offset question
P15UL T
All comes down to the design of the wheel. 28 on one wheel would clear but then on another it might not.
Generally 28 is quite high and will probably sit fairly tucked in at the front.
offset and width go absolutely hand in hand
one can't say how a +28 will look without saying how wide it is
It also depends on the tire (both size and brand)
IE - an 18x8.5 with a +28 and 18x9.5 +28 look vastly different (9.5 will sit out 1/2 inch more) despite the offset being the same
for example - this is 18x8.5 +20 up front (9.5 +20 out back)
An 18x9 with a +26 would sit exactly the same in relation to the fender of the car
this is a good offset calculator
http://marksink.com/tire_wheel_offset/offset.html
here is the widths of the rims - dont have tyres on them so what would you reccomend if they will indeed fit ?
19x9.5 front offset 28 (will they clear the brembos)
19x10.5 rear offset 22
cheers in advance
ps - that is a sweet ride adam, is it yours ?
i really quite thick when it comes to this.....but i take it the wheels would stick out further dues to the increase in wheel width but also stick in further due to the difference in offset ???
thanks for your help guys :thumbs:
