Kieran_ctr Posted March 26, 2016 Posted March 26, 2016 I have eyelids on my car which I had fitted by a body shop while they fitted my rear bumper, I aren't keen on them & want to take them off but found out they used silicon, they have only been on a few weeks so my question is how can I get them off without damaging the headlight? Quote
Ekona Posted March 26, 2016 Posted March 26, 2016 Just pull. Silicone isn't very strong at all, the eyelid will snap first if you're not careful, then attack the light with some silicone remover. Quote
Ceejay29 Posted March 26, 2016 Posted March 26, 2016 Also, kudos on removing the ugly things! +1 Quote
Kieran_ctr Posted March 26, 2016 Author Posted March 26, 2016 They are on TIGHT! U think using a hair dryer to heat & loosen the glue? Quote
Ekona Posted March 26, 2016 Posted March 26, 2016 It's not glue, so no. You need some silicone remover, you can get it from B&Q etc. Or just get a sharp knife between the two surfaces? Quote
DoogyRev Posted March 26, 2016 Posted March 26, 2016 It's not glue, so no. You need some silicone remover, you can get it from B&Q etc. Or just get a sharp knife between the two surfaces? You could try pulling some light weight fishing wire though 1 Quote
Ceejay29 Posted March 26, 2016 Posted March 26, 2016 It's not glue, so no. You need some silicone remover, you can get it from B&Q etc. Or just get a sharp knife between the two surfaces? You could try pulling some light weight fishing wire though Yes I would try this over the knife. Typically the method employed when removing badges etc. Quote
Ekona Posted March 26, 2016 Posted March 26, 2016 Pfft, wimps Hobby knives are the best, proper sharp blades so you don't need any pressure. 1 Quote
ZEUS Posted March 26, 2016 Posted March 26, 2016 Pfft, wimps Hobby knives are the best, proper sharp blades so you don't need any pressure. .....to slice straight into the headlight. Quote
Zeezeebaba Posted March 26, 2016 Posted March 26, 2016 The turkey that put lids on my car used superglue! I managed to remove all of it except one spot on the n/s lens that had eaten into the lens. Luckily I managed to source some facelift lights for a good price. Quote
Kieran_ctr Posted March 26, 2016 Author Posted March 26, 2016 After having a good at it, it looks like a superglue than a silicon! Would u still suggest silicon remover & fish wire? Quote
Zeezeebaba Posted March 26, 2016 Posted March 26, 2016 I used an old AA membership card and a hair dryer. Then I had to polish out the glue damage. 1 Quote
Kieran_ctr Posted March 27, 2016 Author Posted March 27, 2016 Got the eyelids off, just left with black silicon, anyone best way? I'm thinking silicon remover spray & a Stanley blade to run up it? Quote
ilogikal1 Posted March 27, 2016 Posted March 27, 2016 Tardis (or alternative tar and glue remover if you must) will shift that. Soak some sheets of kitchen roll in it, lay it over the silicon, leave for a couple of minutes, use an old rag to wipe it off, repeat until done. Quote
Jetpilot Posted March 27, 2016 Posted March 27, 2016 Could be tigerseal or sikaflex, if its either, you have your work cut out. Quote
Ukeraa Posted March 28, 2016 Posted March 28, 2016 Those of you who take knives to your Zs are lunatics, I get scared when someone gets near mine with jewellery! Quote
Kieran_ctr Posted March 28, 2016 Author Posted March 28, 2016 Thanks to a fellow member on her (Spoons) he came over to help fix my Bose amp problem which is sorted now & do the lights & they came out brilliant, only problem is have a blue line which I'm guessing is paint from the eyelid but hey ho came out better than I expected Quote
ilogikal1 Posted March 28, 2016 Posted March 28, 2016 Looks like they'd benefit from a polish, particularly where the sealant/glue sat. That should get rid of the paint transfer too. Don't forget to re-seal them afterwards though. Quote
