Omegamanuk Posted November 21, 2016 Posted November 21, 2016 Has anyone had the oil seals replaced behind the timing chain that cause the low oil pressure if so what sort of money am I looking at to have them done? Sent from my iPhone using Tapatalk Pro Quote
ZEUS Posted November 21, 2016 Posted November 21, 2016 It's been talked about a lot, it's around 6-800 quid to get done iirc. Quote
Cimanu Posted November 21, 2016 Posted November 21, 2016 Hdev quote £799, believe Abbey motorsport are little less than that Depending on where you're based Mitz at Cougarstore, Zmanalex I believe and a few others also do this job quite regularly. Think Nissan quote it being a 7 hour job.. It's on my list of things to have done next year. What's your oil pressure reading hot and at what mileage? Just to strike fear in to me... Quote
Grumsby Posted November 21, 2016 Posted November 21, 2016 Hdev quote £799, believe Abbey motorsport are little less than that Depending on where you're based Mitz at Cougarstore, Zmanalex I believe and a few others also do this job quite regularly. Think Nissan quote it being a 7 hour job.. It's on my list of things to have done next year. What's your oil pressure reading hot and at what mileage? Just to strike fear in to me... Thinking about doing mine myself with the uprated seals... Mileage at 112k (put 6k on her in 2 months) and when hot my oil pressure is reading around 10-15psi at idle, 30 or so at 70mph in 6th gear. Quote
Omegamanuk Posted November 21, 2016 Author Posted November 21, 2016 07 plate with 70K getting 30psi @ 2k rpm and 60 @ 3k just dropped overnight Sent from my iPhone using Tapatalk Pro Quote
Richf Posted November 22, 2016 Posted November 22, 2016 More info here http://www.350z-uk.com/topic/108292-oil-gallery-gasket-repair-350z-hr-and-370z/ Its not a hard job technically but a ramp is a must and the bottom crank nut is super tight , we had to order tools better suited to working on the railways ! A 1" drive- 1.2m breaker bar and it still takes two guys on it sometimes to break them loose Quote
Dicky Posted November 22, 2016 Posted November 22, 2016 Getting my 370 HR done this Monday at Falcon Performance for £668 all in (inc VAT)... Thought about doing it myself but decided against, due to lack of suitable facilities, not knowing what could go wrong (let's face it we all start off believing it's going to be easy) and if you get something wrong you've got to strip it all down again, plus you've got no warranty Thought of fitting a pressure gauge and monitoring it, but you can bet on the day you decide to give the car a go you won't be monitoring and if the downside is a new engine + fitting your looking a big bucks. The root cause is the gaskets and for peace of mind it's worth getting it done. It's also a selling point when that day arrives Quote
nissanman312 Posted November 22, 2016 Posted November 22, 2016 Getting my 370 HR done this Monday at Falcon Performance for £668 all in (inc VAT)... Thought about doing it myself but decided against, due to lack of suitable facilities, not knowing what could go wrong (let's face it we all start off believing it's going to be easy) and if you get something wrong you've got to strip it all down again, plus you've got no warranty Thought of fitting a pressure gauge and monitoring it, but you can bet on the day you decide to give the car a go you won't be monitoring and if the downside is a new engine + fitting your looking a big bucks. The root cause is the gaskets and for peace of mind it's worth getting it done. It's also a selling point when that day arrives Dicky can you get your guy to take lots of pictures please for our info on here It's a hot topic at the moment One I'm looking into myself Quote
ZMANALEX Posted November 22, 2016 Posted November 22, 2016 More info here http://www.350z-uk.c...0z-hr-and-370z/ Its not a hard job technically but a ramp is a must and the bottom crank nut is super tight , we had to order tools better suited to working on the railways ! A 1" drive- 1.2m breaker bar and it still takes two guys on it sometimes to break them loose Very easy to loosen the crank pulley bolt if you lock the fly (special tool) However if you do not have the tool then the breaker bar trick always works 100% of the time.. Quote
Richf Posted November 22, 2016 Posted November 22, 2016 More info here http://www.350z-uk.c...0z-hr-and-370z/ Its not a hard job technically but a ramp is a must and the bottom crank nut is super tight , we had to order tools better suited to working on the railways ! A 1" drive- 1.2m breaker bar and it still takes two guys on it sometimes to break them loose Very easy to loosen the crank pulley bolt if you lock the fly (special tool) However if you do not have the tool then the breaker bar trick always works 100% of the time.. The fly moving isnt the issue the 100ft lbs plus torque is , however the tool is very useful when tightening the bolt correctly Quote
Cimanu Posted November 23, 2016 Posted November 23, 2016 I have a friend who will be moving to a Nissan dealer as service manager next month.. so will be seeing what it can be done for there at a very reduced labour rate - GTR/370s in the showroom so presume it's a full, performance dealer. If that's still extortionate then i'll be contacting one of you lot! Low rpm hesitation when coming on throttle - related? Or a seperate fault entirely and cured with a map.. Quote
steve916 Posted November 23, 2016 Posted November 23, 2016 Some photos in my build thread ( link in signature below), of when I had mine done by Mitz at Cougar Store Quote
Omegamanuk Posted November 23, 2016 Author Posted November 23, 2016 Anyone able to recommend some one in West Yorkshire to do the job? Sent from my iPhone using Tapatalk Pro Quote
veeg33 Posted November 23, 2016 Posted November 23, 2016 Anyone able to recommend some one in West Yorkshire to do the job? Sent from my iPhone using Tapatalk Pro I can't locate a specialist here in West Yorkshire. I found 2 options, Atkins Motor Engineers (North Yorkshire) or Lockwood and Greenwood (Manchester). I went for L&G in the end and they were brilliant. Quote
Omegamanuk Posted November 28, 2016 Author Posted November 28, 2016 Lockwood and Green Ryecroft Business Park, Ryecroft Street, Ashton Under Lyne OL7 0BU these people?? Quote
