Rhino Posted March 11, 2016 Share Posted March 11, 2016 Alright gents, Firstly sorry if this has been asked many times or if it's pinned. I haven't been able to locate anything. I have a 260 mile drive from Exmouth to Cambridge next week and my car has fallen ill. The symptoms are as the title suggests, during the higher gears when the accelerator is pressed the revs are shooting up with no response/ pull from the Z. I gave it a run out earlier to try and diagnose it better and it started happening as low as 3rd gear. Is the clutch slipping and in need of replacement of is there an easier fix? It's a 350z GT4 with only 41,000 miles on it. Any advice would be fantastic, thank you. Rhino Quote Link to comment Share on other sites More sharing options...
lmc Posted March 11, 2016 Share Posted March 11, 2016 Sounds like your clutch is slipping 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 11, 2016 Share Posted March 11, 2016 Definitely sounds like clutch slip, so probably time for a new clutch kit and fly. Quote Link to comment Share on other sites More sharing options...
Ebized Posted March 11, 2016 Share Posted March 11, 2016 Sounds very much as though the clutch is slipping. If so the fix is a new one and that means the gearbox out, so no "easy fix" - sorry! Quote Link to comment Share on other sites More sharing options...
modo Posted March 11, 2016 Share Posted March 11, 2016 Yes definitely sounds like the clutch😨 Quote Link to comment Share on other sites More sharing options...
TT350 Posted March 11, 2016 Share Posted March 11, 2016 If the engine is revolving but not transferring it to the wheels then clutch is fubar. Quote Link to comment Share on other sites More sharing options...
davey_83 Posted March 11, 2016 Share Posted March 11, 2016 Wear and tear part, happens to all Zeds sooner or later. It's something that'll only get worst also. New clutch time Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 11, 2016 Share Posted March 11, 2016 I agree with the others as it does sound like clutch slip. If you do go down the route of replacing the clutch as it's a fairly big job you're best off replacing the flywheel as well at the same time. Just Fyi though Rhino there are plenty of professional traders on here that can help you source the parts you'll need at better prices than most places. All can be found here: http://www.350z-uk.com/forum/93-professional-traders/ Then all you need to do is find a good local independent garage to fit the parts. Quote Link to comment Share on other sites More sharing options...
Rhino Posted March 12, 2016 Author Share Posted March 12, 2016 Brilliant, thank you all for your input. Finding a good local garage is the hardest part these days, my previous car went in for an MOT and was hit in a car park in which the garage also used and there was nothing that could be done about it. Thanks again for confirming the slipping clutch, i'll get on to it ASAP. Much appreciated, Rhino Quote Link to comment Share on other sites More sharing options...
