TORQEN Big Brake Kit
Adrian@TORQEN
 Share
370z-TORQEN-8pot-red-07.jpg370z-TORQEN-380mm-356mm-8-6pot-blue-01.j
370z-TORQEN-380mm-356mm-8-6pot-red-01.jp
1. TORQEN START Big Brake Kit
Front: 6 Pot 330x32mm
Rear: 4 Pot 304x22mm
Compatible pads
F: Pagid 1361, AP Racing CP3125D50, AP Racing CP3125D46, Hawk HB-110, Ferodo FRP216, Wilwood 8517
R: AP Racing CP2340D40, AP Racing CP2340D38, AP Racing CP2340D43, Alcon 1749, Hawk HB-107, Ferodo FRP3091
2. TORQEN L Big Brake Kit
Front: 6 Pot 356x32mm
Rear: 6 Pot 330x28mm
Compatible pads
F: AP Racing CP5070D51, AP Racing CP3894D51, Hawk HB-121, Hawk HB-109, Ferodo FRP3076, Pagid 8018
http://torqen.uk/product-images/2016-07-28_10-57-55.jpeg
3. TORQEN XL Big Brake Kit
Front: 8 Pot 356x32mm
Compatible pads
4. TORQEN XXL Big Brake Kit
Rear: 6 Pot 356x28mm
Compatible pads
R: Pagid 1361, AP Racing CP3215D50, AP Racing CP3215D46, Hawk HB-110, Ferodo FRP216, Wilwood 8517
5. TORQEN MONSTER Big Brake Kit
Front: 8 Pot 380x32mm
Compatible pads
6. TORQEN XTREME Big Brake Kit
Front: 8 Pot 405mm x 36mm
Rear: 6 Pot 380mm x 32mm
Compatible pads
F: Porsche Cayenne 17Z, Brembo P85 069, Pagid RS29 17Z, Hawk HB0512
Other size disc or calipers will be available on request, feel free to ask.
Extras:
- powder coating
- floating discs - 330mm or more - all 4
TORQEN brake kits are precision CNC engineered from the finest materials, directly replacing the 350z or 370z stock brakes. Calipers are guaranteed for 2 years and brake discs for 6 months.
The brake discs are manufactured from high grade FC30 iron alloy and all come with anti-rust coating. Large vents are built into the discs to dissipate the heat more efficiently. The center caps are made from aerospace grade aluminium with hard anodising electrolyte treatment for better durability. The discs are manufactured to a tolerance of +/- 0.02mm to ensure perfect balancing.
The floating disc are optional and allow the braking surface to float on the hub, negating the effect of the metal expansion when it gets extremely hot and reducing the possibility of discs warping. They also improve heat dissipation, cooling down a lot faster than the standard 2-piece rotors, which reduces brake fade over prolonged periods of heavy braking, like on track days.
Hats are anodised in black, we're looking to offer colour co-ordination with the calipers in the future, but at the moment we want to keep the prices as low as possible to make these kits affordable for everybody willing to upgrade their brakes.
The brake pads included with the kit come with heat plates to improve heat dissipation and reduce the noise. Replacement brake pads are available from either TORQEN or any major brake pad manufacturer, like AP Racing, Alcon, Hawk, Ferodo, Pagid, Wilwood, Brembo.
Sport pads are are included as standard. These are suitable for both track and road use. You would have to push them extremely hard to make feel any fading at all. They are the best compromise for cold bite and reduced noise.
TORQEN Big Brake kits come with DOT compliant stainless steel braided brake lines with waterproof PVC clear coating. These don't require any additional adaptors. They also come with clips attached for easy fitting.
The brake brackets supplied are made from high strength steel alloy making them strong, durable and reliable. No further modification or adaptors are required when fitting to your vehicle.
What's in the box:
4 x calipers made from high quality 6061 T6 heat treated aluminium, squeeze forged and finished with an anti-rust coating
4 x mounting brackets made from high strength steel alloy
4 x high grade FC30 iron alloy with anti-rust coating discs with centre caps
4 x DOT compliant stainless steel braided brake lines with waterproof PVC coating
1 x set of bolts and shims
1 x set of sport brake pads - 0-550C, friction coefficient: 0.40-0.45u
2 x bottle of threadlocker solution
2 x bottle of Motul RBF660 brake fluid
1 x bottle of touch-up paint (for powder coated calipers only)
Colours available:
a. ANODISED
B. POWEDER COATING
Please note:
- the 7 day cooling off period law does not apply to any TORQEN Big Brake Kit and we do not accept returns as they are all made-to-order and customised to your specifications, such as: caliper colours, disk patterns and other optional extras.
- for warranty claims made after the initial 7 days and within the allocated warranty period, TORQEN will provide you with replacement parts free of charge and will also cover any shipping costs incurred.
- during the allocated warranty period, in rare cases you may be required to return goods to TORQEN for analysis before we can ship replacement parts to you. In this case TORQEN will cover the shipping costs.
- the warranty will not apply if damage, malfunction or failure results from race driving, alterations, accident, misuse, abuse, fire or mis-adjustment.
- TORQEN big brake kits are made-to-order, once your order has been confirmed, it is final and may not be cancelled. Changes may be permitted depending on when they are requested or what you would like to change. Acceptance of modification is at our discretion.
- TORQEN guarantees brake kits will fit your vehicle, but does not guarantee that any wheels will fit over our big brake kits. The wheels sizes stated here are a guide only. It is your responsibility to request a wheel fitment template before ordering in order to check and ensure your wheels are big enough to fit over the TORQEN big brake kit.
Fitment templates here:
350z F 356mm, 6 & 8 pot
370z F 356mm, 6 & 8 pot
370z F 380mm, Big 8 pot
370z F 405mm, Big+ 8 pot
How to use the template
Available to order here:
350z kits
370z kits
Spare parts prices:
Standard 2pcs discs - 2 pieces - with bells - pair
405mm - £849
380mm - £799
356mm - £699
330mm - £649
Standard 2pcs discs - 2 pieces - no bells - pair
405mm - £699
380mm - £649
356mm - £549
330mm - £499
Pads - pair:
SPORT:
Small 8 pot | Big 6 pot - TRQ914 - £329
Small 6 pot - TRQ908 - £299
Big 4 pot | Small 4 pot - TRQ612 - £269
RACE:
Big 8 pot - TRQ923 - £479
Small 8 pot | Big 6 pot - TRQ914 - £469
Small 6 pot - TRQ908 - £429
Big 4 pot - Small 4 pot - £399
8 POT calipers anodised colour 2
6 POT calipers in anodised colour16:
380mm standard disc 2 pieces:
380mm floating disc:
380mm vs 356mm disc size comparison
Torque settings below:
Bedding procedure:
http://torqen.uk/docs/TORQEN-brake-bedding.pdf
Well I was going to buy a new Nismo but when the dealer offered me £12,000 for my zed against a £38,000 Nismo I decided to go down the route of upgrades on my car and use the money this way ( still the cheaper option so far). Ooooeer
It may be a 2009 but it's immaculate and I ain't letting it go for that, so I'm keeping the car looking totally standard but heavily modding it under the skin
I still smile at the look on the salesmans face when I told him to work his deal where the sun don't shine and bid him a polite good day :)
Fair play ..... Although I have grown to like the nismo , it's just a 70 dressed up for dinner in reality , they really should have tweaked the engine alot more ( around 370bhp ) ..... Your will be an absolute sleeper / weapon once finished :)
  • 1 month later...
 Share
