Kraziekatz1 Posted March 21, 2015 Posted March 21, 2015 Hey guys, have an 04 350z. It is making a grinding/scraping noise from rear left wheel area when turning right. It's not a knocking noise or similar to when the banana arms went. It's not a squealing noise like a bearing. Not noticed any difference in handling, suspension feels ok. Just put it up on a ramp and everything looks tight and ok. Just wondered if anyone had any ideas? it's definitely a grinding/scraping noise from the rear when turning right only......did have new tyres fitted recently, but can't see anything unusual. Quote
johnny cobra Posted March 21, 2015 Posted March 21, 2015 Check your rear disks and back plate ......... JC 1 Quote
glrnet Posted March 21, 2015 Posted March 21, 2015 There's a metal guard on the discs it could be that scraping on the disc, you can bend it away from the disc with your hands. And what JC said ^ 1 Quote
GIXXERUK Posted March 21, 2015 Posted March 21, 2015 does the noise stop if you brake when turning ? I would check the pads for wear, the rear of the discs for rust/damage, dust shields for damage or stones and play on the bearings 1 Quote
350zedd Posted March 21, 2015 Posted March 21, 2015 Jack the back end up, and rock the wheel from side to side to see if you can feel any play in the bearing. Spin it too, while you are there, and listen for any strange noises. 1 Quote
Kraziekatz1 Posted March 21, 2015 Author Posted March 21, 2015 Thanks guys, will take a look at the brakes next. Quote
RS8055 Posted March 21, 2015 Posted March 21, 2015 I had exactly the same problem... time for new discs and pads... getting them fitted at Kaizer Motor on Monday afternoon 1 Quote
RS8055 Posted March 21, 2015 Posted March 21, 2015 Best advice I can give is to roll your thumb along the discs to the edge, and check for a lip at the edge indicating how worn the discs are. Also, remove the wheel to check how much you have left on the pads Quote
Kraziekatz1 Posted March 21, 2015 Author Posted March 21, 2015 Well the Brake discs look mint, pads in really good condition as well. No unusual movement/noise when the wheel's jacked up. I've had a bearing go on a different car and this is a completely different noise so I'm thinking probably not the bearing (bound to be wrong now I've said that). Being a bit of a girl, what's the back plate? Dust shield? Quote
GMballistic Posted March 21, 2015 Posted March 21, 2015 Well the Brake discs look mint, pads in really good condition as well. No unusual movement/noise when the wheel's jacked up. I've had a bearing go on a different car and this is a completely different noise so I'm thinking probably not the bearing (bound to be wrong now I've said that). Being a bit of a girl, what's the back plate? Dust shield? Yep the back plate is a dust shield. Some times they can get a bit bent & rub against the disc or even trap stones between them & the disc. When you checked the pads where you able to see the inside pad (closest to the inside of the cars body if that makes sense) and not just the outside one? Sometimes people have had uneven pad wear so the outside one could look ok but then the inside one is fubar. Just a thought. Quote
GIXXERUK Posted March 21, 2015 Posted March 21, 2015 Well the Brake discs look mint, pads in really good condition as well. No unusual movement/noise when the wheel's jacked up. I've had a bearing go on a different car and this is a completely different noise so I'm thinking probably not the bearing (bound to be wrong now I've said that). Being a bit of a girl, what's the back plate? Dust shield? did you check the rear of the discs ? Quote
Kraziekatz1 Posted March 22, 2015 Author Posted March 22, 2015 Well the Brake discs look mint, pads in really good condition as well. No unusual movement/noise when the wheel's jacked up. I've had a bearing go on a different car and this is a completely different noise so I'm thinking probably not the bearing (bound to be wrong now I've said that). Being a bit of a girl, what's the back plate? Dust shield? did you check the rear of the discs ? Discs & pads look good on both sides. Really struggling to identify where noise is coming from Quote
Toon Chris Posted March 22, 2015 Posted March 22, 2015 Both my rear bearings sounding like gravel being ground up as they went. I suspect the bearing, especially as its noisy when you load it up. They are not all that expensive and not hard to fit. Any decent garage will manage it in an hour or so, providing the old one come off ok. 1 Quote
choptop Posted March 27, 2015 Posted March 27, 2015 If you are set on buying this car, get an expert in to look at it. Quote
glrnet Posted March 27, 2015 Posted March 27, 2015 If you are set on buying this car, get an expert in to look at it. Rich, she already owns the car Quote
glrnet Posted March 27, 2015 Posted March 27, 2015 Well the Brake discs look mint, pads in really good condition as well. No unusual movement/noise when the wheel's jacked up. I've had a bearing go on a different car and this is a completely different noise so I'm thinking probably not the bearing (bound to be wrong now I've said that). Being a bit of a girl, what's the back plate? Dust shield? did you check the rear of the discs ? Discs & pads look good on both sides. Really struggling to identify where noise is coming from Maybe a visit to TGM at Fleet or Jez at Horsham Developments (Newbury) Quote
Ebized Posted March 27, 2015 Posted March 27, 2015 Possibly the hanbrake? (separate shoes) - see this thread for more info: http://www.350z-uk.com/topic/88876-weak-handbrake-and-slight-roll-after-application/ Quote
