Veeg33's slow dose of Zeditus......
Good to know Veeg. Blueprint do loads of great OEM spec Japanese parts so I'm sure you'll never have to worry about that again. :thumbs:
Yep, that's what I saw on their website. I've registered for free there (catalogue part number look up, BluePrint Live!) and they supply quite a number of 350z parts.
http://www.blueprint-adl.com/
  • 1 month later...
Posted (edited)
Seen other fellow members here installing reversing camera and for the price (EBay specials), I've decided to give it a go.
Brought a CCD cam (number plate light + cam) and a 4.3" monitor for EBay. EBay item number for the camera 271736771908 and the monitor 391106460484
Disassembled most of my rear boot panels
Thanks to this plastic removal tool (as long as my hand) , makes removing them easy
Feed the cable into the rear bumper and used a metal wire to hook it so that I can tape the camera cable to a pilot cable that will help me to feed/guide it into the boot.
Remove the rubber grommet, feed the pilot cable into it and tape it to the camera cable.
Instead of cutting a slot on the rubber grommet, I decided to feed those cable into the tiny hole. With a little bit of lubricant, they just managed to fit in.
The trick is to feed it in whilst the connector is facing the other way ie fold the cable 180deg and start from the smaller end of the connector and slowly push it in. Be careful not to damage cable as they are not the best quality, and try your best to avoid pulling the cables when you are stuck, put the connector.
Feed both in, add some insulation tape and replace it back to its original position.
Next it to locate a good ground location, I choosen this one here.
I had tested my camera and screen before, so did not bothered testing it again on my zed.
Then I locate the reverse light cable which is near to the passenger side rear light. It is light green with a silver ring at every 5cm or so.
Then using a Scotchlok T-tap, I tap into the cable to power up the camera and monitor.
Route all cable nicely, and use lots of tie wrap to secure them, ensuring minimum movement to avoid cable fretting due to vibration.
As for the monitor, I've chosen a strange location but works well for me. This is above the passenger rear speaker. I was initially wanting to place the monitor in the cubby but find it a little troublesome to open the lid every time I need the screen during reverse, and close it when I'm done. Then was also considering placing it above the gauges but was concerned someone might break into the car thinking it was a satnav. So yesterday before this was being installed, whilst reversing to my usual parking spot, I thought it will be good to have it in the corner. Since I will be turning my head back whilst reversing, might as well have it there. It is kind of hidden in the corner. I also brought some limousine black tint to tint both little windows and now they are not visible from outside.
Got some spare CF wrap so decided to wrap the monitor as well to make it look less like a satnav.
The only negative of this monitor position is the camera video is mirrored. It will be OK if the monitor was facing the back of the car but when it is facing the front, it's mirrored. Well, that didn't bother me much as I'm using this to help with distance between me and object behind me.
Overall, I think it's money well spent (£20 all inclusive) and about 2hrs alone time with my zed (DIY)
And this will most likely be my final mod for 2015 and 2016 as I had placed an early bird deposit on a house. Main deposit due mid 2016 so no more spare cash to be spent on my zed unfortunately. But considered lucky that I don't need to sell the zed to help with deposit B)
Edited by veeg33
Great work but what an unusual place for the reversing monitor, :wacko::lol: ..but if it works for you that's all that matters. Kudos. B)
Yeah, it's odd to have there but works fine for me now. The plan is to route the vidoe cable all the way to the head unit when I had a new one installed in 2017 :scare:B)
That's a long way off but a new house is more important. ;)
Posted (edited)
Yep, missus has banned me from spending any money on the zed now. Temporary cure for Zeditus! But I'm looking forward to a new men cave, jet washer, more tools, etc!
Here's a how it will look like when it's done
Edited by veeg33
Posted (edited)
^^ Looks really nice Veeg. Lovely brick work. ;)
Just hope the garage isn't one of those tiny new build types where it's so small that even if you can get the car in, ...getting out of the car can be a nightmare. :scare:
Have you checked to see what the width of the garage door is & internal size? or isn't it a concern? (I know some people just use a garage for storage nowadays)
Edited by GMballistic
Unfortunately, it's the smaller version. I think I could just for the zed in and will struggle a little when getting out/in. Maybe need to fold the wing mirrors :scare: Not much space left once the zed is in. But will be using it mainly as additional storage. I did try my best to persuade my missus for a different house design with a detached double garage, she doesn't like it and it's costing additional £10k :( At least it will be better than my apartment now. :thumbs:
One tip providing you can get the car in the garage is to line a wall with carpet or something soft so that if the drivers door hits the wall it won't damage it. The other thing is when you try to get out of the car put the drivers seat all the way back as this makes it so much easier I've found getting in & out when in tight spaces.
Even a small garage is better than no garage though mate and it's definitely going to be a step up from any apartment imo. Hope you both enjoy your new home once you get settled in. :thumbs:
Posted (edited)
Cheers Gareth! We are so looking forward to our first house. Thanks for the tip! Will definitely add a carpet or rubber mat to protect. As for the seat, it's now all the way back, I'm about 6 feet tall and currently about 2 months pregnant (beer belly). Might still struggle but will learn from this
B)
Edited by veeg33
B)
Yeah I don't think the seat thing will work then. :dry::lol: Think I'm around 5.8" so it does help me.
Lets hope your garage isn't as bad as that guys garage though otherwise you're never getting the Zed in it. :surrender:;)
  • 2 months later...
Just read thur your blog, wow live it so much love gone into it Z
Thanks mate. Zeditus has stopped due to saving up for a house deposit. Hopefully more will come after the purchase B)
  • 1 month later...
Tiny update - My zed's number plates got stolen on Wednesday evening (7th Oct) http://www.350z-uk.com/topic/102362-number-plates-got-stolen-front-and-rear/.
New plates arrived today. Will go purchase a Tar Remover to clean up the old double sided tapes and stick a new plate on.
Decided not to add any tamper proof screws on as I like my plates clean. Apparently, number plates with double sided tapes only are usually target for number plates theft as they are the easiest to be removed quickly.
Anyway, I'm glad they only took the number plates and my no zed. Pics to follow this weekend to show extend of damage caused when they remove my number plates with a screwdriver (assuming)
Posted (edited)
Some pics before and after cleaning and removing previous double sided tapes.
Unfortunately due the scrap tool being used, the little b@st@rd left lots of scratches. Most are behind the number plate (lucky me) but not some
They even managed to peel of some paint at the rear number plate but lucky it's behind the number plate!
2 hrs later with help from lots of tar remover
Anyway, now it's all sorted. I'm still thinking if I should put 2 screws in each plate to reduce the risk of being targeted by number plates thief or just be cheeky and just super glue some screws cap/cover to disguise B)
Edited by veeg33
I'd say the chances of you being targeted again Veeg for your number plates is very unlikely, ...unless of course someone has it in for you or similar but I doubt that's the case. ;)
Screwing them in would make them harder or at least more time consuming to steal but it's never going to stop a determined thief. Hopefully though however you attach the new plates this won't happen again. :thumbs:
Fingers crossed Gareth! :thumbs: Hopefully it won't happen again, else I'll have to make a metal frame to secure it next :scare:
  • 3 months later...
  • 3 months later...
Any updates chap?
Sorry Davey, Tapatalk didn't notify me when you commented on this.
No news from police and no visit from the boys in blue. I wonder when they will use my plate to do a runner :scare:
Posted (edited)
Small update on my zed..... Nothing special, just logging my service interval.
Serviced my zed today @ 81217 miles. Oil change, oil filter and magnetic sump plug. My HKS Hybrid panel filter still looks very clean hence didn't swap it out. As usual, I flush my engine with about 1 litre of Mobil 3000 5w-30 until golden colored oil starts to drip out of the sump hole before I put in the Fuchs B) I also sh1t myself for about 10 secs when I remove my oil filter. Less then 1 ltr of oil dripped out, I though that's all the oil left in the engine and it's been running with very low oil...... :scare: then I realised I haven't unbolt the sump plug....... Schoolboy error!
Oil: Fuchs Titan GT1 5w-30
Oil filter: K&N
Sump plug: OpieOil
All above bought from OpieOil
That's the entrance to my mate's secret garage.
Edit: Just checked my record, last oils change was Feb 2015 @ 78.6k miles hence I've only covered about 2.6k miles :teeth:
Edited by veeg33
  • 2 months later...
Bought a front lip for my zed from Tarmac Sportz. Mine's replica.
Fast delivery and great service from Chris. Arrived in 2 days.
As I don't have the required bits and bobs yet, I can't fit it this weekend. But I can't wait for it to be fitted so decided to attach it to have a look at it.
Result: Absolutely loved it!
  • Like 2
