Help with slam panel what am i doing wrong:(
Ok so just got my slam panel and popped off the plastic caps and fitted it right on no problems. Then when I go to close bonnet it wont close :( so then took off other part of clip to reduce the height to see if it was the height closed it again still nothing. This is so frustrating an easy job like this but cant get bonnet to close.
Thanks for the suggestion wasso but still wont close :(
Seems like the bonnet is now to far away to the latch so wont connect
Yep when I got my catch blinged by Mark he did mention i may need to adjust if i fitted a slam panel - luckily was OK
Any guides for doing this had a look and cant see any bolts that look like I would adjust. If it matters have a 2005 z
Loosen the three bolts that hold on the bonnet catch. Then lift the catch slightly (it does move about with the three bolts loosened). Do them up fingertight while holding the catch in position, then tighten then with your spanner/ratchet.
Yes you need to adjust the bonnet catch slightly. I didn't do this when I fitted my slam panel and eventually ended up getting the bonnet to close but then it wouldn't open again! So then had to adjust the catch lol.
Ah thanks guys I get what you mean now. Cheers for explaining that 14n. Ok round 3 at going for it before it gets dark
it will sort it once you have adjusted the catch up like the other guys have mentioned, its a 50-50 weather you have to or not mate.
Posted (edited)
Bonnet fell on my head and was trapped out there all night was calling for help and my neighbour came over thinking she was going to help but said "that's what you get for having a loud exhaust" walked away :(
Edited by PPod
Yeah managed to get it sorted only took 5 mins but fell asleep straight after so never posted up sooner.(hate switching from nightshift to day) thanks guys
Hope you managed to get into bed rather than spark out asleep on your slam panel :teeth:
I thought we were gonna see news headlines this morning.... :cold:
BREAKING NEWS
Man found frozen and suffering from hyperthermia after spending the night outside with his fingers trapped under the bonnet of his Nissan 350z.
Car and owner are reported to be in a stable condition.
  • Like 2
