SiriusProjects Posted February 18, 2015 Posted February 18, 2015 Just been reading a few posts about painting the plenum and have to admit, it scares the hell out of me. I'm pretty confident when it comes to spraying up pieces of interior trim and things like that, but for me the engine is a big no-no. Exactly how easy is it to remove and replace the plenum? Is it just a case of undoing a few bolts and it simply lifting off? What about when it goes back on? Do you have to ensure that it's bolted to the same tightness all round, using a torque wrench or something? Forgive all the questions, but there is no way I could ever attempt it without knowing everything I need to know. I'd rather leave it to a professional if I am honest, even if it does cost me more. Quote
evest Posted February 18, 2015 Posted February 18, 2015 Hi mate, Don't worry about taking the plenum off - it will be a a bit nerve-racking the first time but you'll be fine. To be on the safe side, have a replacement gasket ready for when you put it back on. You will need to ensure the bolts go back in, in a specific order and to the correct torque. There should be a post in the guides section about installing a plenum spacer - everything you need to know will be in there. Quote
RobPhoboS Posted February 18, 2015 Posted February 18, 2015 http://www.350z-uk.com/topic/37794-plenum-spacer-mrev2-manifold-installation/ Quote
Pritchard Posted February 18, 2015 Posted February 18, 2015 What are you painting it with? im curious as mine is due soon Quote
SiriusProjects Posted February 18, 2015 Author Posted February 18, 2015 There is already a plenum spacer installed on the car as the previous owner had it done. As for what I am painting it with, to be honest I haven't thought that far ahead. It's only recently that I've been reading about painting the plenum so it's early days for me. Quote
RobPhoboS Posted February 18, 2015 Posted February 18, 2015 There is already a plenum spacer installed on the car as the previous owner had it done. (not sure if I'm reading what you mean't correctly) Yes but that manual tells you how to remove it and put it back on PROPERLY and torqued properly (need to do it right imho), download it. I'm using VHT black wrinkle spray paint Pritchard Quote
SiriusProjects Posted February 18, 2015 Author Posted February 18, 2015 The thing is when it comes to engines, I've never in my life attempted anything like this. I mean I've never used a torque wrench for christ sake. Quote
RobPhoboS Posted February 18, 2015 Posted February 18, 2015 The thing is when it comes to engines, I've never in my life attempted anything like this. I mean I've never used a torque wrench for christ sake. Find someone to help out from the club, where do you live ? Quote
SiriusProjects Posted February 18, 2015 Author Posted February 18, 2015 I live near Glastonbury in Somerset. Quote
evest Posted February 18, 2015 Posted February 18, 2015 I was in the same position when i wanted to remove my plenum to polish it. Never used a torque wrench either. Just set aside plenty of time and you'll be fine mate Quote
glrnet Posted February 19, 2015 Posted February 19, 2015 The thing is when it comes to engines, I've never in my life attempted anything like this. I mean I've never used a torque wrench for christ sake. Find someone to help out from the club, where do you live ? Or take a trip to the Zed Shed. Nice drive, nice guys, good banter, take doughnuts, job done!! 2 Quote
MrChow Posted February 19, 2015 Posted February 19, 2015 Torque wrenches are easy to use mate, they're basically like using a socket set that doesn't let you 'Over tighten' the bolt. Instead you hear a 'click' when it's tightened to the right torque. Find out what this is first... As for the plenum, I removed mine the other week. Piece of cake. Don't rush it, if in doubt lay all the bolts out in the order you've removed them in. Try getting a magnetic tray instead of putting them in the scuttle panel like I did. If your cars got a plenum spacer in, there will be spacers underneath the strut bar, be careful when taking the bolts out for this because the spacers could slip down inside the engine bay, and if they're alloy like mine were, a magnet won't help. Also. Remember to plug the MAF sensor back in afterwards... Quote
RobPhoboS Posted February 19, 2015 Posted February 19, 2015 (edited) Actually get some masking tape and a marker pen, label each bolt And ensure you have the right tools. Also worth checking out this video as he takes the plenum off/pops back on: Edited February 19, 2015 by RobPhoboS Quote
glrnet Posted February 19, 2015 Posted February 19, 2015 Actually get some masking tape and a marker pen, label each bolt And ensure you have the right tools. Also worth checking out this video as he takes the plenum off/pops back on: Exactly what I did 1 Quote
Ricey Posted March 6, 2015 Posted March 6, 2015 Depending on the paint you use it'll need etch priming Quote
