GranTurismoEra Posted August 11, 2024 Posted August 11, 2024 Davey organizes them. I wont be there till i get a car preferably GTR but they have meets and driveouts. Some may be a bit far for you. The cotswolds meet up already happened. Thats a safe power band. I was told its more about torque/boost than HP for engine reliability. Quote
ballistic Posted August 11, 2024 Author Posted August 11, 2024 @Olly350z Thats a serious commendation. I will take it on board for sure. Just so much going on with the Zed i dunno when i will get to coilovers tbh, Did you ever have any other brands fitted? And yes springs with OE dampers isnt amazing. @GranTurismoEra OK i will keep an eye out. GTR is a good shout. wish the 400z came out here. Yes 400lbs is the safe limit on DE they say, im just below that, for now.... 😏 1 Quote
GranTurismoEra Posted August 12, 2024 Posted August 12, 2024 So youre engine is stock? Yeah at the moment they're (new Z) still too expensive. Need them below 30k to even consider it. Those are at 350 ft lbs but can be tuned to 600hp. If not GTR ill get another 370 probably convertible later on. Quote
ballistic Posted August 13, 2024 Author Posted August 13, 2024 8 hours ago, GranTurismoEra said: So youre engine is stock? Yeah at the moment they're (new Z) still too expensive. Need them below 30k to even consider it. Those are at 350 ft lbs but can be tuned to 600hp. If not GTR ill get another 370 probably convertible later on. Yea still completely stock unopened engine @ 60k miles. Hope to build it in the near future. Will be cool to see some grey imports of the new Z if that ever happens. Already twin turbo so easy to tune and a good platform. Quote
ballistic Posted August 13, 2024 Author Posted August 13, 2024 (edited) More alcantara bits. This time i did the A piller trim and the armrests on the door. And also purchased new alcantara shifter boot and handbrake cover. Carefully cutting material to size Then apply glue to part and lay material and work out creases. Tuck around the back and make sure its well secured. Cutting relief cuts where needed (loads of em in this case lol) Sounds simple but it very tricky. Have to make sure the surface is evenly covered with adhesive. Easy to cut too little fabric, easy to get glue on the surface of the fabric. Need to work quickly but also make sure its done properly I like to let them set for 24 hours before installation Then reinstall them hoping that they still fit back on and you havnt accidentally covered any clips or fittings. Keep touching it cos it feels lovely 🤩 Purchased these from ebay, the company used to be called JF customs iirc. Microsuede with tan stitching Old one was absolutely battered Bit of glueing to keep the boot in place The stitching is nice and straight and a very good match to the seats. Pretty happy with it Going to see how these bits hold up as im interested in a couple other bits from the company. June 2024 Edited August 13, 2024 by ballistic 3 Quote
ballistic Posted August 20, 2024 Author Posted August 20, 2024 (edited) Front bumper respray and mod. Plus tidying up intercooler etc My previous front bumper paint job was poor and also stone chipped away very quickly and so i needed to get it redone after less than 18 months. While it was away i decided to freshen up my intercooler as it was looking tired. The powder coat was all dull and some fins were damaged. Also there was some oxidisation taking place. I sanded down the surface, removing the damage and creating a more level finish. And also painstakingly straightened any damaged or bent fins. And began painting You can see here how much cleaner it is now Back on the car Came out really nice. Lovely high metallic finish and vht clear coat to protect it. Looks like metal. Also wire brushed the flaking finish of the power steering cooler and gave it a fresh coat. Before After Now onto the juicy bit. While the bumper was getting sprayed i had a little change made. Ive had this Nismo v1 for many years and fancied a change so i had the middle cut away Scary move, and irreversible. But after the holes being glassed in and the bumper sanded and painted i think it turned out great. Before and after Much better paint job this time and the mod is very aggressive, a little different from other V1s out there and a nice change for me. Edited August 20, 2024 by ballistic 3 Quote
ballistic Posted September 6, 2024 Author Posted September 6, 2024 (edited) Couple of exhaust vids as requested. Volume up 🎵 First revs after hours of work in the garage fabricating the exhaust Very short tunnel pull 2nd and 3rd pull Spotted leaving a show Pulling into the meet @The Bounty Bar Kid especially for you mate 😅 Edited September 6, 2024 by ballistic 7 Quote
ballistic Posted September 22, 2024 Author Posted September 22, 2024 (edited) Sequentials everywhere! While having some other mods done, meaning the rear bumper and wing were off being customised, i took the opportunity to fit sequential indicators to the rear and front wing of the Zed. Unlike the front bumper ones which i made myself these were a relatively simple affair, just some soldering and shrouding. All attached using waterproof connectors. Fronts Sides Rear Set the rear DRL/fog lights on a switch. Also the reverse lights are much brighter than before. Which was one dim bulb on the drivers side. Reversing in the dark used to be a gamble 🫠 Edited September 22, 2024 by ballistic 6 Quote
HEADPHONES Posted September 22, 2024 Posted September 22, 2024 Never seen sequencials in the front bumper before 1 Quote
Andy_Muxlow Posted September 23, 2024 Posted September 23, 2024 I do love a sequential indicator 1 Quote
ballistic Posted November 18, 2024 Author Posted November 18, 2024 (edited) Custom vents For a long time now I have had some ideas for bodywork modifications I wanted on my Zed but I couldn't find a place that sells something I want. I also didn't want carbon and poor fitting FRP parts. I happened to come across a place called Sussex Studio recently and after some chatting and sending photoshops of what I want it seemed I had found the right place for what I had in mind. So they got to work: These are OE metal wings customized with vents. All welded and ready for paint And similar vents were put into my JDM style bumper. Once painted it was on to fitting This was an absolute nightmare as the bookshop who fitted my nismo skirts decided to use tiger seal and try as we might we couldn't get to the bolts for the wing. Eventually after hours we got there Then it was time to redo the bumper tuck and refit the nismo spats Im extremely pleased with how this came out and looks amazing, just how I'd imagined. However, anyone who knows gunmetal paint WV2 knows it's almost impossible to get a good match. Neither myself nor the body shop were happy with the match despite their best attempts. So we needed to do something about the paint... Edited November 18, 2024 by ballistic 10 Quote
ballistic Posted April 27 Author Posted April 27 On 03/01/2025 at 21:01, Olly350z said: Are you local to Sussex then?? Sorry just saw this. No im over in NE london/Essex area Quote
ballistic Posted May 20 Author Posted May 20 (edited) (Following directly on from my last post) So there was nothing for it, we decided on a full shell respray to get it perfect: While we were at it we deleted the aerial It came out looking great but we wasn't quite finished yet A couple weeks later we spent a full day cutting and polishing the new paint, and I mean a FULL day. Exhausting Finally ready to leave And the finished product The only thing that wasn't painted is the bonnet as I have plans for that. Overall I'm extremely pleased. We removed all the dents and imperfections and it's basically flawless now. And one colour. Anyone who knows me, knows I take care of the paint as best I can, now I have a clean canvas to work with. Big thanks to Sussex Studio! Edited May 20 by ballistic 4 Quote
ballistic Posted October 28 Author Posted October 28 (edited) Ok with large exterior changes recently I turned my attention back to the interior. After having wrapped the dash in Alcantara, including A pillars and door armrests. I went back and forth on what to do with the centre waterfall area on the dash. Wrap it? Paint it? Hydro dip? 😕 With the success of my earlier Alcantara wrapping and how much i liked the finish I decided to give it a bash on this piece too, I knew it would be my hardest piece as it's much more intricate and has many cut-outs etc, pretty intimidating. 🫠 Gave it a proper clean and prep for adhesive: Apply adhesive, Cut out material and lay over piece and smooth down, removing any creases Cut off main large excess material and work over all corners and edges, carefully applying more adhesive in those areas without getting it on the face of the fabric, fun times. This is the most fiddly, messiest and most time consuming step. Now for the trickier piece lol... This is how the underside looks Finished: I also did the airbag/centre part of the steering wheel, don't worry it's just on the cover 😅 This a very tricky and time consuming job, with lots that can go wrong lol. But I'm very pleased I went this route. It looks fantastic imho. Very premium and sporty. Edited October 28 by ballistic 1 Quote
ballistic Posted October 28 Author Posted October 28 (edited) Next I had the big idea of changing the colour of all the silver trim in the interior... I dunno why, I guess I like the punishment 😅 Here's most of the bits that will need doing: Steering wheel button surrounds Indicator stalks Main cluster dials facia plate Buttons on either side of the main cluster Heater vent surrounds Door handles (including lock buttons) Rings on centre gauges Rectangle bezel that goes over my tablet install Rings around heater controls Big silver ring around the shifter boot Handbrake button 🙃 The trim piece on the back of the gauge cluster you can only see when looking from the outside... So I got to stripping the interior, carefully! Then it was onto prepping and masking, scuffing all pieces and cleaning with IPA. No going back now 🫣 Masking took an age as it had to be perfect and there were many difficult areas to cover, but any mistakes would mean unsightly overspray or silver not being covered. Next step will be paint! Edited October 28 by ballistic 2 Quote
ShortPaul Posted October 28 Posted October 28 7 hours ago, ballistic said: Ok with large exterior changes recently I turned my attention back to the interior. After having wrapped the dash in Alcantara, including A pillars and door armrests. I went back and forth on what to do with the centre waterfall area on the dash. Wrap it? Paint it? Hydro dip? 😕 With the success of my earlier Alcantara wrapping and how much i liked the finish I decided to give it a bash on this piece too, I knew it would be my hardest piece as it's much more intricate and has many cut-outs etc, pretty intimidating. 🫠 Gave it a proper clean and prep for adhesive: Apply adhesive, Cut out material and lay over piece and smooth down, removing any creases Cut off main large excess material and work over all corners and edges, carefully applying more adhesive in those areas without getting it on the face of the fabric, fun times. This is the most fiddly, messiest and most time consuming step. Now for the trickier piece lol... This is how the underside looks Finished: I also did the airbag/centre part of the steering wheel, don't worry it's just on the cover 😅 This a very tricky and time consuming job, with lots that can go wrong lol. But I'm very pleased I went this route. It looks fantastic imho. Very premium and sporty. Loving you're work mate, thanks for sharing the pics 1 Quote
