LewisH Posted February 6, 2013 Posted February 6, 2013 I only recently discovered the 06 revup is 'notorious' for oil consumption... something i was hoping to avoid after owning an RX-8! Now i'm checking it all the time and it seems to always need more. I'm just curious about other 06'er experiences with the oil. Hoping that it puts me a little more at ease. Cheers all. Quote
Wasso Posted February 6, 2013 Posted February 6, 2013 Yes mine consumes a fair bit, even more so now at 75k. Quote
Ekona Posted February 6, 2013 Posted February 6, 2013 Mine never used that much at all, but that seemed to be the exception rather than the rule with the revup. Quote
Rob22 Posted February 6, 2013 Posted February 6, 2013 I added 2, or else 3 x0.5L top ups between changes last time (about 7000 miles). I think I remember reading different spec oils can make a difference in consumption too. Quote
Paddy78 Posted February 6, 2013 Posted February 6, 2013 Mine has started to use a bit which has made me a bit paranoid. Going to get it scoped / compression tested when I get the revup in a few months, although I'm not sure if that will detect this specific issue? This is the one piece of info I missed when doing research on the Zed... I'm not sure there's an easy fix either as it's something to do with the piston holes (I know there's a proper name for this, but I can't remember!) not being quite round enough which leaves a slight gap for the oil to get in and burnt. I could be wrong, but I think if the oil consupltion isbad, the only option is a new engine or rebuild, which is obviously £1000's? Quote
ATTAK Z Posted February 6, 2013 Posted February 6, 2013 Has your car been run on lower grade fuel ? Quote
Paddy78 Posted February 6, 2013 Posted February 6, 2013 Has your car been run on lower grade fuel ? I've had it a year and bar 1 tank of Tesco Super it's only had V-Power... I can't vouch 100% for the 5 years before. I bought it from an independent dealer who obviously said it had, but they nor the original owner could prove that either way, so the damage will have already been done! Quote
ATTAK Z Posted February 6, 2013 Posted February 6, 2013 Nissan will tell you that up to 1 litre per 1000 miles is within tolerance Quote
jell36 Posted February 6, 2013 Posted February 6, 2013 Mine doesn't appear to have used a drop of oil, it's covered 4,000 miles since the last oil change and the oil level is still right at the top of the max oil mark on the dipstick which is where I filled it to then the oil was changed. Quote
Paddy78 Posted February 6, 2013 Posted February 6, 2013 I'm monitoring mine at the moment, but I've only done 250 miles since my P2 service in December. How do you tell how many litres (Hopefully just ml !!!) you've used when checking the dipstick? I know that max is 4.7l, but how much is left when on min? This would help to calculate how much has been used. Quote
ersen.o Posted February 6, 2013 Posted February 6, 2013 u guys got me worried i aint checked my HR in a while :x Quote
ATTAK Z Posted February 6, 2013 Posted February 6, 2013 I'm monitoring mine at the moment, but I've only done 250 miles since my P2 service in December. How do you tell how many litres (Hopefully just ml !!!) you've used when checking the dipstick? I know that max is 4.7l, but how much is left when on min? This would help to calculate how much has been used. On a DE engine, min to max = 1.5 l Quote
Ekona Posted February 6, 2013 Posted February 6, 2013 u guys got me worried i aint checked my HR in a while :x Shoould be checking oil at least once a week, maybe once a fortnight at the most. Quote
S1 HNK Posted February 6, 2013 Posted February 6, 2013 I check my oil weekly. Mine has gone from max to 3/4 in the past 5000 miles and doesn't seem to drop any more than that but its easy to forget to check and if Nissan say 1litre over a 1000miles is in their tolerance, it wouldn't take much to go from max to min and that would be a scary site! Quote
DoogyRev Posted February 6, 2013 Posted February 6, 2013 Mine used about 1ltr over 3 years and 45K Miles Quote
ersen.o Posted February 6, 2013 Posted February 6, 2013 Checked mine was near the low marker but only needed 1 litre, that's over 1.5 years and 10k miles Quote
Gudzy Posted February 6, 2013 Posted February 6, 2013 Checked mine was near the low marker but only needed 1 litre, that's over 1.5 years and 10k miles You really did mean you hadn't checked for a while! If that timescale doesn't include having an oil change, I'd suggest you do an oil change. Quote
ersen.o Posted February 6, 2013 Posted February 6, 2013 Haha yea service was August 2011 @ 14k miles so ordered my new oils n stuff off zmanalex yesterday for a service Quote
