Daisyduke Posted June 4, 2019 Posted June 4, 2019 Are you selling any branded y pipes? Many thanks Daisy Quote
Ian Posted June 5, 2019 Author Posted June 5, 2019 On 04/06/2019 at 07:04, Daisyduke said: Are you selling any branded y pipes? Many thanks Daisy Only as a full cat back system Quote
LEVI-G Posted June 6, 2019 Posted June 6, 2019 Hi there what condition are the headers and exhaust system ? Do you have the y pipes also. I understand they are still waiting to come off. Very interested. Pm me. Quote
Ian Posted June 7, 2019 Author Posted June 7, 2019 First post updated with more sold parts. open to reasonable offers on most items Quote
poke1123 Posted June 12, 2019 Posted June 12, 2019 Have you got the driver's side window switches? Quote
Ian Posted June 12, 2019 Author Posted June 12, 2019 17 minutes ago, poke1123 said: Have you got the driver's side window switches? they've sold sorry Quote
jamez87 Posted June 12, 2019 Posted June 12, 2019 hi, have you got the engine undertray? cheers Quote
Ian Posted June 12, 2019 Author Posted June 12, 2019 33 minutes ago, jamez87 said: hi, have you got the engine undertray? cheers It sold last week Quote
Ian Posted June 19, 2019 Author Posted June 19, 2019 Radiator is OEM or I've got a Mishimoto coming off in a few weeks which has the below spec; Overall Size: 29.7" x 21" x 1.92"Core Size: 15.75" x 28.15"Rows: 2Inlet: 1.4"Outlet: 1.4"Core Thickness: 1.42"Tank Wall Thickness: .08"Fill Neck: 1.25"Drain Plug Thread Size: (M16) .06" Drain Plug Thread Length: .047" Quote
varbrad Posted June 23, 2019 Posted June 23, 2019 Heya, Looking for a replacement boot lift spring (One of these: https://www.torqen.uk/976-350z-nissan-oem-rear-boot-lift-spring-coupe-only-84415-cd71a.html) Let me know if you have either of them left. Thanks Quote
Ian Posted June 23, 2019 Author Posted June 23, 2019 55 minutes ago, varbrad said: Heya, Looking for a replacement boot lift spring (One of these: https://www.torqen.uk/976-350z-nissan-oem-rear-boot-lift-spring-coupe-only-84415-cd71a.html) Let me know if you have either of them left. Thanks They were one of the first things to sell sorry Quote
Ian Posted June 27, 2019 Author Posted June 27, 2019 More parts sold Still plenty left - not all of which is listed in OP Quote
TT350 Posted June 27, 2019 Posted June 27, 2019 The spacers are 15mm front and 20mm rear. If you sell gearbox complete, bear In mind it has a custom built stage 8 clutch clutch by south bend, rated to 750ib/ft torque. Quote
hotrain69 Posted June 28, 2019 Posted June 28, 2019 Do you have the passenger side door weather strip thing. Bit that slots at the top of the door on the outside at the bottom of the window. Also, assume these are universal and should fit my 07 uprev? Cheers. Quote
Leej1980 Posted June 29, 2019 Posted June 29, 2019 Hi, can u pop a pic of which door sill covers you have on it pls? Thanks Quote
fijifixit Posted July 9, 2019 Posted July 9, 2019 On 12/06/2019 at 19:28, jamez87 said: hi, have you got the engine undertray? cheers I may have an undertray available if you're interested? Quote
Ian Posted July 13, 2019 Author Posted July 13, 2019 MORE PARTS ADDED. LOTS MORE STILL AVAILABLE NOT EVERYTHING IS LISTED Quote
Daisyduke Posted July 13, 2019 Posted July 13, 2019 Are the hooks for the battery tie down available? Quote
Ian Posted July 14, 2019 Author Posted July 14, 2019 Yeah ive got them somewhere. Ill double check tonight Quote
pagan Posted July 15, 2019 Posted July 15, 2019 I don't suppose you have the elec. relays for the rad fans in the fuse box under the battery cover.? Quote
