350z Fault Codes in PDF
SuperStu had a bit of time on his hands and has put together the fault codes in PDF so that you can download it to you phone or print it out a keep it in the car so that you don't have to have web access to check a code out and it's attached here.
Thanks Stu, good effort350z Codes.pdf
  • Thanks 1
Just what I needed today - but the code I want is missing :wacko:
P1275 seems to be skipped.
I checked my two sources, both missing. Grrrr.
Google says:
P1275 - Nissan
Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
Description
Air fuel (AF) ratio sensor 1 - response time
Cause
HO2S, AF sensor, fuel pressure, injectors, intake air leak, exhaust leak, MAF sensor
PS - google isn't always right. If this gets confirmed I'll update the PDF.
Cheers
I've had a few other related codes which make me suspect rear O2's and I have some replacements.
If the problem goes away then I'll let you know :)
She has done a few miles so injectors are also a possibility but the codes appear at certain times so I'm going with O2s first.
I've got the RS tuning so I did wonder if it needs adjusting or redoing now the car has done 100K miles since it was first done. I'll post that up separately.
With each new model year, Nissan added additional codes. I suspect the list from a 2009 model would be the most complete.
