Vlad's Supercharged 350Z - pg20 Banzai Mag Feature
Ah i see, it looks nice Vlad.
I have the NRG slimline boss and gen 2.5 quick release hub. I preferred the wheel bolted directly to boss but as you have mentioned you quickly adapt. Nice bit of kit with a deep dish
Posted (edited)
well, here's another small update...
Fitted quick release today
And picture of blue/red LED conversion of the dash + new dial cards
^ found 2 faults so far... "side lights/headlights on" light/LED not working and second half of the speedo is not very bright even tho all LEDs are on. Will investigate :)
Next thing to change gear shaft (as it snapped as per my other thread) and hoover inside of the car :lol:
Edited by Vlad
Very nice. :)
Have you got one of those D loops in your Zed's boot then Vlad?
It's a good idea if you haven't as it means you can padlock the steering wheel to it and leave it in the boot of the car when you go shopping or whatever. ;)
Can't find an image to show you but basically just a welded loop of metal in the boot which you can then padlock your steering wheel to.
nah, i'll be a cool kid and carry it on the back of my backpack... just like that kid in Fast and Furious: Tokyo Drift :lol:
why stop there your half way towards a quick release gear stick too :lol: liking the steering wheel :thumbs:
i'm not half way there...i'm already there :lol:
Was that the Korean version of "Fast & the Furious: Tokyo Drift" Vlad?. :lol: Lol.
If you could set one of those rotary car lift garages up in your house to store the Zed now that would be cool. :yahoo:
Haha I'm not sure...but couldn't find that scene in English lol
Oh that would be cool indeed...or one of them garages that lift up from under the ground lol
Was about to change my short shifter to OEM one after it snapped.... but came up with great idea... still plenty of metal left - so made up new thread on the stick and its old good :)
Trial fit
Trial fit with gear surround on
Happy days :)
  • 1 month later...
Little update
It was time to upgrade brakes slightly...
Bought a set of discs off Keyser, set of yellow stuff pads from Cougar Store and Motul 660 RBF off Clark Motorsport
Fitted Fronts no problem
Rears wasn't as easy as 2 nuts on rear drivers side wheel spacer rounded off...
so men's best friend came to the rescue...
Grinded off some of spacer around 2 rounded nuts to give more access for a size smaller socket...
Also accidentally popped piston out of rear caliper (passenger side)... So thought it was good time to replace seals at same time...
Ordered new spacer and seal kit off Clark Motorsport
New seals fitted, brakes fitted, new fluid is in, spacer on, HAPPY DAYS :)
Got some new wheel nuts as well
Then decided to change my vortech filter.... really like the look of HKS mushroom filters... but SC diameter is 90mm and HKS only do 80mm or 100mm.... then Darren suggested buying cheaper filter (same style as HKS) and just replacing foam as original foam it comes with is pretty crap.
So bought one of them Ash Performance filters, some RamAir replacement foam, took it apart, cut out new foam, refitted...and yes, HAPPY DAYS :D
  • Like 2
