coldel Posted October 23, 2014 Posted October 23, 2014 ...one of my customers from back when I ran my own little local detailing business called me up and asked for some work on his RS4, did it this morning (on my day off from my day job!), detox shampoo, SRP then three layers of Supernatural and very pleased with the results - fantastic stuff and recommend it I also have been using AG Fast Glass, comes up pretty well for a budget option. 1 Quote
GIXXERUK Posted October 23, 2014 Posted October 23, 2014 that looks Col my fav wax is supernatural, not as long lasting as some others but the shine compensates Quote
coldel Posted October 23, 2014 Author Posted October 23, 2014 Cheers, you can get sample pots for about £15, good for four layers on a medium sized car. Quote
Wasso Posted October 23, 2014 Posted October 23, 2014 Nice Col, really nice. 3 layers? I hope not all in the same session?? Quote
GIXXERUK Posted October 23, 2014 Posted October 23, 2014 Cheers, you can get sample pots for about £15, good for four layers on a medium sized car. I always use the panel pots (tight) I don't know how you did all that in half a day !! Quote
coldel Posted October 23, 2014 Author Posted October 23, 2014 (edited) Nice Col, really nice. 3 layers? I hope not all in the same session?? Sorry, not sure why I put 3 , 2, and no not in the same hit! Edited October 23, 2014 by coldel Quote
coldel Posted October 23, 2014 Author Posted October 23, 2014 (edited) Cheers, you can get sample pots for about £15, good for four layers on a medium sized car. I always use the panel pots (tight) I don't know how you did all that in half a day !! 6am start Feel pretty tired now, although booked in a massage at 2:30 today, reward! Edited October 23, 2014 by coldel Quote
coldel Posted October 23, 2014 Author Posted October 23, 2014 'earnt my day off today, currently under a duvet on the sofa half asleep with laptop and tv remote on the side deciding whether to watch Top Gear or Sherlock, cup of tea in hand, life is good Quote
sipar69 Posted October 23, 2014 Posted October 23, 2014 I'm also a fan of Supernatural. Not cheap and requires a bit more work than some waxes but great finish. I believe this picture of my previous 370 was taken after it was used. Quote
hensh65 Posted October 23, 2014 Posted October 23, 2014 Cheers, you can get sample pots for about £15, good for four layers on a medium sized car. I almost used the full tub in one go on the 350z I like to smash it on Quote
roscopervis Posted October 23, 2014 Posted October 23, 2014 I think I could get loads of layers out of a 15 ml pot. Also, putting on many layers of wax a day doesn't allow the previous layer to cure, so you just wipe the previous away. Many carnauba waxes need about a day to cure properly. Some products do allow quick layering, but these are usually sealants. Finish comes from the prep work mainly. Any last stage product adds very little in reality, particularly if you don't know what's on the car. It's a bit like the red wine or hi-fi cable debates. IMO of course. 2 Quote
Sy1441 Posted October 24, 2014 Posted October 24, 2014 Cheers, you can get sample pots for about £15, good for four layers on a medium sized car. I almost used the full tub in one go on the 350z I like to smash it on I'm with you Chris, Lather it on!!! 1 Quote
Ekona Posted October 24, 2014 Posted October 24, 2014 I managed to get about 2-3 years' worth out of a DJSN panel pot, across multiple cars. No need to chuck it on, once a panel is protected then it's protected: By adding extra layers you either just waste it (if the wax hasn't cured properly) or you just delay putting the next lot on when you do a proper wash by a bit. Done correctly, a single layer of LSP should be more than enough. Yes, I've tried layering waxes before over the course of a week, but in all honesty it didn't give me noticeable extra results. Each to their own though, that's the beauty of things like this 3 Quote
Wasso Posted October 24, 2014 Posted October 24, 2014 I've found that applying one layer, cure for 24 hours and then apply a second coat only increases the length of time in which you'll need to re-apply. For instance, 1 layer will give you around 1 month and 2 layers around 3 months. 1 Quote
d95gas Posted October 24, 2014 Posted October 24, 2014 How does this compare to the Supnatural Hybrid ? unsure of which one to try, either the Hybrid or the V2 Super Premium ? Quote
ioneabee Posted October 24, 2014 Posted October 24, 2014 I bought the hybrid by mistake - won't be doing that again - plain old supernatural is way better Quote
Sy1441 Posted October 24, 2014 Posted October 24, 2014 I managed to get about 2-3 years' worth out of a DJSN panel pot, across multiple cars. No need to chuck it on, once a panel is protected then it's protected: By adding extra layers you either just waste it (if the wax hasn't cured properly) or you just delay putting the next lot on when you do a proper wash by a bit. Done correctly, a single layer of LSP should be more than enough. Yes, I've tried layering waxes before over the course of a week, but in all honesty it didn't give me noticeable extra results. Each to their own though, that's the beauty of things like this You managed to get 2-3 years out of 30ml of wax on multiple cars? I'll not lie, thats pretty amazing. Quote
GIXXERUK Posted October 24, 2014 Posted October 24, 2014 I managed to get about 2-3 years' worth out of a DJSN panel pot, across multiple cars. No need to chuck it on, once a panel is protected then it's protected: By adding extra layers you either just waste it (if the wax hasn't cured properly) or you just delay putting the next lot on when you do a proper wash by a bit. Done correctly, a single layer of LSP should be more than enough. Yes, I've tried layering waxes before over the course of a week, but in all honesty it didn't give me noticeable extra results. Each to their own though, that's the beauty of things like this You managed to get 2-3 years out of 30ml of wax on multiple cars? I'll not lie, thats pretty amazing. Agree with dan, I've done the same, less is more, the excess is a waste just making work for yourself, a slight haze is enough 24 hr cure to layer as been said Quote
Sy1441 Posted October 24, 2014 Posted October 24, 2014 In that case I reckon i must have enough wax to polish all the forums cars until the zombie apolcalyse hits! lol 1 Quote
ilogikal1 Posted October 24, 2014 Posted October 24, 2014 I'll also agree with Ekona and Roscopervis, I've done numerous layers on a number of cars and I'm barely half way through any of my panel pots. Although I will disagree with Ekona on layering Dojo Juice waxes (at least PH & BV) as per my recent wax test as a second later did appear to extend the durability - they were applied more than 24 hours apart in my case and only apparent on the Dodo Juice waxes though. You don't achieve anything other than wastage by slapping it on thick either, if anything it just makes it more difficult to remove or it won't last as long due to the wax that's actually in contact with the paint not curing, and therefore bonding, properly. 1 Quote
Ekona Posted October 24, 2014 Posted October 24, 2014 You're right, they do extend the durability, I just prefer to reapply a bit more often. That's a personal thing though. 1 Quote
ilogikal1 Posted October 24, 2014 Posted October 24, 2014 Yeah, I'm with you now - it's been a long day. Quote
