kinglozzer Posted July 31, 2013 Posted July 31, 2013 Hi guys, Thinking about getting some HFCs, to go on my otherwise stock exhaust system. Firstly, will Berk HFCs pass an MOT in the UK? I don't know any mechanics unfortunately . Also, do you guys think this is a DIY job? I saw the autohow YouTube video on it and it looks straight-forward enough to me. How do you think they'll sound on a stock exhaust? Of course plans are to do the whole system but first things first . Thanks 2 Quote
Bems Posted July 31, 2013 Posted July 31, 2013 I have some on a stock exhaust with a takeda short ram system and for me it has just the right note. Not boomy and not overly loud all of the time until you put the foot down! Quote
coldel Posted July 31, 2013 Posted July 31, 2013 Yes they do pass the MOT Fitting is bolts off cat out, direct replacement - although bolts can be very much sealed on so make sure you got room to get under and get leverage on them Berks HFC will give you car a raspy sound, somewhat metallic, its alright for most although some dont like it. Quote
Bockaaarck Posted July 31, 2013 Posted July 31, 2013 As the guys have said, yes the will pass an MOT so you shouldn't worry too much about that. The BERKS HFCs are great, I had some fitted fairly recently. Initially they were a little raspy. However, given a few months mine bedded in nicely and the exhaust now has a lovely consistent tone, which is subtle at low revs and then rich, deep and almost burbley as I apply a few revs. I do have a Stillen Y Pipe and a Miltek backbox (etc) rather than standard, which probably helps. Quote
drfeelgood73 Posted July 31, 2013 Posted July 31, 2013 HFC's are easy to fit..... just have long extension bars as 1 nut on each side is accessed through the engine bay......( was on mine anyway) about 38" length should do you.... Sound again depends on what you got it attached to..... Loads of different options from guys on here..... Quote
kinglozzer Posted August 1, 2013 Author Posted August 1, 2013 Thanks for the advice all, I'm saving for a Nismo cat-back to attach it to, thought I could get the cats done first Quote
The G Man Posted August 1, 2013 Posted August 1, 2013 Once you've done the HFC's and catback, it's worth getting the car UpRevved, really does make the difference to these types of mods. Quote
Tarmac@TarmacSportz Posted August 1, 2013 Posted August 1, 2013 I wouldn't attempt doing it DIY unless you are competent as it can be a pain especially with hand tools. Just one seized bolt will ruin your day and knuckles Quote
ninjaz Posted August 1, 2013 Posted August 1, 2013 There seems to be a lot of interest in HFC's recently. Any chance of a group buy Tarmac? Quote
Tarmac@TarmacSportz Posted August 1, 2013 Posted August 1, 2013 Yes if you want to set it up in my section £370 DE £395 HR Minimum of 5 Quote
ninjaz Posted August 1, 2013 Posted August 1, 2013 That sounds good tarmac, I'll try and sort out a thread today or tomorrow then. Cheers Quote
Bems Posted August 1, 2013 Posted August 1, 2013 Forgot to mention mine were fitted at MOT time and there were no issues at all with emissions. Quote
Will370z Posted August 1, 2013 Posted August 1, 2013 I'll admit hfcs were the best thing iadded to my 350, loved them. I agree with Tarmac though, i wouldn't try fitting these yourself unless you know what you are doing, it can be tricky Quote
ianphampton Posted August 1, 2013 Posted August 1, 2013 (edited) You do need to get them HOT before they'll pass the MOT - when cold they're not functioning at the level required for the emissions First time mine failed the MOT I told the guy to go and give her a hard run for 20 minutes and she sailed through then - you need to emphasize that to your MOT station. Edited August 1, 2013 by ianphampton Quote
martek Posted August 11, 2013 Posted August 11, 2013 Guy's If we get a group buy, could we add a fitment price? Cheers Dave. Quote
