Locking wheel nut snapped/sheared clean off
Stuggerz
Two options I can think of:
It will have to be drilled out, ...a PITA tbh and if you're not careful doing it then you will damage your alloy wheel as well as your hub.
Other option I can think of is to drill a small hole into the snapped bolt, ...then you will need to either tap the hole to fit a smaller size bolt or use an epoxy to fix a smaller size bolt into the hole which once set you use to unscrew the sheered locking nut.
This happened to mine, I just went down to the local tyre place where they had a nut removal tool (most of them have these) and it was off in 2 seconds as if it was a normal nut. Don't panic it's really easy and not a hassle :lol:
I have more to work with. I can get a pair of pliers to grip the remaing. But havnt got the beans to rotate it. I rotated it a little bit on full hulk mode... but my skeletor arms couldnt generate the power lol
from your first pics it seems that the locking nut has come apart in 2 peices so the nut is still on and not the bolt snapped so it just a case of finding something thatll grip the bit of the nut left.
got a pick of whats left?
Update.
Locking nut off. Pushed a 19mm 12 star socket onto it. Luckily it came off no bother.
The stud on my spacer was too long for the locking nut. Lol
No locking wheel nuts in sight :)
Edited by Stuggerz
  • Like 2
