haytonz Posted September 27, 2012 Posted September 27, 2012 hi was just woundering how do you take the rear badges off and if any damage would be left to the paint under or any holes, my zed is a roadster if that makes a diffrence Quote
Jay Posted September 27, 2012 Posted September 27, 2012 hi was just woundering how do you take the rear badges off and if any damage would be left to the paint under or any holes, my zed is a roadster if that makes a diffrence Warm water and Dental Floss. Some people also use a hair dryer. It will leave two small holes ( i think ) and then obviously the residue of the glue. Are you wanting to replace them with a different badge or go for the smooth look? Quote
ddcboyle Posted September 27, 2012 Posted September 27, 2012 dental floss dudnt work for me but seems popular with others. i just bought cheap fishing wire, poured water and done a sawing effect through badge. once the badge is off, youll be left with oads of the glue and 2 holes where badge was. easiest way is to pick the glue off or let it dry, and keep rubbing with ur finger, itll eventually lose stickyness and fall off (be aware u will get burny finger syndrome) Quote
Humpy Posted September 27, 2012 Posted September 27, 2012 Hair dryer worked for me nicely and an old credit card or similiar etc to help remove the badge. Quote
ewan221 Posted September 27, 2012 Posted September 27, 2012 Might be speaking rubbish here , but seem to remember a recent post saying there is no holes when you remove roadster rear badge Quote
Zugara Posted September 27, 2012 Posted September 27, 2012 No holes, I can confirm this. Be a man, just get your finger nails behind the damm thing and pull it off. Thats how I did it, none of this pussying around with floss, g-strings, hair dryers etc..... Quote
Humpy Posted September 27, 2012 Posted September 27, 2012 No holes, I can confirm this. Be a man, just get your finger nails behind the damm thing and pull it off. Thats how I did it, none of this pussying around with floss, g-strings, hair dryers etc..... Thats if you have nails to do that Zugs, unlike myself! If it means being a man try doing it with your teeth instead Haydn Quote
Zugara Posted September 27, 2012 Posted September 27, 2012 No holes, I can confirm this. Be a man, just get your finger nails behind the damm thing and pull it off. Thats how I did it, none of this pussying around with floss, g-strings, hair dryers etc..... Thats if you have nails to do that Zugs, unlike myself! If it means being a man try doing it with your teeth instead Haydn Stop biting them then.......or have you no fingers Quote
jollyranchers Posted September 27, 2012 Posted September 27, 2012 Why do people want to de badge if it leaves holes behind in the lid ? Quote
haytonz Posted September 27, 2012 Author Posted September 27, 2012 can someone promise me that it wont leave a 2 holes because was going to debadge it for my dads birthday since he likes the smooth look, and dont want him to wake up to two holes and wrecked paint Quote
ianphampton Posted September 27, 2012 Posted September 27, 2012 Took my "Fairlady Z" off with warm water and dental floss, definitely NO HOLES Cleaned the glue off with celulose thinners (nail polish remover) but it is serious stuff especially on car paint so just wipe it (Don't let it soak) Left my Burger in the middle so don't know if there's holes behind that one Took about 5 minutes, that's all, no problems Quote
ddcboyle Posted September 28, 2012 Posted September 28, 2012 Why do people want to de badge if it leaves holes behind in the lid ? Alot of people fill the, and get it sprayed. I took mine off so i could vinyl Quote
haytonz Posted September 28, 2012 Author Posted September 28, 2012 so i will take the 350z badge of but leave the nissan badge on till ome one confirms theres no holes Quote
ATTAK Z Posted September 28, 2012 Posted September 28, 2012 so i will take the 350z badge of but leave the nissan badge on till ome one confirms theres no holes THERE ARE TWO HOLES that locate the Nissan badge at the rear of the 350Z There are no holes under the Nissan badge at the front of the 350Z FACT Anyone that has taken the badges off will confirm this Quote
glrnet Posted September 28, 2012 Posted September 28, 2012 See Stew's last post here:- viewtopic.php?f=26&t=30328&p=444719&hilit=rear+badge+removal#p444719 Quote
ATTAK Z Posted September 28, 2012 Posted September 28, 2012 See Stew's last post here:- viewtopic.php?f=26&t=30328&p=444719&hilit=rear+badge+removal#p444719 Hayton's dad's car is a UK coupe not a roadster IIRC Quote
Jay Posted September 28, 2012 Posted September 28, 2012 so i will take the 350z badge of but leave the nissan badge on till ome one confirms theres no holes THERE ARE TWO HOLES that locate the Nissan badge at the rear of the 350Z There are no holes under the Nissan badge at the front of the 350Z FACT Anyone that has taken the badges off will confirm this Amen brother Quote
glrnet Posted September 28, 2012 Posted September 28, 2012 See Stew's last post here:- viewtopic.php?f=26&t=30328&p=444719&hilit=rear+badge+removal#p444719 Hayton's dad's car is a UK coupe not a roadster IIRC Now I'm really confused, his first post mentions a roadster Quote
4RE Leather Posted September 28, 2012 Posted September 28, 2012 No holes, I can confirm this. Be a man, just get your finger nails behind the damm thing and pull it off. Thats how I did it, none of this pussying around with floss, g-strings, hair dryers etc..... I bent my badge doing that:( Quote
ddcboyle Posted September 28, 2012 Posted September 28, 2012 Easiest thing to do mate, get some fishing wire for few quid, and remove th badge to see if it has the holes. My car has holes and its coupe, cant confirm about roadster but seems mixed opinions. If u got holes, get some double sided sticky nd put back on. You can try dental floss, but these guys must be using horse dental floss as my human stuff just snapped under any tension. Quote
haytonz Posted September 28, 2012 Author Posted September 28, 2012 my dads car is a roadster so it should be alright then, ive done the 350z badge today and it works really is so easy went with zugaras advise and just pulled them off so easy then i used auto glym tar remover and a toothbrush and there you have it , going to do the nissan badge tomorow, one more question was dose jdm mean Quote
Zugara Posted September 28, 2012 Posted September 28, 2012 my dads car is a roadster so it should be alright then, ive done the 350z badge today and it works really is so easy went with zugaras advise and just pulled them off so easy then i used auto glym tar remover and a toothbrush and there you have it , going to do the nissan badge tomorow, one more question was dose jdm mean Japanese domestic market. Quote
ATTAK Z Posted September 28, 2012 Posted September 28, 2012 See Stew's last post here:- viewtopic.php?f=26&t=30328&p=444719&hilit=rear+badge+removal#p444719 Hayton's dad's car is a UK coupe not a roadster IIRC just reread this first post - it's a roadster so will have no holes front or rear , , I'm so so SORRY Quote
glrnet Posted September 28, 2012 Posted September 28, 2012 See Stew's last post here:- viewtopic.php?f=26&t=30328&p=444719&hilit=rear+badge+removal#p444719 Hayton's dad's car is a UK coupe not a roadster IIRC just reread this first post - it's a roadster so will have no holes front or rear , , I'm so so SORRY No probs Hugh Quote
