showtime1 Posted June 14, 2010 Posted June 14, 2010 how much oil does your zed use between services? ive notice mine using a fair bit Quote
ATTAK Z Posted June 14, 2010 Posted June 14, 2010 me too ......... about 2 x 1 litre+ fill ups between services ...... I've now changed to fully synthetic on the advice of Tim at Opie which will hopefully reduce the consumption Quote
ug45cwb Posted June 14, 2010 Posted June 14, 2010 Mine uses about a litre every 4k miles or so. This was more than I was expecting but seems pretty standard from what i've heard. Quote
ATTAK Z Posted June 14, 2010 Posted June 14, 2010 Service interval is the usual 9,000 miles. What's yours using ? Quote
rtbiscuit Posted June 14, 2010 Posted June 14, 2010 mine didn't use a drop, i was running 5w30 royal purple oil Quote
showtime1 Posted June 14, 2010 Author Posted June 14, 2010 Service interval is the usual 9,000 miles. What's yours using ? its hard to tell with the dipstick but ive top it up 1/2 litre after about 1500 miles to be honest im struggling to read the dip stick Quote
bounty78 Posted June 14, 2010 Posted June 14, 2010 Yes..the person who design the dipstick is a dipstick Quote
Walbertonio Posted June 14, 2010 Posted June 14, 2010 Just about to put mine in for a P3, and having given it another check, it's used barely any, quite impressed! Quote
ATTAK Z Posted June 14, 2010 Posted June 14, 2010 Yes..the person who designed the dipstick is a dipstick Quote
ace Posted June 14, 2010 Posted June 14, 2010 that does'nt sound right you should not be putting oil or hardly any between services on petrol engines you sure you ain't got a diesel under the bonnet Quote
Demolition49 Posted June 14, 2010 Posted June 14, 2010 For those of you who have high consumption and have the mid life z - 2006 i believe you may have an issue there! Quote
bigbramble Posted July 31, 2010 Posted July 31, 2010 Service interval is the usual 9,000 miles. What's yours using ? its hard to tell with the dipstick but ive top it up 1/2 litre after about 1500 miles to be honest im struggling to read the dip stick I am glad I am not the only one. I am a fully trained mechanic with 11 years experience and the dipstick is total crap, I am now unsure if I have overfilled it as I keep putting more in and I cant really see any definite line, there is a more distinct darker oil at the bottom of the stick but it doesn't seem to move when I put oil in. Anyone else give me any tips? I'm gonna change the oil early next week anyway but it does seem odd. Quote
ATTAK Z Posted July 31, 2010 Posted July 31, 2010 Service interval is the usual 9,000 miles. What's yours using ? its hard to tell with the dipstick but ive top it up 1/2 litre after about 1500 miles to be honest im struggling to read the dip stick I am glad I am not the only one. I am a fully trained mechanic with 11 years experience and the dipstick is total crap, I am now unsure if I have overfilled it as I keep putting more in and I cant really see any definite line, there is a more distinct darker oil at the bottom of the stick but it doesn't seem to move when I put oil in. Anyone else give me any tips? I'm gonna change the oil early next week anyway but it does seem odd. Run the engine after a top up ..... leave it to settle and check again .... that way the new oil gets to be mixed with the old oil and shows up better on the dipstick Quote
showtime1 Posted August 1, 2010 Author Posted August 1, 2010 in the manual it says its normal to use half a litre every 600 miles if i remember correctly that does'nt sound right you should not be putting oil or hardly any between services on petrol engines you sure you ain't got a diesel under the bonnet Quote
nickzzz Posted August 1, 2010 Posted August 1, 2010 Mines hardly used any so far! My old 330ci used loads, at least a litre every thousand miles. Checked my dipstick recently for first time and I honestly thought it was damaged! Is it really meant to look all twisted and crooked? People seem to be saying its terrible design so I'm guessing mines normal! Quote
mic-39 Posted August 2, 2010 Posted August 2, 2010 04 and would use about 1ltr between 5k and 9k miles and only after 5k miles . I assume this is the oil starting to break down and I usually change every 7k anyway. I did notice that it depends on the oil type, the genuine nissan 5-30 spec fs will drop on the dipstick yet the mobil 1 wont show any usage. Driving style also affects usage . Again if I am on long motorway drives for 5-6hours then oil use will be more than shorter spirited drives Quote
Gervais Posted August 2, 2010 Posted August 2, 2010 Mine is a 2004 done just over 5k and oil level hasn't budged. Quote
Wasso Posted August 2, 2010 Posted August 2, 2010 I use about 1ltr every 4-5k miles. It also may consume various amounts depending on your daily driving style? Quote
UNABASHED Posted August 2, 2010 Posted August 2, 2010 I bought an extra litre for fills ups inbetween service but so far I've not had to open the bottle - service was nearly a year ago now! I went for fully synth so this might have something to do with it? Quote
H5 Posted August 2, 2010 Posted August 2, 2010 Always had fully synth (not that I'm sure it makes any difference) and mine doesn't use any (touch wood!). 2004. Quote
Wasso Posted August 2, 2010 Posted August 2, 2010 The last time my oil was changed was litterally a month ago by Abbey - I should have asked actually which oil was used. Lets see if there's a difference in consumption? Quote
