Inevitable, going the FI way -= NOW DONE -= update 13/05/2013
Adrian, For your consideration have a read here: http://www.350z-uk.c..._cooler__st__20
I ended up with this oil cooler set up http://www.driftwork...vt-s14-s15.html
Its pretty cheap for the entire set up Hoses, fittings, Cooler and thermostatic sandwich plate and if can keep a drift car cool, its good enough for us!
Also it has a 92Deg C thermostatic sandwich plate which I couldn't find anywhere else. I think this is pretty important for a daily driver as it can take a while for your oil to get up to temp and a few others have told me in the winter they struggle to get above 60-70deg with a standard Thermostatic valve.
I would also, possibly have a re-think about the gauges. I appreciate you may not like the look of them but I am VERY glad I have mine, in particular the AFR and Oil Temp. I would say they are a necessity for longevity.
I have had a couple of issues over the last couple of years regarding fueling One of which was a faulty injector and the other a tuning issue during the open/closed loop transition.
The AFR gauge showed I was running dangerously lean from time to time and it allowed me to adjust my driving accordingly until the issues were identified and resolved. It was a god send while fault finding to. Without it I'm sure damage would have occurred. :surrender:
Knowing your oil temp is up to temperature before you start to push it is very handy and probably just as important as it not running hot. Again, without my gauge I would have had no way of knowing that my oil Temp on track had reached 138DegC!!!! :scare: until it was too late. Thats how I knew I had to fit a cooler and how I monitor how effective the set up is.
If you don't want them on display, hide them in the cubby hole. I have one in there but you can easily fit 2 and maybe 3 in there if you wanted.
Just something for you to bare in mind. :)
:lol: :lol: Why would you want to humiliate me in front of everybody!? :lol: :lol:
:scare::surrender::scare:
Here is my Spec including all supporting mods :thumbs:
Engine
3.5l VQ35DE V6 block bored to 96mm
Tomei pro cams
Brian crower valve springs and valve caps
3 angle valve seats
Ported cylinder heads
Skimmed heads (0.5mm)
OEM full gasket set
Polished and balanced crank
Eagle h-beam rods
Arp rod bolts
Arp Head studs
Cosworth 96mm 11.0:1 forged pistons
ACL race main bearings
ACL race big end bearings
ACL race thrust washers
New oil pump
APS Plenum
APS Sump
Bosch 725cc Injectors
Vortech V2 Supercharger 3.12 pulley
Additional Engine / Engine Bay
Haltech Platinum Pro ECU
FMIC
Stillen Ceramic Coated Headers
AEM water/meth injector with filter
Wizards of NOS 75 shot system
AMS Light Weight Pulleys (Except main pulley due to damping after lightened and balanced)
Stage 1 Fuel Return System
AAM Fuel rails
Walbro 255 fuel pump
Mishimoto fans and aluminium shroud
Koyo radiator
Nismo thermostat
Nismo oil Cap
Oil Cooler
Power steering fluid cooler
Spill's grounding kit
Stainless Steel Coolant and Power steering pots
Stainless Steel Bolt set
APS Strut brace (modified to clear supercharger)
Rare JDM harness cover (modified to clear brace)
Samco Hoses
Decat Invidia G200 True Dual Exhaust
up rated engine mounts
Z-Speed under tray
Transmission
OEM 6 speed gearbox
Carbonetic twin plate clutch
Kaaz limited slip differential (2 way converted to 1.5 way)
Quick Shifter gearstick
Torque Solution rear gearbox mount
Braided Clutch line
Suspension, Brakes
Braided Brake lines all round
Front - D2 8pot callipers with 356mm disks
Rear - Ksport 6 pot callipers and 330mm disks
Tein Flex suspension with EDFC
NISMO Front and Rear ARB's
SuperPro / Whiteline adjustable bushes throughout
Adjustable rear camber arms
GTSPEC 4 Point Mid Chassis Reinforcement Brace
GTSPEC Rear Lateral Arm Brace
GTSPEC Rear Lower Tie Brace
GTSPEC Front Lower Tie Brace (to be modified to fit)
GTSPEC Fender Braces
Wheels
Rota Drift 18x9 and 18x10 running Toyo 888's 245 and 275 respectively (for track)
Volk RE30 19 x11 and 18x8.5 Running Yokohama 295 and 245 respectively (for road )
Interior
Custom built centre console
After market Head Unit with BT and SAT NAV
AEM Wide Band gauges (two)
AEM Fuel pressure gauge
Saga Oil Temp gauge
Saga Oil Pressure gauge
Saga Boost gauge
Bride Brix II Seats and Rails
EDF Control unit
Nismo throttle pedal (still to be fitted)
Track Cam
NOS Control unit
Water/Meth control unit
2 x 5lbs NOS bottles with heaters (stealth install behind passenger seat)
Nismo Titanium gear knob
Custom warning light array
Green LED Lighting
Exterior
Shine Amuse Front Bumper with CF intake
CF A Pillars
CF Mirror Covers
CF B pillars
Nismo Version 2 rear wing
Upgraded facelift rear lights (LED type) tinted
Rolled arches
Rear arch extensions
Nismo Side skirts (replica)
LX Front wings
Espirit rear bumper
Limo tinted rear glass
Angry wife £0.00 in the bank account :lol:
Just giving you something to aim at mate :thumbs:
I'll take you down the road in her Saturday if it's dry enough see how quick you want to get your SC fitted then :thumbs:
Ha ha good luck with the passenger ride matey.
You of course won't fancy a drink afterwards but take a spare pair of pants :lol:
I couldn't stop laughing historically with the experience.
I'm just waiting to see a pic of the Beast and the Turquoise together - colourful, or what.
Oh, and take spare trousers Adrian :lol:
Trying to keep up with me :evil:
How about going matte red Darren? :teeth::stir:
Posted (edited)
This is a good read. Brings back memories! :)
2.5 years boosted and still going strong. Let me know if you need any help or advice.
May even be able to help you source parts if you need! PM me.
Edited by wizard
With me and Keyser around, you'd be extremely stealth in the current colour! :lol:
I`d hope to be the last one pulled by the fuzz too :p
With the noise on yours?
Anyway I'm so overt it's convert
Is he the guy that bought Bennett's K1 exhaust? :lol: :lol: :lol:
haha Believe it or not part of my exhaust has a quiet milltek stamp on it. Not sure if theres anything in terms of baffles left inside of it though :lol:
Posted (edited)
Just some general advice from me when undertaking an FI build to anyone.
It's very easy to start going through catalogues of stuff and spend as much as your credit card allows buying stuff... but unless the car is to be a show car of some sort, I tend to think a lot of it can be a waste.
Personally I'd always tend to keep things as simple as possible, and find the potential / limit of where I can go with what I have, and then when there's a reason to upgrade something, do so! - This is not about doing things on the cheap, because I know from experience with cars, doing things cheap never ends well... but it's about knowing what you're upgrading and why it will make a difference over OEM / or over the part you're replacing with.... and most importantly, how will you measure that change?
Just some food for thought! :thumbs:
Edited by wizard
