M9O OEY Posted May 29, 2010 Posted May 29, 2010 Hi , Iv read on a different thread about a " penny trick ", Someone asked for a guide to be written . Could someone please explain what it is and does ? I guess it is somethin to do with the Z and i have plenty of pennys lying around . Thanks James Quote
IanS16 Posted May 29, 2010 Posted May 29, 2010 Hint: The penny trick was a good idea in theory but in the long run damages your boot (pushes through) Any idea what I'm talking about yet? Quote
IanS16 Posted May 29, 2010 Posted May 29, 2010 People with heavy spoilers often have to lift the boot hatch and press the release button at the same time to get the boot off of the catch as the springs aren't strong enough. (Not the end of the world but it means you need to use 2 hands at once which is a bit of a pain when trying to put something in the boot) The penny trick is where you twist the black plastic spring casings to release them from the boot lid and insert a penny into the spring casing to stiffen the spring. This does work in a few cases but the penny can actually cause the boot spring to push through the boot after a while - it has pushed through on mine slightly and cracked the paint. Hope that made sense Quote
SteveW Posted May 29, 2010 Posted May 29, 2010 The penny trick is where you twist the black plastic spring casings to release them from the boot lid and insert a penny into the spring casing to stiffen the spring. This does work in a few cases but the penny can actually cause the boot spring to push through the boot after a while - it has pushed through on mine slightly and cracked the paint. Hope that made sense Bloody hell my pennies will be getting taken out tomorrow!!! Quote
Lincolnbaggie Posted May 30, 2010 Posted May 30, 2010 My pennies have been in for three years now and no problems at all Quote
Tarmac@TarmacSportz Posted May 30, 2010 Posted May 30, 2010 If you don't want to do the penny trick then there's a company near me that will re-gas your boot dampers £30 for the pair which will give them enough strength to lift the boot with spoiler. Fakeindian had it done. Quote
ATTAK Z Posted May 30, 2010 Posted May 30, 2010 If you don't want to do the penny trick then there's a company near me that will re-gas your boot dampers £30 for the pair which will give them enough strength to lift the boot with spoiler. Fakeindian had it done. way to go Quote
captain Posted May 30, 2010 Posted May 30, 2010 People with heavy spoilers often have to lift the boot hatch and press the release button at the same time to get the boot off of the catch as the springs aren't strong enough. (Not the end of the world but it means you need to use 2 hands at once which is a bit of a pain when trying to put something in the boot) The penny trick is where you twist the black plastic spring casings to release them from the boot lid and insert a penny into the spring casing to stiffen the spring. This does work in a few cases but the penny can actually cause the boot spring to push through the boot after a while - it has pushed through on mine slightly and cracked the paint. Hope that made sense +1 Slightly dented both sides of my car. Don't do it. Quote
Madmarky Posted May 30, 2010 Posted May 30, 2010 If you don't want to do the penny trick then there's a company near me that will re-gas your boot dampers £30 for the pair which will give them enough strength to lift the boot with spoiler. Fakeindian had it done. Its not to do with the Gas struts tho, its the springs in the little black bump stops that need strengthening. Quote
dcash5 Posted May 30, 2010 Posted May 30, 2010 Rubber washers would work aswell. Plus I think the 370z ones are slightly uprated aswell. Quote
IanS16 Posted May 30, 2010 Posted May 30, 2010 If you don't want to do the penny trick then there's a company near me that will re-gas your boot dampers £30 for the pair which will give them enough strength to lift the boot with spoiler. Fakeindian had it done. Its not to do with the Gas struts tho, its the springs in the little black bump stops that need strengthening. Quote
Ebized Posted May 30, 2010 Posted May 30, 2010 Rubber washers would work aswell. Plus I think the 370z ones are slightly uprated aswell. Its still an issue on the 370 when cold but when it is warm it mostly works OK with just the first push. Quote
M9O OEY Posted May 31, 2010 Author Posted May 31, 2010 Thanks think i'd save my pennies and get them re gassed Quote
Madmarky Posted May 31, 2010 Posted May 31, 2010 Thanks think i'd save my pennies and get them re gassed As i said above its not to do with the gas struts its to do with the bump stops. I have made a guide, you can find it here viewtopic.php?f=35&t=37034 Quote
roy_watson Posted May 31, 2010 Posted May 31, 2010 I have a question related to the above. I have had issues with the boot not clearing the lock mechanism when the button is pressed (requiring two hands to open it etc). I read this post and thought i would see if the "Penny Trick" would make a difference. However when I looked closely at the two spring mechanisms, the right hand side spring is bent into a curved shape (almost like a quarter of a circle if you know what I mean). Upon removing the rubber casing, the piece of metal which runs through the actual spring has completely bent. I'm guessing this is what may be causing the boot not opening properly as both springs are not fully engaged when the boot is closed?!? Two things, what on earth could have caused the spring mechanism to bend like this (assuming its not meant to be like this)? I took the whole mechanism off the boot to see if i could straighten it but with all my strength it wont budge one little bit. Secondly, where would I get a replacement one? Quote
captain Posted June 1, 2010 Posted June 1, 2010 I have a question related to the above. I have had issues with the boot not clearing the lock mechanism when the button is pressed (requiring two hands to open it etc). I read this post and thought i would see if the "Penny Trick" would make a difference. However when I looked closely at the two spring mechanisms, the right hand side spring is bent into a curved shape (almost like a quarter of a circle if you know what I mean). Upon removing the rubber casing, the piece of metal which runs through the actual spring has completely bent. I'm guessing this is what may be causing the boot not opening properly as both springs are not fully engaged when the boot is closed?!? Two things, what on earth could have caused the spring mechanism to bend like this (assuming its not meant to be like this)? I took the whole mechanism off the boot to see if i could straighten it but with all my strength it wont budge one little bit. Secondly, where would I get a replacement one? Happened to me too. Quote
