Nismoandy Posted June 12, 2020 Author Posted June 12, 2020 Hi Andy me to ,but mostly it will make the installation a bit easier as i can reuse the power steering and air conditioning line's from the car which is a big bonus Quote
Nismoandy Posted June 17, 2020 Author Posted June 17, 2020 (edited) Quite a lot of the mechanical side of the build has been done. The prop shaft is going to be installed just a photo to show the difference in length of the the original 350z carbon fibre to the new shorter prop shaft. I have purchased water pipes and vacuum lines ,and intend to get them install in around two weeks time but first I will be tackling the wiring, with some help as I hate wiring Edited June 17, 2020 by Nismoandy 3 Quote
KuroKiddo Posted June 18, 2020 Posted June 18, 2020 Good job so far! Are you running the Wiring Specialities loom? Also what are you doing for the exhaust manifolds? 1 Quote
Nismoandy Posted June 18, 2020 Author Posted June 18, 2020 (edited) On 18/06/2020 at 04:40, KuroKiddo said: Good job so far! Are you running the Wiring Specialities loom? Also what are you doing for the exhaust manifolds? So the wiring, is a stand-alone, so the ecu and engine wiring is completely separate to the ECU in 350z, lighs etc so yes Wiring Specialities loom ,quite amazing stuff to be honest I will try to explain when once we have some progress on the wiring but I'm no expert. Ps. (I'm expect the dashboard to light up like a Christmas tree)who said wiring wasn't fun. The exhaust manifold and starter motor and steering rack which is positioned on the driver side has been a challenge as there is not much room for clearance on all three items to work properly without interfering with each other it would have been better if the starter motor had been positioned on the passenger side but the kit does not allow for this. I have managed to find and enough room for this to work without interferences with each other. I will try me best to put some photos to show when I have finished install. Edited September 7, 2020 by Nismoandy Info Quote
Payco Posted June 18, 2020 Posted June 18, 2020 You are doing an amazing job on this Andy and I have enjoyed our phone chats along the way exchanging project stories. Keep up the good work mate. 1 Quote
Nismoandy Posted June 26, 2020 Author Posted June 26, 2020 (edited) Small update the vacuum pipes and water pipes installed and just waiting on a few more parts to carry on Edited June 26, 2020 by Nismoandy 3 Quote
Nismoandy Posted June 29, 2020 Author Posted June 29, 2020 Been tidying up the pipe runs and in some places secured them , so as they can not to rub on anything that might damage them . Also I was mucking with the air filter . 3 Quote
Nismoandy Posted July 2, 2020 Author Posted July 2, 2020 (edited) Installed the oil filter relocation kit from sikky . Also Connected the fuel pipe to Ls fuel rail, Surprisingly, a standard Nissan click on fuel connection works Edited July 2, 2020 by Nismoandy 5 Quote
Nismoandy Posted July 4, 2020 Author Posted July 4, 2020 (edited) Onto the next stage now with the wiring , this is stage where there's not a lot to show you but here's a couple of photos to give you a rough idea and it will take a while to complete so I probably won't post for couple of weeks ( just a note to everyone this part of the wiring loom has now been updated with a different version from wiring specialists) Edited January 9, 2023 by Nismoandy update 3 Quote
Mark@Abbey m/s Posted July 5, 2020 Posted July 5, 2020 awesome build , Wiring specialities loom are pretty much plug and play , I presume your using the LS ECU so are you using the CAN BUS translator so the stock car is happy? 1 Quote
Nismoandy Posted July 6, 2020 Author Posted July 6, 2020 Yes pretty much as you say, the Nissan ecu will run everything around the engine ,and a separate ecu will run and translate the LS engine Quote
Nismoandy Posted July 12, 2020 Author Posted July 12, 2020 (edited) sorry I double up Edited July 12, 2020 by Nismoandy I double up! Quote
Nismoandy Posted July 12, 2020 Author Posted July 12, 2020 I have had the order for the wiring loom ecu etc,for a while I have continuing with the build I haven't chased up my order with them, Wiring specialities supply a fantastic product won I'll share with you once it's installed using all of your factory instruments and adding a couple of cool features, but because of the pandemic there's a back log of orders and I won't receive mine for two months , so that means a bit of a go slow for the build although I would like to push on i will go over what I have done and make sure that it's OK. 1 Quote
Rs2oo Posted July 28, 2020 Posted July 28, 2020 Keep up the good work man. Can't wait to hear it !!!! 1 Quote
Payco Posted July 28, 2020 Posted July 28, 2020 looking forward to see this in a couple of weeks when we meet up. Great project and awesome use of knowledge and skills. Full marks for taking this on. 1 Quote
Nismoandy Posted July 28, 2020 Author Posted July 28, 2020 Thanks for your best wishes much appreciated . I still am waiting for the rest of the wiring loom. But hopefully in 3 weeks time I'll have all of the wiring when I get a chance next week I will update the progress on the bit's and pieces, tidy up etc 2 Quote
Nismoandy Posted August 4, 2020 Author Posted August 4, 2020 Had Some good news today . The wiring has turned up So cracking on with the build Very pleased with the quality of the wiring loom 3 Quote
Nismoandy Posted August 5, 2020 Author Posted August 5, 2020 (edited) https://youtu.be/YAsEumZvLPg Throttle cable is installed Edited August 5, 2020 by Nismoandy 3 Quote
Payco Posted August 5, 2020 Posted August 5, 2020 Good work Andy and another step forward and closer. Looking forward to seeing it Sunday. 1 Quote
