V1H
Project: WeaponiZed
Recommendations appreciated!
I did it anyway, wrapped my roof in gloss black, too :blush: [Hexis SKINTAC #HX20890B]
Quite like Tint Studio's job. (But I can always undo a vinyl wrap, or part of it. )
Roof wrap
Roof wrap
Roof wrap
Edited by V1H
  • Like 2
Share this post
Link to post
Well just had my RHD AAM TT 370Z dyno'd.
Results really poor for me.
340whp
7psi
E85
12°Timing
Remote/flash tune
Thinking I should get a proper dyno tune.
Do you know how much timing is in your build?
Share this post
Link to post
340whp
7psi
E85
12°Timing
Remote/flash tune
That dosnt sound right get that thing custom tunned by somone
Share this post
Link to post
Yeah definitely cannot be rite.
The thing that makes me sad, is that it was remote tuned by Sebastian of SpecialtyZ. He is known as the 370Z god in the tuning world.
Now I am very unimpressed with that  result (only 90hp more than stock) I will just go get a proper dyno tune lol!
Share this post
Link to post
Oh ok what did he think you should see ?
Share this post
Link to post
Ok well he got back to me. He said it is a very conservative tune and if we want we can add pwr.
Wonder why we stopped there in the first place??
So I asked if we can continue to add pwr without comprimising too much safety and reliability of the motor. Will see what he says what he gets back to me.
Another tuner looked at the ecutek log i sent him, and he said I was only on 8° timing and on my setup I should be around atleast 16°.
Share this post
Link to post
Tbh if I was tuning remotely, I’d go super-conservative too.
Share this post
Link to post
I think to get it making more power and safely you would need to spend a lot of time back and forth with files
So maybe that what it needs
Why don't you speak to jezz at Horsham who tunned renne and I'm sure he would be able to get you running like him as his just done his?
Just a thought
Share this post
Link to post
Just a thought
Thats a possibility yeah, but if I was going to get another tuner I would probably go local dyno this time.
My current remote tuner has tuned 100+ TT 370Z, so he would have his reasons to go super conservative on me, like Ekona said maybe because it's done remotely and he can't hear/see the car in person. I don't knows lol
But yeah, 340whp is not worth the investment I put into the car, so I definitely want to get more power added one way or another. :)
Share this post
Link to post
I agree, at 7 psi you should see another 100bhp on top of your current result. I dont know my timing, but i know I have a very safe (rich) A/F. As u see from my torque plot, it drops quite steeply in the upper rpm range. I’m guessing Jez pulled my timing there to completely eliminate knock. (Very conservative tune). AAM actually recommend disabling knock and ignoring mild knock up top. But that was a no-go for Jez :lol:
Either way, definitely go get a proper local tune. I reckon, Sebastian will have (blindly) added a huge safety marging in timing and/or fuel maps.
Edited by V1H
Share this post
Link to post
Yeah and if it's that rich it will just be bore washing for fun surley ?
Share this post
Link to post
Hey yeah Seb just told me he went very conservative on me because of the traction issues I was having.
He said he can add timing now for more power. Im only at 8° atm. Heavily under tuned.
Share this post
Link to post
Hey V1H, wre you getting any boost creep issues?
I have just started to experience boost creep again recently. It was fine for the past 3 weeks and then it just started happening out of no where :(
Share this post
Link to post
How do you notice boost creep?
My boost does droop as rpm rise (see below dyno plot), but it has been doing so from day 1. I understand this might be normal but also read it can be due to slightly too soft WG actuator spring load but has nothing to do with a boost leak.
When I observe my Boost gauge I can confirm my boost decreases from 0.44bar @3500 to 0.33bar @7000 (I'm driving on the green Low-Boost setting) but this behaviour is stable.
Edited by V1H
Share this post
Link to post
Boost creep does the opposite. The boost will cotinually rise up past the set the target as RPM increases, it can rise upto dangerous values where AFR will lean out.
For example, for the past few weeks my boost has been pretty stable sitting around 7-9.9 psi max.
But just recently it started playing up and goin much past the usual reading of 7-9.9psi.
It reached 14 psi with just 4500rpm. If I kept the throttle down the boost would have gone higher.
Not sure why this started happening but will hopefully have it sorted out soon. :(
Edited by shadow85
Share this post
Link to post
What controls the boost?  Wastegstes
Share this post
Link to post
 Yeah I just started reading up on the causes.
So, if it was fine for a few weeks and then it just starts playing up, is the wastegate become faulty just recently or something?
Share this post
Link to post
Wow, 14 psi that is risky high! :scare: Would quickly make your motor pop.
Either the WG goes south, or maybe, you have a leak in the vacuum hose so the BCSV doesn't apply enough vacuum to open the WG?
Share this post
Link to post
Ok found the issue. Vaccum line melted closed from heat when it was on the dyno. Got it replaced with braided lines, won't melt anymore lol.
But now another issue, damaged front right wheel because I punched the pedal in 3rd at low speed and it threw me into the curb very quickly. :(
yeah, it was my fault for being a dick head...
Fml lol
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
