be dropped by before they start to be too effected by handling? Of course, the camber & toe will be put out when I lower, but how far is "reasonable" before things get silly?
And has anyone done a serious drop with no camber/toe adjustments - how does the car feel?
Second question, coilover choice, are these any good?
>> http://www.japspeed.co.uk/Nissan-350Z-D ... s/p-0-873/
Or is it worth the extra and go for HSD's?
>> http://www.driftworks.com/shop/hsd-hr-c ... z-z33.html
My car is used daily/fast-road,
Cheers guys :)
Haha, nice.
Actually, to contradict myself a bit, just done some reading & looking, a 30mm drop on lowering springs looks pretty good. And in fairness this still my daily.
Although it would look good on stock Rays wheels, I'm unsure just a 30mm drop would look any good on my "new wheels idea", since I'd be running a lower profile, therefore more gap.
Also done some reading - BC Racing Coilovers - seem cheap & people say they're good? Any thoughts/comments?
At 30mm drop, you will deffo need to get camber correction kits.
AFAIK even the Eibach Springs that go 20mm need them already.
Camber correction bolts for the rear and adjustable a-arms for the front, I think.
Only went for a mild drop myself on Tein springs and thus not needing either.
This should be done with caution. The stock TCS is very touchy about rolling radius of tyres, particularly in relation to the ration of front vs back rolling radius. If you want to run a lower profile tyre, typically you'd install wheels which are bigger. Ie move from 18" to 19" and run lower profile while keeping the same rolling radius. This way you wont effect the gap or TCS but have a nicer looking setup :thumbs:
Eibachs state 25mm drop but they are more like 30mm drop :thumbs:
PM Wasso, he's dropped his 30mm and doesn't have any problems as far as I know, not sure what he did about camber correction though :)
Haha, nice.
Nice thanks for the replies. What's TCS though? Lol.
Traction control I guess? Then I'll just turn it off with my new setup.
New wheels might be something like 18x10 with 265/35 Tyres, means 15mm drop, so fair bit less rolling radius.
Also people saying that I absolutely need camber correction etc. Do I really though? I mean, my drift/track car is an s13 and I slammed that with no camber arms, lots of camber very far from factory settings and it felt great.
Just keep the ratio of rolling radius front to back the same as OEM and the TCS (traction control) wont be a problem. Saying you will just turn it off all the time is asking for trouble. If you have a crash and the insurance find out you had TCS off then you may not be covered.
If your using your 350 as a drift car your going to be eating tyres and it really won't matter - If you want to use it on the road at best it will wear tyres quicker at worst it won't handel well at all.
Hm are you talking about the relation between front & back? I notice my current setup does indeed have different profile tyres front & back, however I also know the Rays are different widths too.
I defiantly won't be running with the same profile tyres or similar tyre fitment to OEM as they're so chunky, I will be going for more stretch, as to tuck the tyre better under the fender.
I can't see me having problems with TCS off, I don't find the 350 very tail happy even when off and I'm used to my s13 which I use for drifting - 290hp, welded diff, etc.
Nice. I won't be using it for drifting, but replacing tyres every 6 months(??) due to camber is fine with me. B)
I'm talking about rolling radius, not width of tyres. For the car to understand if the rear wheels are spinning it monitors the speed of the front and rear wheels (rear wheels spin faster, then TCS will kick in). Now as standard, the rear wheels have a bigger rolling radius than the fronts (IIRC there is a 3% difference). For the TCS to keep working you need to factor in this difference and keep it the same. As soon as you change it (more than a percent or two) it will get confused. Now the absolute rolling radius doesnt matter, what you need to keep in mind is the percentage difference front to rear wheels. I've written a detailed comparison before so give it a search and you'll find the numbers. You can run non OEM rolling radius so long as you keep this relation of front to rear correct :thumbs:
Ah that's awesome, makes a lot more sense. I will have to go check my current setup & do some calculations!
Thanks for clearing that up! Brilliant. Just unsure now if I will need more than a 30mm drop - lowering springs or coilovers. Hmm :)
Right, done some calculations. Correct me if I'm wrong here (been using www.willtheyfit.com for this)
Current setup,
225/45 8j and 245/45 8.5j radius difference = 2.66%
New potential setups
265/35 10.5j and 285/35 10.5 = 2.13% (favourite so far)
245/35 10.5j and 265/35 10.5j = 2.18%
255/30 10.5j and 285/30 10.5j = 2.87%
Any thoughts for thoughts? :) Cheers.
u might run into some rubbing issues with 275.s on a 9.5 rim on the front, unless the offset is quite high!
This is how low i run mine
and that is on the Daiyama coilovers that you mentioned on your first post, they seem a very good road setup so far, low spring rates so not harsh either.
Not as good as the CS2's on my R34 but id say there better ride quality than the Tein's i used to have on that!
I had the alignment checked on mine last week, just have standard adjustment available so brought the Toe back in to spec & left the camber at around 4 degrees negative on the rear, drives fine. Obviously not as much rear grip as you'd have available with a more upright tyre but not really an issue.
Also i didnt really wory about tyre sizes & rolling radius, if the TCS doesnt like it then i'll turn it off but it seems ok with 215-35-19 on a 9.5J front & 245-35-19 on a 10.5J rear
Right, done some calculations. Correct me if I'm wrong here (been using http://www.willtheyfit.com for this)
Current setup,
I run the 265 35 in front and 285 35's rear and have no problem all on a 9.5j rims with a offset of 15. No issues or rubbing. I rekon I could even get away with 275's in front as well but thats too wide for the front.
Nice, thanks for the replies everyone. Very helpful, gives me something to work on now, awesome.
Lum - any more pics of your car? Looks very low & pretty awesome, I probably won't be going as low as that, since I have a slight driveway to get up & down everyday, and I know if I were that low it wouldn't happen :lol:
Beau - awesome, thanks for the info RE tyre sizes. I'm now thinking of going staggered 9.5j front, 10.5j rears, so probably same tyre sizes as said above, but on different rim widths, should be perfect. B)
Although - like I said, the silver 350 above has the same tyre profiles on 9.5 and 10.5j's, yet that measured to have 0% front/back ratio, so surely must interfere with the TCS?
