Road noise or Bose ?
jamess115
Hi Zedders, I recently posted a thread re, quality of the Zed's factory fitted bose system. On reflection, this doesn't sound too bad - at least when your standing still.. I am running Bridgestone Potenzas on mine but with windows and volume up, the road noise is so loud, I can't even here the lyrics !! I'm interested in opinions on here as to whether the Zed does suffer from road noise to a large extent or whether the bose really is a crap bit of kit?
Are you guys driving with a Stethoscope to the car? :S
Music/Engine/Exaust all come before I hear anything else...
when your flying there is no road noise tho
and did i just see Dan mention tyres without saying MPSS are needed :p
^^^ have to agree ^^^ what he said, can't beat a good exhaust note to drown out any road noise ;)
Edited by tatooandy67
Why don't you emulate some of the bloody idiots out there who drive with headphones on? Can police fine you for such behaviour? It strikes me as more than a little dangerous.
MPSS are a little quieter and will alleviate some noise, as will some heavy sound damping in the boot and possibly a higher quality stereo setup. But if you wanted a quiet car to listen so you can hear music get a Prius. One of the best things about the zed is the exhaust note.
I drive the MR2 with headphones on, as it's just too loud otherwise.
They're noise cancelling ones, and sometimes I'll put music on. Sometimes I just activate them and drive like that. Far less distracting than being partially deaf by the end of the journey :)
I'm reasonably satisfied with the Bose, even as a semi-audiophile. At least satisfied enough not to bother with a HUD / speaker upgrade just yet...
If it helps, here is what I'm using:
MPSS types on the rear.
050A on the front (will probably replace with MPSS when they wear out)
Bose CD player set to +5 bass, -1 treble, possibly -1 rear fade (possibly just 0), Audio PS ON (or whatever it's called)
I've also replaced the relay in the sub amp because it kept cutting out. I don't *think* this has affected the sound, but it seems less "boomy" now?
