My Progress UPDATED 18/11/2010 More 3M Di Noc
AlexZ
  • Replies 267
  • Created
  • Last Reply
Top Posters In This Topic
Well the weather man said it was going to be a dry day and he was right.... I got some more claying done and the plugs changed...I've used a little Redex and Optimax since I last removed the plugs and there seem better now. :teeth::p
Clay Time.... :thumbs: For the people who dont know why this is required Ive shown a few close ups lol..
With a good wash sorted you will still find little tar bit and surface sh*te hangging around.... :doh:
After the clay session on the wing.... :thumbs::teeth::p
Tada, the polish is just to give the paint a little jacket until the full wax and p/c action can start.
Right the plugs...I tooks the images as I removed the Strut braces, engine cover, air filter pipe, coils and plugs from the passanger side... :p
Strut Brace, understand were the lock nuts are and loosen them any way you feel you will remeber the correct seeting. This has to be retighten back to the original setting..
Remove the Brace fixing bolts and nuts.
Undo the air filter pipe at the following locations
Remove the four engine bolt nuts
Remove the bolts securing the wiring loom and coil packs and unplug the coils..
Whip the plugs out..
When the plugs are fitted it's advised to use some sort of copper grease etc to make sure the plugs dont corode in the heads. I use Antiscuffing paste..
Refit in revese order. The Plug torque setting is 23n.m. :teeth:
Alexz
  • 2 months later...
Ok with the car just clicking over 45k I thought I best get her serviced asap. This is the first servive I've done since owning the car so I thought best do all the oil's and be happy knowing its all done. I spoke to Nissan and bought the oils, washers and oil filter.
I got the car in work yesterday morning and started...I took a couple of images along the way for people to have a peep... :teeth:
Engine Oil
I snapped one of the lower engine guard nuts in the front panel on removal..I guess Nissan couldn't be arsed to grease then last time it was serviced. Doh :thumbdown:
Couple of quick points if your going to do it yourself for the first time...Make sure you bough the correct filter before removing the one on the car lol... Make sure you have a new sump plug washer...this type compresses on itself... :thumbs:
Torque Setting accoring to Autodata is 35Nm for the sump plug.
Rear Diff
First thing is to whip the plastic cover off....IIRC there are four 12mm nuts... The diff holds 1.4liters of oil according to Nissan's manual and the torque setting for both the plugs are 34Nm. You will find the drain plug has a magnet on the end to collect and loose metal in the diff. Again I bought new washers for both plugs...these are plain washer and could be used again if needed.
Gear Box
Same as the diff the plugs are torqued to 34Nm, they also use the same washers. I would advise using a 500ml bottle to do this as the 1000ml is a little tight up the side of the box. Nissan say you should use 2.9liters of box oil...this doesnt come out the fill hole like most other cars I've services and you cant feel the oil level when you dip your finger in lol...Scary I know. :scare:. Most other cars also have a magnet on the box drian plug unless mines fell off lol..
I also had a good look round the car as all services should included. The front pads are low and require replacing soon. I've had a quick search and a lot of people recommend Ferodo DS2500. I was looking more toward the Brembo Sport ones. Has anyone used these before...Opie's can sort them for £108 delivered.?
Barring the brakes the car is cool...I changed the plugs to Denso Iridium ones late last years and cleaned the K&N filter.
When the snow cleared today I washed her and clayed the bonnet and wings... :teeth:
Alexz
Good thread this mate :thumbs: is the oil filter quite a small one? I had to buy a non gen on saturday morning as i wanted to change the oil this weekend & Nissan werent any help at all.When Autopart gave me it i thought hmm looks a bit small for a big engine.Id rather have the right one before i get my car on the ramps at work & empty it to find its wrong :surrender:
yeah they are quite small! i was quite shocked when i got mine, i got a magnetic one and a magnetic sump plug from envy and there spot on!!! :thumbs:
nice thread and nice garage, wish I had the latter!
Time to get a plenum spacer for you, I think :thumbs:
Now then mate, I have looked into them but at this moment I'm happy with her...Although I do need some more brake pads lol. :thumbs:
The garage is were I work so I can use it most weekends...Just a shame were only open for 4hours lol... :thumbdown: but it great when it's my Sat morning on cause 4 hours is to much lol.
get some yellow stuff pads from cs they feel good enough if you don't do to much inspired driving. :thumbs:
To be honest mate I ordered the Mintex pads today, if there no good I'll order some others of the forum's advise. If there ok I guess there'll be plenty of member's wanting good pads at these prices. :teeth:
I dont mind been the test dummy lol.. :scare:
Alexz
