big_joe Posted January 23, 2018 Posted January 23, 2018 Hi all I had a 350z a few years ago, the reason i sold it was that at 6ft6 i didn't have enough head room with my helmet on on for track days, it was near enough impossible to drive. Now i was wondering if anyone has managed to mount a fixed back bucket seat lower than a standard cloth seat? I need atleast another 2 inches over a cloth seat i'd imagine. On my track Civic I have side mounts bolted straight through the car floor and bolted underneath the car with spreader plates....so i'm literally sat on the floor :D. Is this an option on the Z....it obviously depends on the shape of the floor pan inside the car (needs to be flat really) and if there is anything in the way underneath the car? I really fancy another Z but its useless to me if i cant track it. Cheers! Quote
Willsy1980 Posted January 23, 2018 Posted January 23, 2018 Get a Roadster, loads of head/Helmet room Just not the best if you park it upside down.... 1 Quote
big_joe Posted January 23, 2018 Author Posted January 23, 2018 8 minutes ago, Willsy1980 said: Get a Roadster, loads of head/Helmet room Just not the best if you park it upside down.... Haha, yeah I'll be decapitated Should have stated, I'm only interested in a tin top 1 Quote
The Chubby Ninja Posted January 24, 2018 Posted January 24, 2018 I'm having the same issues and I'm not even 6ft, fine without a helmet but need to slouch in the bucket seat when I've got it on. Mine is on rails but I was thinking about taking them out and making some sort of bracket up so I can bolt it to the floor. The floors not flat tho so may cause some issues. I think bride do low seat rails but I'm not sure if it will give much more room than the one I've got. Would like to find out if anyone has the bride low max rails? Quote
AW11mike Posted January 24, 2018 Posted January 24, 2018 I’ve got buddy club rails on my Sparco evo seats, there is three height settings, I’ve got mine on the highest, so looks like they can go very low. Quote
Jetpilot Posted January 24, 2018 Posted January 24, 2018 Check out Andy James/Silver Pheonix thread, he is of the lanky variety and regularly tracks/sprints/hillclimbs his car and has just adapted some seats and mounts! 1 Quote
big_joe Posted January 24, 2018 Author Posted January 24, 2018 5 hours ago, Jetpilot said: Check out Andy James/Silver Pheonix thread, he is of the lanky variety and regularly tracks/sprints/hillclimbs his car and has just adapted some seats and mounts! Had a look at it, not sure those seats look any lower than stock....and they're a bit fancy for me I Did some research, the floor plan looks like a real ball ache to do anything with Also it seems people have trouble getting wide seats in there, might be a no go for me Quote
andy james Posted January 24, 2018 Posted January 24, 2018 After fitting my fancy seats which was not easy I came to the conclusion that Nissan did a really good job getting the standard seats to adjust so low as they had to design the floor pan to accommodate both left and right drive cars. Without rails I recon my seats sit slightly lower than standard. As you discovered by looking at the floor pan it's not an easy job to modify. custom made seat bolted directly to the floor could be a way forward. Quote
Kieran O'Quick Posted January 24, 2018 Posted January 24, 2018 (edited) Hey there Joe, I found the Buddy Club seats and rails were noticeably lower than the cloth ones. Very light too, but about £400 I think.. Failing that it's a bit of fab. PS. You never should have sold that Zed Edited January 24, 2018 by Kieran O'Quick Quote
buster Posted January 24, 2018 Posted January 24, 2018 (edited) if your still struggling for low frames i d suggest these...i fitted these when fitting my recaro sr3 s and have at least 3 inch head room https://www.ebay.co.uk/itm/2-x-Steel-Bucket-Seat-Low-Mounting-Bracket-For-Nissan-03-06-350Z-3-5L-V6-Z33-/122023896210?hash=item1c6930e492 Edited January 24, 2018 by buster 1 Quote
The Chubby Ninja Posted January 24, 2018 Posted January 24, 2018 Cheers buster I think il give one a try Quote
Snjur Posted January 24, 2018 Posted January 24, 2018 I have these what buster attached and im 99% sure it's exact one. I have Sparco R100 and comparing to OEM ones they do sit bit lower but not so much. Same problem im facing on track with helmet on. I just need extra inch. Also passenger one is not "ideal" as its only secured by 3 bolts so i will need to cut and weld additional inch of steel in order to secure it with all 4 bolts. But for this price they are best buy Quote
