harryjackson Posted June 25, 2016 Posted June 25, 2016 The reason people go for the GC fabrications harness bar is because it's braced within the floor of the car. How come you haven't put the Tegiwa stabiliser bars on? Probably not too safe Sent from my iPhone using Tapatalk But it's a 'harness bar' with no harness stabilisers? That's not safe at all, especially if you buy it with the intention to use a harness. My bar didn't come with the stabilisers unfortunately, I'm trying to source some. Anyone know anywhere? There are better alternatives to those small welded harness stabilisers. If you wrap your harnesses properly to start with it reduce the movement quite considerably. Best place would probably be Tegiwa themselves. Even though I've heard some terrible reviews of them. Sent from my iPhone using Tapatalk Quote
GMballistic Posted June 25, 2016 Posted June 25, 2016 My bar didn't come with the stabilisers unfortunately, I'm trying to source some. Anyone know anywhere? Try Tegiwa to see if they can help would be my first call. Link: http://www.tegiwaimports.com/ Quote
blaqkaudio Posted June 25, 2016 Author Posted June 25, 2016 Cheers chaps I'll try giving them an email and see how far I get 1 Quote
blaqkaudio Posted November 16, 2018 Author Posted November 16, 2018 Well what a bump, it's been over two years and I still have the Zed Just cant find anything more fun for the money! Anyhow, it's only right I upload some pics shortly to show some of the progress as it draws to a close. Car is finally going up for sale next year once the weather starts to improve Quote
blaqkaudio Posted November 16, 2018 Author Posted November 16, 2018 (edited) So I guess the considerable change came in May 2017, I purchased a STS rear mount turbo system from a member off here. Everything turned up in two huge boxes and as expected everything needed was there and all brand new Here are some dug out pics Edited November 16, 2018 by blaqkaudio Quote
blaqkaudio Posted November 16, 2018 Author Posted November 16, 2018 (edited) Car and kit was then taken to a friends who has the space and skill to help me fit it all. Found the install manual online, printed out and progress started - here are some pictures taken along the way Work started, intake removed Injectors removed to install new ones Backbox removed Mock setup of my new back-box to be... New pieces in place Edited November 16, 2018 by blaqkaudio 3 Quote
blaqkaudio Posted November 16, 2018 Author Posted November 16, 2018 Front mount install Rear turbo and intake setup installed She was then trailered off for tuning: 3 Quote
blaqkaudio Posted November 16, 2018 Author Posted November 16, 2018 Then I had installed a CJM Stage 0 Fuel Return kit courtesy of Elliot on here, also got a Boost controller and installed that too, went back in for its final safe retune A rather moody looking shot from the Dyno room... Car has been running perfectly and sounds ridiculously good every time I drive it, perfect weekend toy Now pretty much tucked up for the winter and any mods/maintenance to be done in the meantime More pics to follow as they come off my phone! 2 Quote
blaqkaudio Posted November 23, 2018 Author Posted November 23, 2018 (edited) 17 minutes ago, msitpro said: Numbers?! What's lag like? It's running a very safe 355whp On high boost map when needed its running 375whp For me the lag is not 'noticeable'. In standard guise the Zed doesn't lack in low down get up and go, once the boost comes in you're away. Plus due to the extreme torque a turbo can put on these engines suddenly it's been tuned to be as progressive as possible Edited November 23, 2018 by blaqkaudio 1 Quote
msitpro Posted November 23, 2018 Posted November 23, 2018 3 hours ago, blaqkaudio said: It's running a very safe 355whp On high boost map when needed its running 375whp For me the lag is not 'noticeable'. In standard guise the Zed doesn't lack in low down get up and go, once the boost comes in you're away. Plus due to the extreme torque a turbo can put on these engines suddenly it's been tuned to be as progressive as possible So between 410-430 ATF with 15% drivetrain loss. What's 'safe boost' and 'high boost' levels? 7psi and 10psi? Do you have a dyno graph so I can see when the turbo is spooling etc? How much is the rear mount turbo kit and where's it available from? What do you do with Cats etc? Hmm.... It takes a feed straight from a stock exhaust pipe post-cats? Though I suppose it would be far better to go decat, bungs/signal generators. Then some cats post-turbo... I guess for your level of power you don't need a modified MAF? Quote
msitpro Posted November 23, 2018 Posted November 23, 2018 3 minutes ago, msitpro said: Stock injectors?? Sorry, re-looked at photos. Were the injectors part of the kit or bought separately? What is recommended for this kit? 500cc? Quote
msitpro Posted November 23, 2018 Posted November 23, 2018 I also see you're not running a cat post-turbo exhaust. How are you passing MOT? Or are the emissions really low due to the nature of turbos? (MOT limit is 200ppm for CO2?) Quote
Sim Posted November 23, 2018 Posted November 23, 2018 (edited) Great build @blaqkaudio I bets it's fun to drive Edited November 23, 2018 by Sim 1 Quote
blaqkaudio Posted November 23, 2018 Author Posted November 23, 2018 (edited) 4 hours ago, msitpro said: So between 410-430 ATF with 15% drivetrain loss. What's 'safe boost' and 'high boost' levels? 7psi and 10psi? Do you have a dyno graph so I can see when the turbo is spooling etc? How much is the rear mount turbo kit and where's it available from? What do you do with Cats etc? Hmm.... It takes a feed straight from a stock exhaust pipe post-cats? Though I suppose it would be far better to go decat, bungs/signal generators. Then some cats post-turbo... I guess for your level of power you don't need a modified MAF? Correct, exact psi levels I haven't even checked since having it back on the boost controller (tucked away in the garage for the winter and up for sale soon ) Wastegate has a 5psi spring in. As far as I am aware you can't buy the STS rear turbo kit anymore, company was recently acquired though so it may come back? That said it's an American based company and only available over there. Cats wise the car has decats, the turbo setup literally replaces the existing backbox and uses the existing exhaust mounts. 4 hours ago, msitpro said: Sorry, re-looked at photos. Were the injectors part of the kit or bought separately? What is recommended for this kit? 500cc? DW injectors came with the kit, 600cc which I was told were bigger than the normal supplied ones Edited November 23, 2018 by blaqkaudio Quote
blaqkaudio Posted November 23, 2018 Author Posted November 23, 2018 3 hours ago, Sim said: Great build @blaqkaudio I bets it's fun to drive Cheers mate, it certainly is! 2 Quote
andybp Posted November 23, 2018 Posted November 23, 2018 I did wonder when stemo's rear mount kit would show up Quote
blaqkaudio Posted November 23, 2018 Author Posted November 23, 2018 1 hour ago, andybp said: I did wonder when stemo's rear mount kit would show up Yeah great guy and communication. x2 large boxes turned up at my doorstep like Christmas last year, absolutely nothing missing in the kit Quote
andybp Posted November 23, 2018 Posted November 23, 2018 keep an eye on the scavenge pump though definitely the weak link in rear mounts Quote
blaqkaudio Posted November 23, 2018 Author Posted November 23, 2018 (edited) 2 hours ago, andybp said: keep an eye on the scavenge pump though definitely the weak link in rear mounts Cheers Andy will do kit also came with an in-cabin warning buzzer which I have fitted behind the dash, if the pump fails the buzzer will go off immediately which I've read is deadly loud Edited November 23, 2018 by blaqkaudio 1 Quote
da.murf Posted November 24, 2018 Posted November 24, 2018 Great looking car and nice to see a diff turbo setup. One question though, are you not afraid of sucking water into the filter mounted beside turbo?? Know it has a water shield but still lol. Easily done with a big puddle Quote
blaqkaudio Posted November 24, 2018 Author Posted November 24, 2018 (edited) 6 hours ago, da.murf said: Great looking car and nice to see a diff turbo setup. One question though, are you not afraid of sucking water into the filter mounted beside turbo?? Know it has a water shield but still lol. Easily done with a big puddle Cheers and absolutely! I've been caught out in the rain before with no issues. Torrential rain with flooding/huge puddles let's say is a no no basically. It's not my daily so I just use common sense when deciding to take it out Wouldnt take it out in that sort of weather if it was standard to be honest Edited November 24, 2018 by blaqkaudio 1 Quote
blaqkaudio Posted January 30, 2019 Author Posted January 30, 2019 Well that's a wrap on this build thread and soon to be my 6-odd years of 350z ownership. Been through a lot with this car and it truly will be sad to see it go. Everything considered, I'll soon own 3 cars and for someone that works from home it's just not sensible, so she's up for sale Deposit has now been placed on the new toy which I will be picking up on my return from working in the US. 16th Feb literally can't come fast enough! It's always been a great forum here over the years so may keep in touch and create a new thread in the relevant area, who knows Quote
Hansburger Posted January 30, 2019 Posted January 30, 2019 Nice setup! Got a dyno sheet somewhere? Quote
